Hex E50UG
more question how they will fix it, if forced changes, restrictions on port 1 which can subsequently affect some other work, then will this be described in detail or we will simply not get any detailed answers.
on the other hand, I admit that if the problem is with the hardware, then the router can remain as is, with all the advantages and disadvantages, as a product already on sale. the home router market knows many such examples. on the other hand, the time and lifespan of Mikrotik routers is several times longer than other home routers and it is difficult for me to imagine how it will exist further, unless it is soon replaced by revision 2, for example.
But if they find hardware bug how they wanna repair ??
Change to ver2.0 but how ? send to reseler ?
@lurker888
My ONT refuses to link at 100Mb, seems like they have upstream ports set to 1Gb auto-negotiation only.
@lurker888
If at some point I feel like tinkering with this thing again (and assuming MT doesn’t provide a resolution beforehand), I might try this.
Honestly, though, this hex refresh product is defective - and I am running out of patience to try and “work around” whatever it is. If it was not defective, there would not be this many people with identical complaints, starting immediately after release and continuing even until now (that reddit thread is five months old), regarding the ether1 port.
I’m glad I only bought one of these.
U are lucky- i buy 2 of them and same isue with eth1 .
I have on ether 1:
Vlan for pppoe connection to isp with pppoe client
Vlan for home network, all on same port.
I can max internet connection 800/600 mbit with cca 40% cpu usage.
Yes, you are one of the lucky ones where E50UG magically has no problem.
This is MT Achilles’ heel and it has burned me before. I bought first run of original hex-s. PoE output port was busted, not always work after reboot. Open MT ticket, find out “first run” of hex-s has faulty PoE, support told me “sorry, we refuse to help go bug reseller”. Call reseller, they also refuse since I had device more than 30 days, do nothing for me, basically told me kick rocks/pound sand…
EDIT: I keep receipts: http://forum.mikrotik.com/t/hexs-rb760igs-inconsistent-poe-output-after-reboot/140648/1 SUP-21204
So after all that, MT has my money, and I’m left with admittedly (by them) faulty device, no recourse, my money down toilet.
Same thing again? I hope not…
Moral of the story “Don’t buy brand new hw”?
Or perhaps moral of story “Buy from company that supports and stands behind what their own product, and not dump responsibility on reseller for faulty product not made by reseller” ?
Or maybe “immediately return product ASAP to reseller, don’t wait for weeks of troubleshooting, before you are stuck with bad device and out whatever money spent” ? And good luck trying to convince reseller to give money back..
This is the least intelligent thing that has been posted in this thread. Give me a break.
Maybe they can assist to make MT change their standpoint?
https://www.eccnet.eu/
Well thank you
It is “funny” and playful, in this all but optimal customer experience.
But one does need some intelligence to see that … oh well, not everybody will… :laughing:
Based on the screenshots you shared from the support ticket, it doesn’t look like MikroTik support said, “sorry, we refuse to help go bug reseller” What they told you is the usual process: warranty claims (RMA) should be handled by the reseller where you bought the device, since that’s your contract partner.
You mentioned, “Call reseller, they also refuse since I had device more than 30 days, do nothing for me, basically told me kick rocks/pound sand…” — and that seems to be the core issue here. It’s really important to choose your reseller carefully. I personally only buy from official MikroTik distributors. It’s disappointing to hear that a seller would refuse a warranty return. That’s not just bad service — in the EU, it’s actually against the law. If the product is under warranty and all conditions are met, the seller is required to process the warranty claim.
Infabo,
My old hex-s was purchased from an authorized reseller. Reseller contacted MikroTik within my same support ticket to ask them if they were sending replacement. They did not. Device was faulty, MikroTik knew it was (since they fixed later revision, quite obviously from looking at the newer board) and left me with known broken device, no help at all.
The point is - I hope this is not same situation again, and again I’m stuck with bad design. Just like my hex-s; that router mostly “worked” but had known flaw with PoE, and I am stuck with it - they did not help me at all. Am I stuck again with faulty ether1 port, no help, sorry maybe shouldn’t have purchased without being psychic and somehow knowing port 1 not work right ??
To sebastia’s joking point – should we all start waiting a year before buying new release device, so they can fix initial busted designs??
Well, once upon a time it was common advice to not buy a first version of a new car, but wait one year or so for the second version.
Running on the edge of latest technology has some risks…
With electronic devices the risks are much less (not that many moving parts) but still there can be issues that slip through the tests, or come out on early production batches only once they are already in the hands of customers.
So, wait one year?
Naah, speaking of home/non-professional users and at least for inexpensive devices like the Hex or Hex S we are talking of 50-60 bucks, if something goes wrong (as in this case) you can have a couple pizzas out less and make even or accept that you have overpaid a nice 4 port switch that you can re-use somewhere else.
A professional buying hundreds of these for his customers before thoroughly testing them?
Well, that would be - let’s say - unfortunate.
To clarify, your device was over the 2 year warranty period, this is why the seller refused to change it, right? At least it looks like that from the ticket
To clarify, my previous issue is not with the warranty. My old hex-s did not “fail” in a manner after purchase soon after purchase which would cause me to say “oh let me return to seller”. It had defect from factory which was not readily apparent. Upon discovering defect down the line, the issue is MikroTik dumping responsibility for said defect onto reseller, making it their problem, and telling me the answer is “buy more”. Or “try again, hopefully you are lucky and don’t get old stock?”
EDIT: Would prefer company that says “Oh, we know serial numbers from X to Y have this bad problem. We should notify resellers and deal with it properly.” And not “sweep problem under rug and hope no one notices. And if they do, too bad for them.”
Anyway, my old hex-s is off topic, and hopefully that experience is not repeated here. That’s all.
I suggest releasing a set of fixes for hEX, a new sticker for the front panel :slight_smile:
HAHAHA… touche, and within the realm of possibility!!
Someone have any answer for ticket or replay from support Mikroitk ? Im waiting 14 days and nothing…
