It's a mikrotikish reminder to change your password ![]()
Or take next step not using passwords at all.
Use PKI.
I was also using an Ed25519 key (only used passwords with WinBox), but it suddenly stopped working... That's when I lost SSH access with any users other than admin.
It's time to do a factory reset and try again ![]()
None of them are non-ASCII characters… it just stopped working out of the blue without any changes…
Thanks everyone for the help, I’ll look around and try to sort this out.
I got a crash from WinBox4 when trying to delete a "folder" in Files:
Translated Report (Full Report Below)
Process: WinBox [96905]
Path: /Applications/WinBox.app/Contents/MacOS/WinBox
Identifier: com.mikrotik.winbox
Version: 4.0.98044 (4.0.98044)
Code Type: X86-64 (Native)
Parent Process: launchd [1]
User ID: 506
Date/Time: 2026-01-02 13:56:14.4639 -0800
OS Version: macOS 15.6.1 (24G90)
Report Version: 12
Bridge OS Version: 9.6 (22P6083)
Anonymous UUID: 86ACF646-12D5-4059-5A43-605C0F154657
Sleep/Wake UUID: C49F2F39-4731-4E38-9F65-5B249391FAD8
Time Awake Since Boot: 1500000 seconds
Time Since Wake: 18149 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000008
Exception Codes: 0x0000000000000001, 0x0000000000000008
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [96905]
VM Region Info: 0x8 is not in any region. Bytes before following region: 4540801016
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 10ea72000-110cf6000 [ 34.5M] r-x/r-x SM=COW /Applications/WinBox.app/Contents/MacOS/WinBox
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 WinBox 0x110322ef2 Handler::sendCmd(unsigned int, HPath const&, nv::message&) + 610
1 WinBox 0x11031a773 0x10ea72000 + 25855859
2 WinBox 0x110323ffc IHandlerMngr::msgRx(nv::message) + 1212
3 WinBox 0x11018fc51 0x10ea72000 + 24239185
4 WinBox 0x110191d3b 0x10ea72000 + 24247611
5 WinBox 0x10fdacafa 0x10ea72000 + 20163322
6 WinBox 0x10fdacafa 0x10ea72000 + 20163322
7 WinBox 0x10f5b9bf2 0x10ea72000 + 11828210
8 WinBox 0x10f5c20dd 0x10ea72000 + 11862237
9 WinBox 0x10fd6c248 0x10ea72000 + 19898952
10 WinBox 0x10fd6bfce 0x10ea72000 + 19898318
11 WinBox 0x10fe9a8df 0x10ea72000 + 21137631
12 CoreFoundation 0x7ff8117befb3 __CFSocketPerformV0 + 951
13 CoreFoundation 0x7ff811798ab0 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
14 CoreFoundation 0x7ff811798a52 __CFRunLoopDoSource0 + 157
15 CoreFoundation 0x7ff81179880d __CFRunLoopDoSources0 + 203
16 CoreFoundation 0x7ff811797476 __CFRunLoopRun + 973
17 CoreFoundation 0x7ff811796a72 CFRunLoopRunSpecific + 536
18 HIToolbox 0x7ff81d2880d4 RunCurrentEventLoopInMode + 281
19 HIToolbox 0x7ff81d28af97 ReceiveNextEventCommon + 499
20 HIToolbox 0x7ff81d41419a _BlockUntilNextEventMatchingListInModeWithFilter + 63
21 AppKit 0x7ff8151fbdb1 _DPSNextEvent + 912
22 AppKit 0x7ff815c8a137 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1263
23 AppKit 0x7ff8151ece99 -[NSApplication run] + 610
24 WinBox 0x10eac9349 0x10ea72000 + 357193
25 WinBox 0x10fd73746 0x10ea72000 + 19928902
26 WinBox 0x10fd6c368 0x10ea72000 + 19899240
27 WinBox 0x1101627f5 main + 19749
28 dyld 0x7ff81130a530 start + 3056
Thread 1:: QQmlThread
