ttrs
May 19, 2023, 8:50pm
1
Hi.
Hap ax2 7.8 everything works fine.
Upgraded to 7.9 and all clients cannot connect to wifi.
Did experiments with auth types, PMKID, rebooted. Nothing helped.
Downgraded to 7.8 and everything works fine again.
Am I missing something or its a bug in 7.9?
# may/19/2023 22:29:12 by RouterOS 7.9
add admin-mac=48:A9:8A:7F:5A:21 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] poe-out=off
/interface wifiwave2
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.mode=ap .ssid=MikroTik-7F5A25 \
security.authentication-types=wpa2-psk,wpa3-psk .disable-pmkid=yes
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=all \
.width=20/40mhz comment="comment1" configuration.country=\
Germany .mode=ap .ssid=mywifi .tx-power=19 disabled=no \
security.authentication-types=wpa2-psk,wpa3-psk .disable-pmkid=yes \
.encryption="" .management-protection=allowed .wps=disable
add comment=defconf name=WAN
add comment=defconf name=LAN
add comment=192.168.99.32/27 name=default-dhcp ranges=\
192.168.99.33-192.168.99.62
add address-pool=default-dhcp interface=bridge lease-time=1d name=defconf
/port
set 0 name=serial0
/queue simple
add max-limit=6M/25M name="Limited clients" target=192.168.99.32/27
/routing table
add disabled=no fib name=vpnz
add bridge=bridge comment=defconf interface=wifi1
add bridge=bridge comment=defconf interface=wifi2
set generic-timeout=2m tcp-established-timeout=1h
set discover-interface-list=all lldp-med-net-policy-vlan=1
/ip settings
set allow-fast-path=no
/ipv6 settings
set disable-ipv6=yes max-neighbor-entries=15360
add address=192.168.99.1/26 comment=defconf interface=bridge network=\
192.168.99.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=10m
/ip dhcp-client
add comment=defconf default-route-distance=2 interface=ether1 use-peer-dns=no \
use-peer-ntp=no
add address=192.168.99.0/26 comment=defconf dns-server=192.168.99.1 gateway=\
192.168.99.1 netmask=26 ntp-server=192.168.99.1
set allow-remote-requests=yes cache-max-ttl=6m servers=\
1.1.1.1,1.0.0.1
established,related,untracked
invalid
add action=drop chain=input comment="!!!! - disabled to log in from WAN defcon\
f: drop all not coming from LAN" disabled=yes in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid dst-address=!192.168.19.0/26 log-prefix=\
drop_invalid
connection-state=new in-interface-list=WAN log=yes log-prefix=\
drop_forward
ipsec-policy=out,none out-interface=ether1
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=APRR
/system note
set note="APRR "
/system ntp client
set enabled=yes
/system ntp server
set enabled=yes manycast=yes use-local-clock=yes
/system ntp client servers
add address=0.de.pool.ntp.org
add address=1.de.pool.ntp.org
add address=2.de.pool.ntp.org
add address=3.de.pool.ntp.org
Disable wpa3, wpa2 only. and it might start working ( for most it does, it did for me).
Should be solved in 7.10b5.
Try 7.10b5 then, it should be much more stable
ttrs
May 26, 2023, 7:54am
5
I hope Mirkotiks team is aware if this issue. Will wait for 7.10 stable
This isnt a widespread issue and i believe it might be something on your end.
Anyways:
WHY??? please properly setup VPN and reenable this now
mazel
May 29, 2023, 11:28am
8
Hi.
/port
set 0 name=serial0
/queue simple
/routing table
/ip settings
/ipv6 settings
192.168.99.0
/ip cloud
/ip dhcp-client
use-peer-ntp=no
1.1.1.1,1.0.0.1
invalid
drop_invalid
drop_forward
invalid
icmpv6
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
ipsec-ah
ipsec-esp
!LAN
/system clock
/system identity
set name=APRR
/system note
set note="APRR "
/system ntp client
set enabled=yes
/system ntp server
I had the same behaviour after upgrade from ROS 7.8 to 7.9 (as you can see in my topic http://forum.mikrotik.com/t/wireless-clients-not-connecting-after-upgrade-to-7-9-hap-ax2/166453/1 However, after I managed my configuration to work with ROS 7.9, I experienced issues with signal stability and strength even when all devices remained in same distance from router as for ROS 7.8. I guess that ROS 7.9 have some combination of SW+HW issues with hAP ax2. Now, I am running 7.10beta8 on my ax2 and it seems that this version is the most stable since my first hAP ax2 setup (from 7.6 to 7.9, the 7.10beta8 is the most stable version with good performance). Please, try upgrading to 7.10beta8.
ttrs
May 29, 2023, 12:08pm
9
Thanks for the info. In my case there is no capsman. I will wait for the 7.10 release and try it.
