@anav
There is no need to apologize, and it would be foolish of me to ignore your advices after all the help you provided. And if there is better and more efficient way of configuring this than Mikrotik’s tutorial that is fine with me. Just like electronics… You can make circuit 100 different ways and it will work, but only few are correct ones, and efficient.
I hope you get better soon
So this is config at the moment, i didn’t make any changes to firewall rules yet as I don’t want to loose connection.
I presume that I have to remove from R1 this:
"Wireguard FWD GRAWE_VDC_HEINZELOVA -> URED" dst-address=192.168.1.0/24 \
src-address=192.168.25.0/24
"Wireguard FWD URED -> GRAWE_VDC_HEINZELOVA" dst-address=192.168.25.0/24 \
src-address=192.168.1.0/24
add action=accept chain=forward comment="Wireguard FWD FIDENS_LTE - > URED" \
dst-address=192.168.1.0/24 src-address=192.168.20.0/24
add action=accept chain=forward comment="Wireguard FWD URED -> FIDENS_LTE" \
dst-address=192.168.20.0/24 src-address=192.168.1.0/24
From R2 this:
"Wireguard FWD DECATHLON_VDC_ZADAR -> URED" dst-address=192.168.1.0/24 \
"Wireguard FWD URED -> DECATHLON_VDC_ZADAR" dst-address=192.168.25.0/24 \
And from R3 this:
add action=accept chain=forward comment="Wireguard FWD LTE -> Ured" \
add action=accept chain=forward comment="Wireguard Ured -> LTE" dst-address=\
If that is the case, why it’s added in tutorial ?
R1 - 192.168.1.0/24 - Office router
# jan/26/2022 06:36:59 by RouterOS 7.1.1
# software id = CD7M-66CD
# model = RB952Ui-5ac2nD
# serial number = **********
add admin-mac=**:**:**:**:**:** auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-g/n country=croatia disabled=no \
distance=indoors frequency=2472 installation=indoor mode=ap-bridge ssid=\
"Fidens 2.4G" wireless-protocol=802.11
set [ find default-name=wlan2 ] band=5ghz-a/n/ac channel-width=\
20/40/80mhz-XXXX country=croatia disabled=no distance=indoors frequency=\
auto installation=indoor mode=ap-bridge ssid="Fidens 5G" \
/interface wireguard
add listen-port=30700 mtu=1420 name=wg1
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=\
dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.1.1-192.168.1.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp interface=bridge name=defconf
/ppp profile
add local-address=192.168.89.1 name=VPN_Ured remote-address=vpn
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
add bridge=bridge comment=defconf ingress-filtering=no interface=ether2
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
/interface l2tp-server server
set authentication=mschap2 default-profile=VPN_Ured enabled=yes use-ipsec=\
required
/interface sstp-server server
set default-profile=default-encryption
/interface wireguard peers
add allowed-address=192.168.25.0/24,10.255.255.2/29 comment=\
GRAWE_VDC_HEINZELOVA endpoint-address=**********.sn.mynetname.net \
endpoint-port=30700 interface=wg1 persistent-keepalive=30s public-key=\
add allowed-address=192.168.20.0/24,10.255.255.3/29 comment=FIDENS_LTE \
endpoint-address=**********.sn.mynetname.net endpoint-port=30700 \
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
add address=10.255.255.1/29 comment=VPN interface=wg1 network=10.255.255.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=15m
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
established,related,untracked
add action=accept chain=input comment=Wireguard dst-port=30700 protocol=udp
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 \
ipsec-policy=in,ipsec protocol=udp
ipsec-policy=out,ipsec
add action=accept chain=input comment="allow ipsec-esp" protocol=ipsec-esp
invalid
in-interface-list=!LAN
connection-state=invalid
add action=dst-nat chain=dstnat comment="Port 21 za FTP server" dst-address=\
192.168.10.8 dst-port=21 in-interface=ether1 protocol=tcp to-addresses=\
192.168.1.39 to-ports=21
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