0 libsystem_kernel.dylib 0x7ff8116748f2 poll + 10
1 WinBox 0x10feade7f 0x10ea72000 + 21216895
2 WinBox 0x10feb18f3 0x10ea72000 + 21231859
3 WinBox 0x10fd73746 0x10ea72000 + 19928902
4 WinBox 0x10fe2b629 0x10ea72000 + 20682281
5 WinBox 0x10feaf8eb 0x10ea72000 + 21223659
6 libsystem_pthread.dylib 0x7ff8116afe59 _pthread_start + 115
7 libsystem_pthread.dylib 0x7ff8116ab857 thread_start + 15
Thread 2:: QNetworkAccessManager thread
Thread 3:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x7ff8116769fe __select + 10
1 CoreFoundation 0x7ff8117bd10c __CFSocketManager + 671
2 libsystem_pthread.dylib 0x7ff8116afe59 _pthread_start + 115
3 libsystem_pthread.dylib 0x7ff8116ab857 thread_start + 15
Thread 4:: QSGRenderThread
0 libsystem_kernel.dylib 0x7ff8116706f6 __psynch_cvwait + 10
1 libsystem_pthread.dylib 0x7ff8116b0302 _pthread_cond_wait + 988
2 WinBox 0x10febc1db 0x10ea72000 + 21275099
3 WinBox 0x10febc134 0x10ea72000 + 21274932
4 WinBox 0x10f073c14 0x10ea72000 + 6298644
5 WinBox 0x10f073d06 0x10ea72000 + 6298886
6 WinBox 0x10f07422c 0x10ea72000 + 6300204
7 WinBox 0x10feaf8eb 0x10ea72000 + 21223659
8 libsystem_pthread.dylib 0x7ff8116afe59 _pthread_start + 115
9 libsystem_pthread.dylib 0x7ff8116ab857 thread_start + 15
Thread 5:: com.apple.NSEventThread
0 libsystem_kernel.dylib 0x7ff81166db4a mach_msg2_trap + 10
1 libsystem_kernel.dylib 0x7ff81167c704 mach_msg2_internal + 83
2 libsystem_kernel.dylib 0x7ff811674bc3 mach_msg_overwrite + 574
3 libsystem_kernel.dylib 0x7ff81166de3b mach_msg + 19
4 CoreFoundation 0x7ff811798bf2 __CFRunLoopServiceMachPort + 145
5 CoreFoundation 0x7ff81179763f __CFRunLoopRun + 1430
6 CoreFoundation 0x7ff811796a72 CFRunLoopRunSpecific + 536
7 AppKit 0x7ff8153509cf _NSEventThread + 127
Thread 6:
0 libsystem_pthread.dylib 0x7ff8116ab834 start_wqthread + 0
Thread 7:
Thread 8:
Thread 9:
Thread 10:
Thread 11:: CVDisplayLink
1 libsystem_pthread.dylib 0x7ff8116b0335 _pthread_cond_wait + 1039
2 CoreVideo 0x7ff81b1c6f09 CVDisplayLink::waitUntil(unsigned long long) + 375
3 CoreVideo 0x7ff81b1c5ea0 CVDisplayLink::runIOThread() + 524
4 libsystem_pthread.dylib 0x7ff8116afe59 _pthread_start + 115
5 libsystem_pthread.dylib 0x7ff8116ab857 thread_start + 15
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00006000006591e0 rbx: 0x00007ff7b148b330 rcx: 0x0000000111088400 rdx: 0x0000000111088000
rdi: 0x0000000000000002 rsi: 0x0000600000658000 rbp: 0x00007ff7b148b260 rsp: 0x00007ff7b148b220
r8: 0x0000000000000008 r9: 0x000000006be2e800 r10: 0x00000000001ff800 r11: 0x0000000000000030
r12: 0x0000600001397cc0 r13: 0x000060000065bc90 r14: 0x0000000000000000 r15: 0x0000000000000008
rip: 0x0000000110322ef2 rfl: 0x0000000000010216 cr2: 0x0000000000000008
Logical CPU: 8
Error Code: 0x00000004 (no mapping for user data read)
Trap Number: 14
Thread 0 instruction stream:
8b 23 4d 8b 6c 24 20 4d-85 ed 74 23 4c 89 e8 66 .#M.l$ M..t#L..f
66 66 66 66 66 2e 0f 1f-84 00 00 00 00 00 81 38 fffff..........8
02 00 ff 88 74 31 48 8b-40 08 48 85 c0 75 ef bf ....t1H.@.H..u..
28 00 00 00 e8 99 89 75-fe c7 00 02 00 ff 88 0f (......u........
57 c0 0f 11 40 10 48 c7-40 20 00 00 00 00 4c 89 W...@.H.@ ....L.