What are the results of
/sys routerboard print
on terminal?
mazel
May 30, 2023, 6:38am
11
I do not have capsman neither (I have ax2 standalone) - I had bad vlan configuration that worked until 7.8. However, I think that ROS 7.10 stable release will not have all the fixes that 7.10beta8 has - so I am not sure that 7.10 stable will solve that type of issue. I do not know why but for my unit,it seems that beta versions are more stable (wifi signal) than stable ones.
… However, I think that ROS 7.10 stable release will not have all the fixes that 7.10beta8 has - so I am not sure that 7.10 stable will solve that type of issue. I do not know why but for my unit,it seems that beta versions are more stable (wifi signal) than stable ones.
And why do you think that ? That’s the whole point of a stable release, to include all fixes which were in beta for that same version.
mazel
May 30, 2023, 8:20am
14
Because of my experience that I have since I bought hAP ax2. I do not know why but beta versions works far better then stable releases for me, I do not know why. Also, when I briefly looked yesterday at release notes for 7.10beta and 7.10rc, I think I missed some fixes for rc.
No offense but in this context “I think” is not good enough.
Either you know or you don’t.
If you know, make a comment of it in the 7.10rc thread so MT staff can respond.
mazel
May 30, 2023, 12:31pm
16
“I think” is good enough as I am expressing my experience and my thoughts. As I mentioned I looked to release notes briefly so that means that 7.10rc might have all fixes from latest 7.10beta but I just overlook in list. So If I would know for 100%, I would not use words “I think” and I would write a comment (since I was not 100% sure, I used words “I think” which suits my expression good enough).
On the other hand, I had issues with wireless client connectivity with ROS 7.9 as many users on forum (as far as I can see many topics mentioning 7.9 and wireless issues) so MT staff knows about that (in my opinion). Although, as I mentioned before, my particular unit seems to be working better with beta versions than stable versions (from my knowledge beta version does not equal to stable release), so from that point of view I said that my unit works better with beta than stable - also I do not know the origin of issue with wifi stability and signal strength so I cannot report what it might be causing as antennas are HW and ROS is SW, so it might be not only SW related but SW+HW related issue (with my particular unit).
Also, I would like you (and me) to stop all this conversation in this point as it does not even matches the topic. Also, topic author wrote that he will wait until 7.10 stable release as 7.10beta8 seems to be working (with my unit) better than 7.9.
ttrs
July 2, 2023, 8:19am
17
Hi. Upgraded to 7.10.1.
The wifi works good, the clients are connected.
WIll wait for few days to monitor how stable it is over time.
3a4oT
August 3, 2023, 11:10am
18
Hap ax2 or better to say ROS 7.x on it, is unstable. I’m on 7.10.2 only 5 Ghz works, 2.4Ghz can’t connect. Tried to set up CapsMan, but wifewave2 is a nightmare. Not recommended to buy and recommendation for Microtik to make a truly stable release before selling hardware.
I am not so sure about that statement.
That lower SSID is 2.4GHz channel.
There have been quite some bugs, true, but most of the times it’s a config problem.
And Mikrotik is pretty fast in releasing bug fixes and new versions.
So …
Do you mind to put your config on the table so we can have a look ?
Terminal:
/export file=anynameyouwish
Review export for serial, passwords and public wan ip (put something else in there so we know there was something).
Then post between [ code ] quotes for easier readibility.
It might also help to make a drawing of your network, which device is connected how to where.
You have only ax2 ? Why are you setting up CAPsMAN in that case ? Do you have any other AP that you plan to use ?
Like@holvoetn said, there was some bugs but Mikrotik was really fast in solving that issue, try 7.11rc1 version
