Looks same, works different. Just zoom-in! New features always comes with new bugs. Product development cycle.
IMHO MikroTik relies a lot on the crowdsource community for final-testing stable releases before it goes into a long-term branch.
Don’t like bugs? Use long-term releases.
There is no long-term release for Winbox. These bugs were either a) always there and long time not discovered or b) are simple regressions because of e.g. some new column-drag-drop-feature.
When you need some very stable version without recent features but without some known problems, try version 3.21
It will still work with all version 6 RouterOS (but not with the v7rc3).
Show columns in OSFP / instance. After select “Effective Router ID” is showing other columns. Unselect columns (in/out filter) not work. It doesn’t work properly in other places either. (wireless tables / registration)
Just switched over to 3.30 TY, TY , TY , TY. I can now /export my config in terminal and it is fully visible scrolls well and doesnt not get overlapped on lines. TY, TY
(note: reg firmware not beta)
Just a caution - if you even just click OK in the show columns window without changing anything, it will still change what columns are displayed even though you haven’t actually made any changes. You don’t have to select or deselect anything to trigger this bug, apparently.
If i select to-adresses or to-ports and click ok, it changes the column width of every column and it never adds neither to-adresses nor to-ports in the columns …
What is interesting to me is introducing new software changes, often breaks existing code or introduces a whole new set of bugs… Good lesson for any testers out there…
Stupidly, when I installed v3.30 I forgot to keep a copy of v3.29. I reported the issues with columns to support on Thursday but their software archive doesn’t have copies of previous version of winbox, that I can find.
Could someboy kindly point me to a trustworthy site for downloading v3.29 ? Many thanks in anticipation.