68 08 49 89 44 24 20 48-83 c0 10 4c 39 f8 74 1a h.I.D$ H...L9.t.
[49]8b 76 08 49 8b 56 10-48 89 d1 48 29 f1 48 c1 I.v.I.V.H..H).H. <==
f9 02 48 89 c7 e8 24 fb-f3 ff 49 8b 7e 20 48 8b ..H...$...I.~ H.
07 48 89 de ff 50 10 48-83 c4 18 5b 41 5c 41 5d .H...P.H...[A\A]
41 5e 41 5f 5d c3 eb 00-48 89 c3 48 8b 7d c0 48 A^A_]...H..H.}.H
85 ff 74 09 48 89 7d c8-e8 07 89 75 fe 48 89 df ..t.H.}....u.H..
e8 19 87 75 fe 66 0f 1f-84 00 00 00 00 00 55 48 ...u.f........UH
Binary Images:
0x10ea72000 - 0x110cf5fff com.mikrotik.winbox (4.0.98044) <5fbbe0e4-0fc1-3aed-910f-1158fe462ca9> /Applications/WinBox.app/Contents/MacOS/WinBox
0x11428c000 - 0x1142a2fff com.apple.security.csparser (3.0) <cbad8bc8-7a41-3852-bf3e-f32fb787dff0> /System/Library/Frameworks/Security.framework/Versions/A/PlugIns/csparser.bundle/Contents/MacOS/csparser
0x11df22000 - 0x11df2efff libobjc-trampolines.dylib (*) <fc1d5fa4-f762-3c6a-bdff-bc47152fb2de> /usr/lib/libobjc-trampolines.dylib
0x7ff81171d000 - 0x7ff811bd1fe2 com.apple.CoreFoundation (6.9) <e07800d9-4e39-3c3c-852c-6620a2ae4070> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7ff81d1e0000 - 0x7ff81d4c16ed com.apple.HIToolbox (2.1.1) <cace9f6b-e827-3cc3-8613-47743a3c458c> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7ff8151bc000 - 0x7ff81670d493 com.apple.AppKit (6.9) <fe1f4402-834c-30cb-b66b-ccec88c1dc60> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7ff811304000 - 0x7ff81139e6c7 dyld (*) <c6e52c5e-d1d2-354c-a4ec-069f8d5baafe> /usr/lib/dyld
0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
0x7ff81166d000 - 0x7ff8116a9b4f libsystem_kernel.dylib (*) <a0701b73-99d9-31f3-babf-51c65e53ebbd> /usr/lib/system/libsystem_kernel.dylib
0x7ff8116aa000 - 0x7ff8116b5faf libsystem_pthread.dylib (*) <2f5f8bae-cebe-30d8-83e3-eca5a30ea39d> /usr/lib/system/libsystem_pthread.dylib
0x7ff81b1c4000 - 0x7ff81b217913 com.apple.CoreVideo (1.8) <ab5d4910-4b00-301c-b99e-2cc2097655b5> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 8
thread_create: 0
thread_set_state: 419
VM Region Summary:
ReadOnly portion of Libraries: Total=1.2G resident=0K(0%) swapped_out_or_unallocated=1.2G(100%)
Writable regions: Total=2.7G written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=2.7G(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 2
Activity Tracing 256K 1
CG image 32.1M 6
ColorSync 252K 31
CoreAnimation 184K 17
CoreGraphics 12K 2
CoreUI image data 1192K 9
Foundation 40K 2
IOKit 15.5M 2
JS VM Gigacage 16.0M 4
JS VM Isolated Heap 6416K 5
Kernel Alloc Once 8K 1
MALLOC 2.6G 139
MALLOC guard page 72K 18
STACK GUARD 56.0M 12
Stack 21.1M 13
VM_ALLOCATE 848K 109
__CTF 824 1
__DATA 32.9M 919
__DATA_CONST 102.0M 941
__DATA_DIRTY 2576K 337
__FONT_DATA 2352 1
__INFO_FILTER 8 1
__LINKEDIT 163.0M 5
__OBJC_RO 61.3M 1
__OBJC_RW 2396K 2
__TEXT 1.1G 958
__TPRO_CONST 16 2
mapped file 231.0M 75
shared memory 1312K 19
TOTAL 4.4G 3635
With 3200 comments, 44 beta versions and a lot of bug fixes / improvements / regressions in between. Perhaps it’s time to create a separate thread each time a new beta version is released?
