Combination of a lot of things - getting guests network working
Hi, I am rather new here, so apologies if i post in wrong category.
I have a RB4011, and need to setup a guest network to work with my unifi access point.
at this stage i have :
Address Lists:
address - description - interface
172.16.10.2/24 - internal lan - ether2 (LAN)
172.16.180.1/24 - Guest network - vlan180
Firewall:
srcnat 172.16.180.0/24 masquerade
filter rules:
fasttrack connection
accept input udp 53 ether2
accept input udp 53 vlan180
accept input tcp 53 vlan180
(I heard that these 2 rules will prevent the 2 seeing eachother, but that was without vlans)
drop forward src:172.16.10.0/24 dst:172.16.180.0/24
drop forward src:172.16.180.0/24 dst:172.16.10.0/24
INTERFACE:
ether1 (fibre) connected to tp link router for internet
ether2 (LAN) rest of my lan devices, computers, laptops etc
on ether2 we also have a unifi ap managed by a unifi controller
vlan180 - ideally all guests should use this network or vlan
i managed to get my unifi access point guests to work and get dhcp addresses on the 172.16.180.0/24 network.
i added 8.8.8.8 and 1.1.1.1 as DNS servers in the DHCP somewhere, but no dns queries on the guest network is working…
somewhere i have to allow dns queries from the vlan180, or remove vlan180 completely, and somehow seperate these 2 networks using the mikrotik
i have a basic tp-link archer6 router where my internet is connected to - 172.16.10.1, it has some vlan features, but i think its a little primitive for the mikrotik.
could someone please help me through this setup?i mostly use winbox for configurations at this point.
Hi, welcom on the forum.
Please export your configuration with CLI, remowe sensitive data and show it to us.
Diagram of your current/planned network could also be helpful.
/export file=anynameyouwish
Right here goes an attempt, i dearly hope i have removed all sensitive info :slight_smile:
# 2025-07-01 10:33:37 by RouterOS 7.17.1
# software id = 8TNG-A64A
# model = RB4011iGS+
# serial number = HHD****
add name=containers
set [ find default-name=ether1 ] loop-protect=on name="ether1 (FIBRE)" \
    rx-flow-control=on tx-flow-control=on
set [ find default-name=ether2 ] loop-protect=on name="ether2 (LAN)" \
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] name="ether10 (WIFI)"
/interface pppoe-client
add add-default-route=yes interface="ether1 (FIBRE)" name="AXXESS 50/50" \
    use-peer-dns=yes user=###
/interface veth
add address=172.17.0.20/24 gateway=172.17.0.1 gateway6="" name=veth1-adguard
/interface wireguard
add disabled=yes listen-port=13280 mtu=1420 name=COETZEE-VPN
add listen-port=13233 mtu=1420 name="To Mindspring Office"
/interface vlan
add interface="ether2 (LAN)" loop-protect=on name=vlan180 vlan-id=180
add name=LAN ranges=172.16.10.101-172.16.10.240
add name=Guest_Pool ranges=172.16.180.88-172.16.180.240
add add-arp=yes address-pool=Guest_Pool interface=vlan180 lease-time=\
    6d7h18m15s name=GUEST_DHCP
/port
set 0 name=serial0
set 1 name=serial1
/container
add envlist=base_envs interface=veth1-adguard logging=yes start-on-boot=yes \
    workdir=/opt/adguardhome/work
/container config
set registry-url=https://registry-1.docker.io
/container envs
add key=TZ name=base_envs value=Africa/Johannesburg
add bridge=containers interface=veth1-adguard
/interface detect-internet
set detect-interface-list=all internet-interface-list=all lan-interface-list=\
    all wan-interface-list=all
/interface wireguard peers
add allowed-address=10.254.10.0/30,192.168.100.0/23 endpoint-address=\
    #####.#####.co.za endpoint-port=13233 interface="To ###### Office" \
    name="##### Office" public-key=\
add allowed-address=10.71.80.10/32 disabled=yes interface=##############-VPN name=\
    #### public-key="###############"
add address=172.16.10.2/24 interface="ether2 (LAN)" network=172.16.10.0
add address=172.17.0.1/24 interface=containers network=172.17.0.0
add address=10.254.10.2/30 interface="To ###### Office" network=\
    10.254.10.0
add address=172.16.180.1 interface=vlan180 network=172.16.180.0
add address=172.16.10.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=172.16.10.1 \
    netmask=24
add address=172.16.180.0/24 dns-server=8.8.8.8,1.1.1.1 gateway=172.16.180.1 \
    netmask=24
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
add action=fasttrack-connection chain=forward hw-offload=yes
