WinBox v3.43 ESR (bugfixes, improvements)
it same lol
it not same :upside_down_face:
Isn't AI generating same patches for both projects and we have now "a race" of them?
If I linked the topic you can imagine that I've read it. Thanks.
yes and no, only mark1999 went the extra mile and patched some other issues (crash on devices that have cmr installed for example, which he fixed in v5 apparently, did not test).
fixed in patch set v4 in GitHub - mark99i/WinboxPatch: WinBox 3.43 for RouterOS 7.25 · GitHub
Add pls dark theme like this Winbox - Darkmode - Please - #33 by givbra
Don't be greedy asking for customizations at this stage, or you can spend your own tokens doing so.
Let him make the app functional.
Since many people already released their patches to make WinBox 3 work with 7.25+ with the help of AI, I don't see any sense in making my fix, because it would be just a time wasting, cause I'm not using AI.
So, I decided to release a patch, that applies the changes of my ESR version to already patched EXE that contains 7.25+ fixes. The patch will be published in a day or two.
Thank you for the patches, I didn't notice them right away, if you don't mind, I'll add them to my version, specifying you as the author?
No problem. Then my patch is not needed.
Please, if you can, update the icon to make the app look normally in explorer. I've already prepared the *.ico file and placed different icon sizes into it, from 16x16 to 256x256. However, it's not so simple, as it should be. Just replacing icon resource doesn't work, there are problems. I tried to update the icon in different ways, but without success. Sometimes, it displays fine in explorer, but in the window title there is a default icon, that is used for apps without icon resource. Sometimes, the icon in the title doesn't look smooth, i. e. it uses wrong size and resizes it. It looks, like MikroTik made some weird things and may be they load it dynamically, instead of letting OS to do everything...
WinBox3_Icon.zip (58.1 KB)
Regarding swap title order - I saw this request from the users multiple times and it's required, when you have many opened WinBox instances to distinguish them. If their titles start with "admin@x.x.x.x...", they look the same on taskbar. But when they start with identity, they are much more informative.
WinBox3_Icon.zip
My AI confirmed what you’re saying (I don’t know much about ASM myself), and it says it can be replaced. Is something wrong with the stock icon?
Got it, I’ll incorporate the patch into my build
Yes, stock icon contains very limited set, max 48x48 size:
As I said, it cannot be normaly displayed in explorer, because it requires much larger icons
and also it looks like that on taskbar:
I've also noticed a small issue with window title. It shows "via Winbox 3.43...". However, it should look like "- Winbox 3.43...". My mod originally uses hyphen before WinBox version. "via" prefix was initially intended to indicate an agent router address, when you are connecting through RoMON. Seems, AI misinterpreted its meaning.
I'm not suggesting features... since I'm not using the patch...
But, one idea it be sha1 (which is short) so you could match to the patch set being used to know which patch you were using. in theory the pure WinBox version# is pretty fixed :wink:
oh, ‘via’ syntax — this was my interpretation of this task and i forgot about romon.
Win10 and Win11 apparently parse icons differently, or I inserted them incorrectly; I didn’t find any difference between the patched and unpatched versions. I’ll need to look for Win7 again now, in 2026 haha
I don't think so. When you simply change an icon resource in any other executable, it's handled the same way on every OS from 7 to 11. It displays the icon correctly everywhere - in explorer, on taskbar, on window title and so on. But with WinBox 3 something strange happens.
And Win 7 support is also one of the reasons to remain on WinBox 3. Windows 7 is still used by many people, including me, just because it's not bloated with tons of :poop:, like telemetry, unneeded apps, it's much more responsive and fast, and UI is much better than in newer OSes. Similarly like WB3 vs WB4.
Thank you :slight_smile: Your work is awesome!
Thank you :slight_smile: Nice work!