Keep putting a good summary at the start and people can go from there. Similar to how the RouterOS announcements are done.
One might think that, after roughly 17 months in beta, a release candidate level of quality would have been reached by now. I would not start new topics while still in beta.
Yes, for sure, b44 must be v1 now !
And still not easy bug reporting or source code auditing...?
It is NOT an open-source project. When you want open-source software, you will have to shop somewhere else.
Seriously? It' so raw and buggy, that there should be at least 40 more betas until even thinking about v1...
Mikrotik needs proper UI designers to get this thing done. Otherwise it will be like this forum in dark mode - which for some reason shows read topics in white text and unread topics in almost-indistinctible gray-on-bluish-dark-gray. Strangely other sites using Discourse are able to make their forum actually readable.
It’s not really about the suitability/progress on Winbox4. It more about readability in the forum.
No one is going to read 3k+ comments. There is an element of carry forward from each beta version in the list of issues unresolved and fixed which the Mikrotik team can continue to post at the opening comment for each new thread.
I figure it would also help the Mikrotik team find and trace bugs against each beta version.
I agree. A user has made a list of open problems, but of course that is always a subjective list and other people may see different problems and/or would not think of the items on the list being a problem.
To keep focus on the open problems it would be better when there is a separate smaller topic where each beta is discussed and there is actually a clear status of where each beta is, what it still needs, and comments can be made about that in particular. That should help MikroTik to develop in the direction of a finished product, instead of the way it is going now.
Any help to import databse hosts from 3.xx vesrions ? ![]()
Could this be changed, so that the grouped tabs are kept together even after switching to other tabs/tab groups. What I mean is that the tab groups should only be broken apart when using Shift + Left-Click too, not by normal click. Let me give an example:
For some property dialogs, such as the PPP Profile, I might prefer to group the tabs like this (tabs with fewer items are grouped together):
If I keep this view then WinBox 4 does remember the group and does restore the grouping even after the application has been restarted.
But if I switch to the General tab, then the grouping of the 4 other tabs is broken apart, and I'll have to manually group them again.
Could you please make the change, so that when I click on General, then back to any of the 4 other tabs, the 4 tabs are still kept together in one group? If I don't want them to be grouped together anymore, I would hold Shift and click on the individual tab headers to remove them one by one (this is currently already implemented).
One important note is that such behavior should be customizable. May be with some setting. In some scenarios it could be useful, in others not, so it could be inconvenient to break them, using additional key.
any workaround for this? im on macos
FEATURE-REQUEST
I would like to suggest an improvement to the WinBox user interface regarding window handling.
Currently, the WinBox main window inherits the size of the login window. From my personal perspective, it would be much more convenient if the login window were decoupled from the WinBox window.
Ideally, I would prefer:
A small, compact login window
After successful login, a WinBox main window that opens in the size defined by the workspace
At the moment, the WinBox window always opens with the same dimensions as the login window, even when “Open in new window” is enabled. This makes workspace management less intuitive and often requires manual resizing after every login.
Additional UI issue with inner windows:
Another related problem occurs when the WinBox window is resized to a smaller size. If you then open a section such as Interfaces, the inner window may open larger than the available WinBox area. In that case, the user has to manually resize the inner window to be able to see all content.
It would be very helpful if:
The inner windows were automatically constrained to the available WinBox window size
Especially on the right-top and right-bottom edges, inner windows should not exceed the parent window dimensions
This would significantly improve usability, especially on smaller screens or when working with tiled windows.
Thank you for considering this feature request.
Well, I am actually happy that the login window is sized like the working window, as I have a very long list of saved credentials.
What I do not like so much is that the properties of this window (and other things like font and zoom factor) are saved in one global config file, every time a WinBox closes. As I usually have like 6 WinBox windows open at the same time (on different virtual desktops), I have to close them all and only then I can change things, close it again, and re-open the different sessions to have new settings.
It would be better when the WinBox settings aren’t saved when they haven’t been changed.
(the selection of a router to connect should not be considered a change, or only that should be saved and not all other unchanged settings from that session)
Request 1: Please display the ROS version and processor type in the title bar as per Winbox 3.
Winbox 3 :
Winbox 4:
Request 2: Provide an option to have menu flyouts in single column as per Winbox 3 - Much faster to navigate and avoid incorrect selections. Flow to second column only when window size is too small.
Example is System flows a 3 column box when there is more than enough vertical space to show all entries.