add action=accept chain=input in-interface="ether2 (LAN)"
add action=accept chain=input dst-port=53 in-interface=vlan180 protocol=udp
add action=accept chain=input dst-port=53 in-interface=vlan180 protocol=tcp
add action=drop chain=forward dst-address=172.16.180.0/24 src-address=\
    172.16.10.0/24
add action=drop chain=forward dst-address=172.16.10.0/24 src-address=\
    172.16.180.0/24
    "Accept FORWARDED established and related packets" connection-state=\
    established,related
add action=accept chain=forward dst-port=53 protocol=udp
    "Accept all packets from Local Network (172.16.10.x) Mikrotik Port 2" \
add action=accept chain=input comment="Allow WireGuard" dst-port=13233 log=\
    yes log-prefix=WG-Input protocol=udp
add action=accept chain=input comment="Allow WireGuard" dst-port=13280 log=\
add action=accept chain=input in-interface="To ########## Office" protocol=\
    icmp
add action=drop chain=input comment="Drop invalid packets" connection-state=\
    invalid disabled=yes
add action=masquerade chain=srcnat src-address=172.17.0.0/24
add action=masquerade chain=srcnat src-address=172.16.10.0/24
add action=masquerade chain=srcnat src-address=10.71.80.0/24
add action=masquerade chain=srcnat src-address=172.16.180.0/24
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=172.16.10.1 \
    routing-table=main scope=30 suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=192.168.100.0/24 gateway=10.254.10.1 \
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set winbox address=172.16.10.0/24,192.168.100.0/24,10.254.10.0/24
set api-ssl disabled=yes
/system clock
set time-zone-name=Africa/Johannesburg
/system identity
set name=##########-MikroTik4011
/system note
set show-at-login=no
/system package update
set channel=testing
/system routerboard settings
set enter-setup-on=delete-key
Please use proper tags for code, the “< / >” button in the edit window.
so sorry, took me a whole 10min now to find that button, then saw there is a very tiny + button on the edit menu
assuming you allready edited it into that preformated text thing, thank you.
and apologies
Not at all my field of (little) experience, but if I were you I would start with a default Mikrotik set of firewall settings (and build if needed upon it) as per Rule #8:
optionally adding at the end of the forward chain the allowed things and closing it with a “drop all else” rule.
If you look around on the board you will find many examples of this latter modification, default firewall (for SoHo devices) is here:
In any case it is good practice (for readability, for the helping forum members, but also for you in the future) to group firewall filter rules by chain, rules are applied in top to bottom order within a same chain, it won’t change anything in the functions performed, but it is much more readable if you have first all input rules, then all forward rules, etc.
I am 100% sure that is where i started.
resetted the device a few times, removed all default everything, started from scratch.
I am still battling to remember the difference between input, forward and output, logically to me it does not make sense.
Did not know you can group filter rules in the mikrotik, and it does not affect the function or application order, as if i understand you correctly, it solely applies filter rules from top to bottom.
for now i am just trying to get things working, and then afterwards can sit en neaten it up and group things nicely.
The possible issue when - without enough experience/knowledge - a new user fiddles with firewall rules is that he can (accidentally) leave some big holes in it, hence the suggestion to start from a solid base instead from nothing.
This should help:
and should it also make you understand why rules are processed in the order they appear on each chain separately. (the grouping is only advised for readability, it doesn’t change anything in how the rules are applied).
A full example is here:
Thank you for all your suggestions, but i honestly do not have the time or effort to learn the flow chart, or study 1000 things. All i wanted was to get the guest network working, seperated from my normal lan.
i’ll find another router where the learning curve (requirement) is not so immense.
honestly, if i came here asking for advise on how to secure my mikrotik router i would undrstand, but that is not my question or reason for asking anything on the forum.
