Adding my private moons ID to clients in Windows PC and Linux, using the “zerotier-cli orbit” command followed by the two MOON_ID, works as expected, adding the moons to the peers list as attached image.
Question: in RouterOS 7.4, is there a way or a specific command to add private root servers ID, in order to the ZeroTier client to have and use them in the list of peers ?
Private Root Servers (aka moons) could possibly be implemented as a container services but I’m pretty sure MT won’t incorporate it as a standard package. You can host a private root service on your own server or on a cloud services.
IIRC, Mikrotik dont build the Zerotier package for Router Boards. Its done by Zerotier themselves… You might want to reach out to them on their twitter/mastodon accounts…
Well, if you pay MT or ZeroTier Inc enough, I’m pretty sure they’d be willing to look into the possibility of implementing a root server that could possibly fit inside a container. Otherwise, it’s up to you to fix it. Be aware that you won’t be able to use the standard ZeroTier apps and the administrative web interface using a private root server.
Anyway, back to @ROBPER original question. MT has most probably implemented the standard linux client using hardcoded settings specificallyfor the ZeroTier controllers thus needs to add a new interface to allow private ones.
