Cool. Can you also distribute this via caps/capsman?
I hope that it will be possible to do that with capsman but i believe that, at least in the beginning, some manual work will be required for MLO to work with capsman.
Ive tested it on a hap ax3 with cap ac cap.
It worked ![]()
Great, how did you do it? Under provision, I can only select a configuration, not a "network". How can I configure capsman to provision these settings?
Does Wi-Fi roaming work between those devices for you?
I’m currently using the hAP ac2 and cAP ac, and I plan to skip 'ax' and go straight to 'be'. Could you share the key CAPsMAN configuration?
Could you please add a short howto/tutorial under Case studies | RouterOS Manual? It is apparently not so self-explanatory how to use this menu and the labels (and in combination with capsman). Thanks
In 5GHz band, not all frequencies are allowed to use same EIRP / Tx power. And running different devices with different ROS versions might cause one of devices (e.g. the be one) to choose channel with low permitted Tx power. Example of such data (for an ETSI country) on wAP AX:
[admin@wAPG wap] /interface/wifi> /interface/wifi/radio/reg-info number=0 country=<ETSI country>
ranges: 2402-2482/20dBm/40MHz
5170-5250/23dBm/160MHz/indoor
5250-5330/23dBm/160MHz/indoor/dfs
5490-5730/30dBm/160MHz/dfs
5735-5875/14dBm/80MHz
Note the frequency range between 5735 and 5875 MHz with EIRP limited to 14dBm which is pretty lot less than 30dBm for range between 5490 and 5730 MHz.
Another reason for lower range is use of wider channels ... since EIRP is limited, using twice as wide channels means dispersing allowed Tx power over twice the spectrum ... meaning half the power (or -3dB in logarithmic scale) per Hertz ... and it's power per Hertz which defines range. And it's the power per Hertz (on receiving side) which defines SINR and hence bits per Hertz ... and in a bad case that means that throughput when using wider channels can be lower than if using narrower channels (and that happens in marginal radio conditions ... away from transmitter). I'm pretty sure that it's the same even for stations which don't support wide channels if AP is configured to use wide channels ... I somehow doubt that WiFi radio is smart enough to vary Tx power amplifications for every radio frame transmitted depending on actually used channel width, perhaps (advanced?) WiFi7 radios can do that. I'd be interested if someone can point me to some trustworthy information about this.
Yep, the 14 (or 13) dBm is the actual ETSI limit for 5735-5785 (channels 149-173).
I was recently "bitten" by that (on another make AP set to "auto") hence, I tried to make some clear schemes:
Wi-Fi channels cheatsheet
In a nutshell, we only have a very limited number of "free" or "almost free" channels with a "reasonable" allowed power AND NOT the 10 minutes CAC that - depending on the specific location - might be a nightmare.
It also doesn't help that the new devices have a minimal channel width and a fixed channel grid of 20 MHz...
Just setup a network config.
Ignore everything else. No need for provisioning rules.
Make sure your network config is enabled.
I'm using static cap interfaces and it picked it up right away. I actually didn't expect that ![]()
It's already in the manual, but it's as easy as:
/int/wifi/disable [find]
/int/wifi/network/add ssid=HomeWifi .passphrase=password
all 2ghz, 5ghz, 6ghz etc will be correctly set up
Thank you. I tried it and it works for me with capsman, even when the CAP is not on 7.24rc firmware, but on older versions without the network setting (e.g. long-term release 7.21.5).
Probably the country setting should be added with
/interface/wifi/network/radio add configuration.country=Country
Pretty easy overall.
But what is then the provision action use-network-config used for? I already asked that over here, V7.22rc [testing] is released! - #111 by infabo, but no answer.
I disabled the provisioning rules completely. Just enable capsman, set network config and radio options, and it will work.
I understood that. But this is very little control, when this magic wand automatically provisions all connected caps.
Have tried combinations of this, including the higher permitted power range for UK in 5Ghz.
Still feels to me the range on 802.11ax is not as good as the AX3.
I tried a 802.11be device too, no improvement to signal but I did not expect that.
Fingers crossed it's in software and that we see improvements
It would be better to compare it with ax2, since both ax2 and be3 have built-in antennas.
I am also trying to get my head around it how this is supposed to be working.
So all of a sudden capsman is not needed anymore ?
Or did I misunderstand ?
My best guess is, by using e.g. /interface/wifi/provision/add action=use-network-config identity-regex=foo get around the "auto magic" and regain some control.
its still capsman but "more simple ™️"
The use case I see for now is SOHO setups.
Just set up an SSID, Password and WPA Type and connect all your caps. Done.
The important fact here is that the interface has to be disabled first for the "network" config to pick it up.