I am still in need of some help here to get the guest network DNS access, or allow DNS queries over my default router at 172.16.10.1
the details/specifics and added security, and best practices i’ll worry about later, for now i just need to get it working so that i can understand things.
Right, so I managed to get it working, no thanks to anyone on this forum…
for the other people like me, that dont know, here is my working config
created a vlan, added vlan to the lanbridge, added dhcp to vlan, added some firewall rules to ensure the guests network cant access the normal lan and visa versa
still need to connect a laptop to see if i can bypass any measures in place though. but very happy that it works 100%
# 2025-08-04 08:24:55 by RouterOS 7.19.3
# serial number = ######
add name=LAN-BRIDGE
add name=containers
set [ find default-name=ether3 ] name="ether3(WIFI_TRUNK)"
set [ find default-name=ether10 ] disabled=yes loop-protect=on name=\
    "ether10 " poe-out=off rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus1 ] disabled=yes
    use-peer-dns=yes user=######
/interface veth
add listen-port=13233 mtu=1420 name="######"
/interface vlan
add interface=LAN-BRIDGE loop-protect=on name=vlan180_guest vlan-id=180
add name=DHCP_GUEST ranges=172.16.180.80-172.16.180.254
add add-arp=yes address-pool=DHCP_GUEST interface=vlan180_guest lease-time=\
    17h30m name=Guest_DHCP
/port
set 0 name=serial0
set 1 name=serial1
/certificate settings
set builtin-trust-anchors=not-trusted
/container
add envlist=base_envs interface=veth1-adguard logging=yes name=\
    e996620b-c1d9-4ec7-89dd-02a06f24601a root-dir=\
    e996620b-c1d9-4ec7-89dd-02a06f24601a start-on-boot=yes workdir=\
/container config
/container envs
add bridge=LAN-BRIDGE interface="ether3(WIFI_TRUNK)" trusted=yes
add bridge=LAN-BRIDGE interface="ether2 (LAN)" trusted=yes
add bridge=LAN-BRIDGE interface=ether4 trusted=yes
add allowed-address=######,###### endpoint-address=\
    ###### endpoint-port=13233 interface="######" \
    name="######" public-key=\
add address=###### interface="######" network=\
add address=172.16.180.1/24 interface=vlan180_guest network=172.16.180.0
add address=172.16.180.0/24 gateway=172.16.180.1
add action=accept chain=input comment="Allow DHCP for Guest VLAN" dst-port=\
    67,68 in-interface=vlan180_guest protocol=udp
add action=accept chain=input in-interface="######" protocol=\
    icmp
    established,related
add action=accept chain=forward comment="Allow Guest to UniFi Controller" \
    dst-address-list=###### dst-port=8443 protocol=tcp src-address=\
    172.16.180.0/24
add action=accept chain=forward comment="Allow Guest DNS UDP" dst-port=53 \
    protocol=udp src-address=172.16.180.0/24
add action=accept chain=forward comment="Allow Guest DNS TCP" dst-port=53 \
    protocol=tcp src-address=172.16.180.0/24
add action=accept chain=forward comment="Allow Guest HTTP/S for portal" \
    dst-port=80,443 protocol=tcp src-address=172.16.180.0/24
add action=accept chain=forward comment="Allow Guest Internet Access" \
add action=drop chain=forward comment="Block Guest to Main LAN" dst-address=\
    172.16.10.0/24 src-address=172.16.180.0/24
add action=drop chain=forward comment="Block Main LAN to Guest" dst-address=\
    172.16.180.0/24 src-address=172.16.10.0/24
add action=masquerade chain=srcnat comment="General Internet NAT via TP-Link" \
    out-interface=LAN-BRIDGE src-address=172.16.0.0/16
add disabled=no distance=1 dst-address=###### gateway=###### \
/ip service
set winbox address=######,######,######
/system clock
/system identity
set name=######
/tool sniffer
set filter-interface=vlan180_guest filter-port=bootps
Nice to here that your configuration works.
Please remember that it’s a MT’s users’ forum where people like you and us try to share their problems/solutions and help each other if only we can. We do not have same configurations, equipments or possibilities to test MT against TP-Link, D-Link, CISCO, Unifi etc. brands and their caveats/tricks. You should remeber that it’s our time we share for free … why? It’s a good question.
