Wireguard performance???
Hi!
I got help with configuration of my Wireguard to the VPN provider Mullvad.
Which I am happy about....
But here is a (really) stupid question: Why does the performance increase 5-7 fold when I start and run the tool "torch"?
Yes, I am probably a novice on Mikrotik ....
Cheers,
Jonas D.
Your problem is fasttrack. Make sure the connections to your vpn are not fasttracked and you are fine.
Search the forum with that keyword, you should find enough information.
Great!
You made my day!!!
/JD
JODA58, can you please tell me what is you Mikrotik model and what is a CPU load during download of big file over Wireguard?
Hi!
I had a https://mikrotik.com/product/RBwAPG-5HacT2HnD-BE
BUT I am sorry to say that I can not answer your question… it died a few days ago.
Sorry,
Jonas D.
I was able to get about 140 Mbps download from Mullvad on my hEX. Judging by CPU load I guess this is it for now (on ROS 7.1). Didn’t use mangling for setup; utilising routing table instead.
