Connecting to multiple devices with same IP-address
Hello
Im completely new to MikroTik’s and networking in general. I’ve searched the forum, but need something of a clear answer.
My problem is, that i have 4 identical indsutrial machines which have the exact same IP-addresses. The addresses is like:
192.168.0.2
192.168.0.20
192.168.0.90
I need to accsess all four machine from a SCADA server, with the IP of 172.168.0.1.
Is it possible to connect machine 1 to port 1 on the router, machine 2 on port 2 and so on - and after that use NAT to translate the ip addresses like this:
Machine 1 internal ip : 192.168.0.2 on port 1 - external address: 172.168.0.10
Machine 2 internal ip : 192.168.0.2 on port 2 - external address: 172.168.0.20
… and so on.
The first thing i am worried about ip-conflicts, but hope it is possible to isolate the ports in som way.
I cannot change the IP-adresses of each machine.
The router im going to use is MikroTik RB2011UiAS-RM Router.
Check these for some ideas:
http://forum.mikrotik.com/t/port-to-interfacing/97096/1
http://forum.mikrotik.com/t/how-to-allow-two-devices-with-same-ip-access-internet/115990/1
Thank you Sob. I am not sure how to implement it at my project, but i will keep looking. Thanks again.
You didn’t choose exactly easy thing to start with. If I take the first example, with your addresses it should be:
add address=172.168.0.10/24 interface=ether1
add address=172.168.0.20/24 interface=ether1
add address=192.168.0.1 interface=ether2
add address=192.168.0.1 interface=ether3
/ip firewall mangle
add action=mark-connection chain=prerouting dst-address=172.168.0.10 new-connection-mark=port1
add action=mark-connection chain=prerouting dst-address=172.168.0.20 new-connection-mark=port2
add action=mark-routing chain=prerouting connection-mark=port1 new-routing-mark=port1 passthrough=no
add action=mark-routing chain=prerouting connection-mark=port2 new-routing-mark=port2 passthrough=no
add action=dst-nat chain=netmap dst-address=172.168.0.10 to-addresses=192.168.0.2
add action=dst-nat chain=netmap dst-address=172.168.0.20 to-addresses=192.168.0.2
add action=masquerade chain=srcnat out-interface=ether2
add action=masquerade chain=srcnat out-interface=ether3
add dst-address=192.168.0.0/24 gateway=ether2 routing-mark=port1
add dst-address=192.168.0.0/24 gateway=ether3 routing-mark=port2
Where ether1 is where you have the server and ether2-x is for those machines with fixed addresses.
And btw, 172.168.x.x are public addresses that you shouldn’t be using in LAN. Private range is only 172.16.0.0/12, i.e. 172.16-31.x.x.
