Winbox v3.21 released!
Just the opposite, there is no longer any possibility to use unsecured connection in Winbox.
Which is great.
Furthermore, /log print in Terminal is also useless because scrolling back Terminal screen to anything before the final contents results in sheared off, unreadable lines. With new WInbox, it is impossible to examine log at all without drag-and-dropping log file to local PC and examining it there. And this causes you to lose “memory” entries. Very bad regression.
+1
https://alaincasault.com/wp-content/uploads/2020/02/WB_3-21-scaled-e1582771764404.jpg
Log entry DPI issue already fixed in internal build.
This is great!
When can we expect a release?
Cheers,
AC
Make font selectable! Default font - is piece of crap, really.
How did they fix this? I reported above that the log window columns crop the data at the right side edge because the columns are too narrow in the zoomed view. They also lack headers to be able to manually resize them to the desired width.
I guess Normis’ answer means that the fix is already done and is waiting for the next release (presumably 3.22).
Didn’t someone said the log for WinBox 3.21 should be fixed later with new RouterOS version?
Well, yes, but that’s always been a deficiency in the log window.
RouterOS long-term 6.45.8
WinBox v3.21
I not use the standard admin username, but long username with also random character, for example “MyUser_HWC5RacbovLAnPtVOjYr2zstWAs022Gb”.
I test to simply capture traffic of the connection to router with Wireshark and I see that the username was send in clear text in the first frame.
In any https comunication the encryption is befor of any transfer of data. As is there be for username.
Can you work to implement the encrption befor of any other data?
Waiting for your kind reply, thank you.
Best regards
Like SNI? :smiley:
Or like DNS ? :smiley:
… I refer to SSL/TLS encryction use in Https.
In this case the SNI is not applicable, and more simple because one IP[:Port] is one device.
Did you ever check how SNI actually works?
Winbox v3.22 has been released:
http://forum.mikrotik.com/t/winbox-v3-22-released/137515/1
