I already posted this in another older topic, but apparenly it’s not visible enough.
I’m having some problems with Wireguard on Hap Ac2 (7.1 beta3). I manage to get port forwarding working on my main router (Hap AC3) and now i would like to make a wireguard server on one of the CAPsMAN client (HapAC2).
It seems, that connection is working, since i can ping my phone’s IP from Wireguard server and also i can ping Wireguard server from my phone. But that is all that is working. I can’t get acces to any device in local network and also not to the internet from my phone. In allowed IP’s on client i have 0.0.0.0/0.
Should i enter some aditional routes in IP/routes or maybe some firewall rules?
HapAC3 has an ip 192.168.3.3 and is also gateway and DNS server for my network. If i check for firmware upgrade on HapAc2, new firmware check works, so internet acces is working.
The issue might be that there is no route from your devices back to the WireGuard subnet (10.0.0.0/24).
When a WireGuard client is sending traffic to a local device, the packets will go client → ac2 → local device and then the local devices will try to send an answer to the 10.0.0.0/24 network. They will send it to the ac3, since this is their default gateway, but the ac3 does not route the traffic to the ac2, because it has no route to it. So either you have to add a route at the ac3 (10.0.0.0/24 via ac2) or you SNAT your WireGuard clients.
And probably change where the local network ip address is placed (on bridge-local rather than ether2)
** Probably not exactly this (would need to remove/disable existing), perhaps edit using winbox **
add address=192.168.3.31/24 interface=bridge-local
I added firewall masquarade rule as you suggested and changed location of IP adress to bridge (i also did this yesterday but it just keeps jumping back to ether2, where LAN is connected every few hours). I tried but it stil doesn’t work. There must be some small thing i am missing. Is there any option to add default gateway ip to the configuration? Currently i only have DNS in configuration options.
There must be a way to configure this proberly on Mikrotik behind NAT. I’m currently running WG on RPI3 also behind NAT and it works flawlessly but it maxes out at 70 Mbps.
Sorry, i somehow completly overseen your post. Probably because of the late hour and yesterday i was to busy to try it.
Your solution actualy worked The only thing not working now is, that when i’m connected through wireguard i don’t have acess to my LAN, internet work’s normally. Any suggestions in that direction?
My comment was in moderation for quite some time, so that might be the reason why.
The reason for the traffic being dropped is the following: When a WireGuard client sends a packet to a local device, the ac2 directly forwards the packet to the local device, omitting the ac3. The response however is being sent to the ac3 by the local device. The ac3 detects that this packet is a response, but it is not aware of any request in its connection tracking tables, so the packet has the state invalid.
If you don’t need to be able to address your WireGuard clients from your local network, I’d recommend you to NAT the clients at the ac2. It will save you a lot of hassle, especially if you use firewalls on your local servers.
Just follow the the instructions for source NAT here: https://wiki.mikrotik.com/wiki/Manual:IP/Firewall/NAT#Source_NAT
You have to follow the instructions on your ac2 with the out-interface being your LAN interface. This will “hide” your WireGuard clients “behind” the local IP address of your ac2. The ac3 does not need to be aware of that.
Thank you for very good explanations of everything. I used masquarading. It works as you said it will.
If in the future i would need acces from my main router to one of the wireguard clients is there any good way to do this without braking this NAT rule? Or maybe use some different approach?
I was thinking more in a way of full port range to one client. But it’s not a problem if it isn’t possible. I will probably never use it in such way anyway. Thank you again for all your help.
