Feature Request: OpenVPN DCO (Data Channel Offloading)
Please Mikrotik, consider implementing DCO for OpenVPN if it is not too difficult. it very significantly improves (3-4x or even more) the performance of OpenVPN, lowers latency and and CPU load, even when low power devices are used as access servers.
Are you a twin of @mahdaviyousefiamir as you use exactly the same words
Wow! Thanks to you I found my long lost twin! :joy:
