Use my mod, it has the button in the right place
Improved forum appearance (CSS based)
Colors are also much better than original.
But overall you are right, it's a global problem.
Good luck with newer RouterOS like 7.23+ As far as I have seen, it does not work with WinBox 3.x
For me WinbBox 4 do what I need to do.
There are new field types that WinBox 3 has no supports, for example, you can no longer edit/add containers with the GUI in WinBox 3:
There were bugs with default values that recently produced many forum threads with WiFi problems.
Also, there are also new field types that while editable with WinBox 3, get better support with WinBox 4 (like the combo address%interface@vrf fields).
That's where the dictionary/conversion table comes handy ![]()
Mikrotikish<->English conversion table/dictionary
By banning posts Mikrorik has demonstrated it has fully embraced the "cancel culture".
It's the "I don't like what you are saying, therefore you don't exist" type of energy.
A main reason I have stopped contributing to the forum which is now an echo chamber basically.
Sigh...
Well, your table only subtracts 1 release channel. In case of WB4 I think 2 channels should be subtracted. I. e. release=beta, rc=alpha, beta=... sandbox? ![]()
True, but the "early" counts for at least half a channel. But that is mainly for RouterOS versioning.
For Winbox it is worse
My suspect is that after almost two years of development and 3300+ posts on the related thread the 4.01 rc was published (in February) only because the 44 previous "beta"'s were getting dangerously near to 1200 in ternary.