192.168.89.0/24
add action=dst-nat chain=dstnat disabled=yes dst-address=192.168.10.8 \
dst-port=4500 in-interface=ether1 protocol=udp to-addresses=192.168.1.6 \
to-ports=4500
/ip firewall service-port
set udplite ports=500
add dst-address=192.168.25.0/24 gateway=wg1
add dst-address=192.168.20.0/24 gateway=wg1
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ppp secret
add name="**********" profile=VPN_Ured service=l2tp
/system clock
set time-zone-name=Europe/Zagreb
/system ntp client
set enabled=yes
/system ntp client servers
add address=161.53.128.17
add address=45.87.77.15
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add comment=DECATHLON_VDC_ZADAR host=192.168.20.1 interval=5m
add comment=GRAWE_VDC_HENZELOVA host=192.168.25.1 interval=5m
R2 - 192.168.25.0/24 - LTE1
# jan/26/2022 06:39:09 by RouterOS 7.1.1
# software id = J61H-4XD4
# model = RBwAPR-2nD
/interface lte
set [ find ] allow-roaming=no band="" name=lte1
/interface wireless
set [ find default-name=wlan1 ] band=2ghz-b/g/n channel-width=20/40mhz-XX \
distance=indoors frequency=auto installation=outdoor mode=ap-bridge ssid=\
MikroTik-7FCF0A wireless-protocol=802.11
/interface lte apn
set [ find default=yes ] apn=******************** ip-type=ipv4 name=Telemach
add name=dhcp ranges=192.168.25.244-192.168.25.254
/ppp profile
add bridge=bridge comment=defconf ingress-filtering=no interface=ether1
/ip settings
/ipv6 settings
set use-ipsec=yes
add comment=defconf interface=lte1 list=WAN
add allowed-address=192.168.1.0/24,10.255.255.1/29 endpoint-address=\
************.sn.mynetname.net endpoint-port=30700 interface=wg1 \
add address=192.168.25.1/24 comment=defconf interface=bridge network=\
192.168.25.0
add address=10.255.255.2/29 comment=VPN interface=wg1 network=10.255.255.0
/ip cloud
add address=192.168.25.0/24 gateway=192.168.25.1 netmask=24
/ip dns static
add address=192.168.25.1 comment=defconf name=router.lan
add action=accept chain=input comment=WinBox dst-port=8291 in-interface=wg1 \
protocol=tcp src-address=192.168.1.20
invalid
192.168.89.0/24
add dst-address=192.168.1.0/24 gateway=wg1
/ip upnp
set enabled=yes
/ip upnp interfaces
add interface=lte1 type=external
/ppp secret
add name=vpn
/system clock
/system identity
set name=GRAWE_VDC_HEINZELOVA
/system leds
# using RSRP, modem-signal-threshold ignored
add interface=lte1 leds=led1 type=modem-signal
add interface=lte1 leds=led2 modem-signal-threshold=-71 type=modem-signal
add interface=lte1 leds=led3 modem-signal-threshold=-51 type=modem-signal
/tool mac-server
/tool netwatch
add comment=RUTER_URED host=192.168.1.1
R3 - 192.168.20.0/24 - LTE 3
# jan/26/2022 06:38:20 by RouterOS 7.1.1
# software id = P3N3-9GCJ
/interface lte
/interface lte apn
set [ find default=yes ] apn=***************** name=Telemach \
use-network-apn=no
add authentication-types=wpa-psk,wpa2-psk eap-methods="" group-ciphers=\
tkip,aes-ccm mode=dynamic-keys name=WPA/WPA2 supplicant-identity="" \
unicast-ciphers=tkip,aes-ccm
/interface wireless
distance=indoors frequency=auto mode=ap-bridge security-profile=WPA/WPA2 \
ssid=Fidens_Hotspot wireless-protocol=802.11 wps-mode=disabled
add name=dhcp ranges=192.168.20.248-192.168.20.254
add address-pool=dhcp interface=bridge lease-time=1d name=defconf
add allowed-address=192.168.1.0/24,10.255.255.1/32 endpoint-address=\
add address=192.168.20.1/24 comment=defconf interface=bridge network=\
192.168.20.0
add address=10.255.255.3/29 comment=VPN interface=wg1 network=10.255.255.0
/ip cloud
add address=192.168.20.0/24 comment=defconf dns-server=192.168.20.1 gateway=\
192.168.20.1
/ip dns static
add address=192.168.20.1 comment=defconf name=router.lan
add action=accept chain=input comment="Winbox " dst-port=8291 protocol=tcp \
invalid
/ip upnp
set enabled=yes
/ip upnp interfaces
/system clock
/system identity
set name=DECATHLON_VDC_ZADAR
/system leds
