WinBox v4.1rc released!
What's new in 4.1rc3 (2026-Apr-08 10:31):
  • table: fix warnings printed in app output;
  • table: try to fix Windows on ARM rendering issues;
  • ui: fix Cancel button focus in file transfer progress dialog;
WinBox files for Windows, Linux and macOS are available here:
https://download.mikrotik.com/routeros/winbox/4.1rc3/WinBox_Windows.zip
https://download.mikrotik.com/routeros/winbox/4.1rc3/WinBox_Linux.zip
https://download.mikrotik.com/routeros/winbox/4.1rc3/WinBox.dmg
What's new in 4.1rc2 (2026-Mar-31 13:13):
  • form: fix optional address type field (WireGuard/Peers/Endpoint) (introduced in v4.1rc1);
  • ui: increase combobox popup's minimal width;
https://download.mikrotik.com/routeros/winbox/4.1rc2/WinBox_Windows.zip
https://download.mikrotik.com/routeros/winbox/4.1rc2/WinBox_Linux.zip
https://download.mikrotik.com/routeros/winbox/4.1rc2/WinBox.dmg
What's new in 4.1rc1 (2026-Mar-30 10:40):
  • form: improve "address" field by allowing to select Interface and VRF fields (where supported);
  • form: allow opening linked object or its parent table for certain fields (e.g., when adding an IP address and selecting an interface from the dropdown, it is possible to open either the interface table or the selected interface);
  • form: add support for input field postfix;
  • form: add support for min/max row count limit for multi fields;
  • form: add support for monospace font in scripts;
  • form: add support for new "note" attribute which shows documentation or hints on label hover;
  • form: change style of multi field plus/minus buttons;
  • form: fix "hyperlink" field type (IP/Routes Immediate Gateway);
  • form: fix sorting for some fields;
  • form: increase minimal width for combobox and multi-selection fields;
  • mdi: fix resizing when window was moved to top or left side and then resized;
  • mdi: move window resize mouse area 1px deeper within content;
  • mdi: try to move whole window into workspace when (re)opening;
  • table: change disabled row icon color;
  • table: make New button with dropdown expand full available height;
  • table: send only disable/enable attribute when disabling/enabling row;
  • table: update some firewall table icons to stand out more;
  • ui: make checkbox/radio/tooltip background color darker in light mode;
  • ui: make search result rows a little taller;
  • ui: simplify error message with MAC connection when device is not responding;
  • add new field type support used by future RouterOS version;
  • change intermediary certificate for Windows executable signing;
https://download.mikrotik.com/routeros/winbox/4.1rc1/WinBox_Windows.zip
https://download.mikrotik.com/routeros/winbox/4.1rc1/WinBox_Linux.zip
https://download.mikrotik.com/routeros/winbox/4.1rc1/WinBox.dmg
Let me try again: this used to work with old "wireless" drivers, not any more with new "wifi": if DHCP server is on the same device, in Wifi/Registration tab show "Active Host Name" if it exists.
Nice addition would also be to show the comment associated with static DHCP entry if hostname is not available, or always - for example I have many "smart" devices (switches, power sockets, battery management, weather station) that show as "lwip0", but I have a comment for each one.
please explain how it is supposed to work. this should work for “ping”, right?
also suggest to allow DNS lookup either local (in winbox) or in router (when supported), and indicate whether it should use IPv4 or IPv6 when DNS record for both is available.
20260330-winbox4.1rc1
Thank you for this update with some great improvements!
Interesting, it does not do that here! But the router is 7.22.1 maybe it requires 7.23beta?
No, I've tested on a device with 7.22.1 and it behaves the same.
I tried with 7.23beta4 and it works, but with 7.22.1 it does not work for me…
Interesting! Will this add inline documentation?
Both changes are great, thank you! But please make the dropdown lists wide enough to display the interface names without cutoff after few letters:
Works with 7.22.1 for me.
I hope a feature to easily rename an address list... (both winbox and cli)...
20260330-winbox4resizeftw
That's a work around, but it is not very user friendly to resize the whole window when the dropdown width could scale independently.
One step closer to colors.
But already better.
Also, while I know what it does... I still think the disconnect icon still in weird place. e.g. is disconnection from safe mode...
Clever idea, but the "Int…" looks lame. And ellipses could never be populated regardless of window size/font. Even some "IF" be better over "Int..." (interval? internal? lots of int... things).
Interstellar.
Seriously?
"If" looks as lame as "Int", whatever combination of letters you pick they can still match lots of unrelated words.
Would it be possible to avoid forcing everything into a single line by minimizing element widths? In a GUI with proper visual grouping, elements could be wrapped across multiple lines. The current approach feels quite limiting, and it’s a bit frustrating to hear that nothing can be done about it.
I checked again and now it works. I do not understand yet what went wrong.
My procedure to upgrade is like this:
  • rename WinBox to WinBox-4.0.1
  • unzip Winbox_LInux.zip
  • close an existing WinBox window
  • open it again from my shortcut pointing to WinBox
I am almost certain that Winbox-4.1beta1 appeared in the top bar when starting it, but this new feature did not work. Must be a mistake made somewhere because this morning after closing and re-opening the program it works.
