WinBox v3.42 released!
What’s new in v3.42:
*) added support for the Files menu in future RouterOS versions;
*) added some widget features for future RouterOS versions;
*) fixed crash when dragging the “#” column by disabling its movement;
*) fixed date fields to support year up to 2106;
*) terminal: ignore legacy shift-out (SO) character;
If you experience version related issues, then please report them to support@mikrotik.com.
Both Winbox 32-bit and 64-bit versions are available here:
https://www.mikrotik.com/download
thanks
The changelog probably uses \n as line separator instead of \r\n and WinBox v3.41’s textbox is unable to render them:
Thanks Mikrotik for this new version of WinBox 3 I personally love this software as it is simple and “raw” and I was seriously afraid that you had removed the support for v3.
make sure v4 to have a v3 layout in the future !
Sorry about the changelog. Newlines are fixed now.
Just one question, where can I find out more about these changes?
Waiting for the export feature in Winbox 4 to completely remove 3 from my installs!
There is a file browser in 7.19 for example. Not the current files menu but when you get to a spot where you need to select a file, it will now open a browser instead of just it being a single textbox.
That's what this is talking about.
I have 7.19.1 and WinBox 3.42, where is this new file browser?
The new file browser (and related WinBox protocol) is probably needed to address use cases where the file system has (tens of) thousands of files/folders, which should be more frequent, now that ROSE-storage/RDS are being pushed. The old file browser loading and listing all files and folders at once is certainly no longer adequate.
I think 7.19.x doesn’t have the necessary changes on the RouterOS side yet.
Version 7.20 will change how the system internally handles files menu. In order to do so, new WinBox was required. Nothing to do with popups, etc. Others would skip that line in changelog or hide it under “other fixes and improvements” :slight_smile:
will it fix problems caused by fileman locking things and scanning every drive connected?
It’s for 7.20+. The file menu is supposed to better represent the hierarchical file system, i.e. show only the content of the directory you’re in as opposed to every single files on the drive, which will be a godsend for folks using e.g. RDS2216.
http://forum.mikrotik.com/t/rose-and-the-files-menu/183099/3
If WinBox 3 is still alive, may be you finally fix these two very annoying bugs?
  1. If WinBox window has maximized state and was minimized to taskbar, then if reconnection happens, it loses maximized state, and this makes all internal windows to shrink to fit into new main window size, causing total mess.
  2. If you have an opened log window and a new message arrives, the window doesn’t scroll automatically and this new message may be hidden or not completely visible. But if one more message arrives, the window is scrolled automatically. I. e. scrolling happens only on every second message.
just wondering , what this does.
it does not make a copy
RB5009
Switch - Rule and clicking on + makes the winbox dissapear.
Winbox still does not use Prefixes above “GiB”
When are we going to see TiB?
For how long the normal WinBox is going to be supported? Version 4 is basically unusable.
Sometimes WinBox 3.42.102.0 freezes if you open the ARP list (IP > ARP).
In my case, the ARP list has no more than 390 entries.
The task manager shows that at the moment of freezing, WinBox is fully loading one processor core.
If you wait for some time, then the connection between WinBox and RouterOS x86 7.19.1 is broken after about 6 minutes.
A year or two ago, I used WinBox to track the average traffic received by a particular port. I think I just had to open some monitoring window, leave it running for a few minutes, and one of the boxes was “average Rx Mb/s” or something.
I have tried to do the same today and cannot for the life of me find the feature. Has it been removed or am I going crazy?
