šŸ“£ WinBox 4 is here šŸ“£
Agree the login screen can be improved. At least part of that is already on the list:
With the new solution allowing multiple tabs be selected at the same time (Shift+Click), the tables may be places one above the other :slight_smile:
But this won’t allow to choose the same tab multiple times. My suggestion is much more flexible and allows not only to choose different tabs, but also choose the same tab on multiple panels and adjust their sizes and positions as required. As on example above, you can show different saved groups (Home and Work routers) or whatever you like simultaneously without any need to switch.
The example working was with Waterfox - for all intents and purposes, Firefox. The example with problems was WInbox. I’m using KDE, so that really may influence things. And it would open a whole new can of worms: how much variation would the several window managers on Linux create? There must be SOME tag or whatever that we could use to make the behavior (a little more) predictable.
I think that is one of the reasons why so many software makers do not release versions for Linux.
You just do not know in what environment your application is going to run. There are many different distributions, there are different window managers, way less standardization of fonts, etc etc.
It is beneficial to have so much flexibility, but it also makes end-user support and handling of bugs more difficult.
But we don’t know if we are right on this one: it may very well be a different thing. Because the browser part of the hints always worked for me - en Linux. It’s the Winbox 4 part of the hints that doesn’t work. For all we know, they may even have used the wrong tag this time.
For example: I know there are standard ways to put/read things to/from the clipboard. So CTRL+C and CTRL+V can be made to work the same, across all window managers - even between one Gnome application and KDE. There are other examples, but this one I remember.
With a little bit of luck is just a wrong TAG, a bad parameter and that’s it.
…still no ā€œOpen in new windowā€
Mikrotik, please simply duplicate the exact functionality in Mac Inbox 4 that you currently have in Windows Inbox 3.42..
Do that first, before anything else…Then go from there.. Simple.. :smiling_face_with_sunglasses:
Yes, it was suggested many times and I also support this. But it seems they don’t care. They are just making some improvements of initially shitty interface and they are doing them VERY slowly. In such situation it would probably better to make skins support and create a few skins including WinBox 3 style, that would exactly repeat WinBox 3 interface. And of course give us a skin editor to adjust everything. With current style and layout I will never use this product on a daily basis.
Hear hear!
Adding a qt.conf file to the executable’s directory with the content:
[Platforms]
WindowsArguments = fontengine=gdi
allows the fonts to be substituted again.
DjM, mikey, have you updated to the latest beta?
Rows spacing is pretty ok now, tabs are back, VLANs have indentations are grouped in a tree, undo, redo, safe mode are also here…
Request: Sidebar menus with submenus should open the flyout on Press instead of on Release. This mimics other menu behaviors.
I’m not sure if there’s any downside to showing the submenu on hover. In fact if I open a submenu and hover around other menus, they pop out automatically after about 500ms… and it doesn’t seem terrible.
Request: ā€œSafe Modeā€ checkbox on the Connect Screen.
Bonus points for a ā€œRead Onlyā€ checkbox.
These are good ideas !
I don’t get the point. What are you going to put in a safe mode, when a router is not connected?
And what checkbox are you talking about?
Content deleted by author.
Lets just switch to java.
Mikrotiks competitors use it, so it has to be good.
(that’s a joke)
Yes, yes, yes.
And just a little addition about RAM usage:
WinBox 3: <30 MB
WinBox 4: >300 MB with the same window set. And can easily reach 500 MB and more with not so much opened windows.
And with all of that it's very unresponsive in comparison with very fast lightweight WinBox 3.
There are delays and freezes everywhere: when switching between tabs, with log autoscrolling, when opening a subwindow.
20-30 times higher resource usage and much slower performance and responsiveness...
These are common issues with modern GUI software - they often use a lot of RAM, put a heavy load on the CPU, and can feel slow to use. That’s just how things have evolved over the past 20 years. Just look at Windows and other Microsoft software.
Still, one thing that shouldn’t be done wrong is the design: it should look modern, be efficient, and support productivity.
