Hex E50UG
We have a saying: patience and tobacco!
Let me clear the air a little here as well. I was really excited to use this new hEX refresh; I own seven or eight MikroTik routers personally and am responsible for deploying 100+ (mostly good and reliable original Hex RB750Gr3!) in my line of work. I was also really excited to see new hEX-S, except not so much if it has the same problem the E50UG does.
When MikroTik routers work right and are “suited for purpose”, I think they are wonderful devices and I do enjoy using them. I simply wish that MikroTik, as a company, handled various aspects of their support and warranty processes… better.
I truly hope a valid and proper solution for this problem can be found.
Szczepan, to your question, my case has not been touched since I answered them about trying port 2.
I got this answer from the support service,
You will be notified, via our ticket system, when the fix is ​​on the horizon.
Hopefully, it will fix the behavior for you as well.
Best Regards,
waiting..
as a device, the Mikrotik hEX (E50UG), with its price and performance - I like it. but I have taken it out of service for now, I think that if all the problems are solved, then in the future I will be happy to use it.
The saga continues, on hEX S refresh.
http://forum.mikrotik.com/t/upgrade-from-rb750gr3-to-hex-s-2025-e60iugs/184158/1
Hi
it’s been more than a week now… no new thoughts here?
I can’t believe Mikrotik treats this as a correct behaviour of the new hEX S and E50UG…
I was also so happy to see the new arm based hEX, and now do not know what to think.
Regards
Piotr
They say - Work at solution ASAP.
So we must wait … or buy something new.
I just loaded the 7.20Beta7 from the testing branch and it fixes the problems with WAN being on ether1. I'm not recommending that you do the same, I'm willing to take some risks. I am having a problem with watching BritBox, when I'm streaming a program it crashes the router. I'm guessing that the packet buffer is being swamped, not sure, yet, still checking.
Thanks. So still waiting for stab version.
But try beta at homlab.
You can put WAN on whatever port but that beta does indeed fix the performance of ether1.
I've done tests with that device since the fix came out in 7.20beta5.
As full managed switch (VLAN on all ports), ether 1 reaches Gb speeds.
Using ether 1 as WAN in default router config results in 900 for download, 840 up.
So I was just testing Britbox, and the router isn't crashing. Unfortunately I made two changes before testing, I turned FastTrack off and Changed the ether1 L2MTU from 1600 to 1596 so it matches all the other L2MTUs. I'm thinking that the L2MTU might be the culprit. But it works.
I would like to know what MT changed in the code to make this work.
I dont think it would be any kind of trade secret and transparancy is the best policy.
I have an ISP link of 700/350mb with PPPoE, my bandwidth tests were around 420/200mb.
I had reset the configuration without the default, configured the router using Quick Set and set the Fasttrack rules. Now I'm using the full speed of my link, but it isn't constant (sometimes the bandwidth test doesn't achieve the maximum speed even using fast.com, speed.cloudflare.com or speedtest.net)
I'm using RouterOS 7.19.4 (stable).
I've heard (fron non-MT sources, and I haven't confirmed myself) that it is related to a power saving feature of the mac not working "optimally."
@lurker888 Interesting, that is something I'd not yet considered, and may explain why (in cases like mine) inserting a dumb switch in front of the E50UG/hex refresh, between it and my provider's ONT handoff, "magically" fixes the problem.
That is, if this is some EEE/802.3az bug baked into the silicon or driver for the built-in PHY of EN7562, and putting a switch in front of the router that does not negotiate 802.3az with it conveniently side-steps the problem?
Shame on MikroTik for not providing a toggle or indicator for 802.3az in their devices, it would make confirming whether or not it has anything to do with my problem a lot easier...
There have been other threads also asking for this, e.g. EEE on Mikrotik. Oh well.
Extra edit: Aside from this E50UG problem,I have several professional use cases for MikroTik switches but simply cannot use them at all because I cannot control EEE and their igmp querier stupidly only runs untagged (i.e. no VLANs) .
I decided to revisit this today, using 7.20rc1 on the E50UG hex refresh. Have some odd/interesting results to report.
Using factory default settings, I get the same results as before in my setup, 1-12 Mbps at most when uploading to gpon/FiOS WAN using ether1.
What's interesting is if I stop using only-hardware-queue on ether1 and assign a cake queue to the interface using queue trees instead, my E50UG upload jumps up to 100-125 Mbps (which is a far cry from the 300Mb I should be getting, but it's better than 12 Mbps!!)
While digging through the GUI, I also found this:
Those Tx/Drop counters are constantly increasing, with or without the interface queue being only-hardware-queue, even when things are "idle". By idle, I mean 1-10 Kbps at MOST passing through ether1/wan. If I run a speed test, those drop counters increase at a much higher rate per second.
So assigning a cake queue to the interface (or maybe anything that's not only-hardware-queue?) is doing something that helps, somehow. Also, the E50UG router appears to constantly and always drop tx packets from my ether1 port, regardless of what configuration changes I make. Per my GUI screenshot above, it dropped over 1GB (!) with less than 30 minutes uptime...
Edit: maybe I’m misinterpreting the tx/drop counters? Not sure but the queue results are fairly interesting.
I recently purchased my first MikroTik device, the hEX S (2025), and have also come across the ether1 issues that have been reported by others as well. I am glad not to be alone :slight_smile:.
For the time being, I pulled ether2 out of the bridge and am using that port for my WAN to achieve 300/300 with Verizon Fios. I'm not well-versed in hardware, but I understand that I am utilizing the switch chip for routing/firewall, which is non-ideal.
I also noticed this when I was trying to debug what was going on. I haven't played around with the queues yet, but I'll give that a try to explore a bit further.
For ether1/WAN, another interesting thing I tried was clamping the advertised link to be 100M BaseT Full. To my surprise, I was able to get 100/100 in my speed tests. However, as soon as I added 1G Base T Full as an advertising option, the issue of slow upload speeds (~1-12 Mbps) surfaced.
@eric0x7677 thanks for sharing your results, I’m morbidly glad someone else with the same service I have is reporting the exact same results. Please keep me posted with your findings and I’ll do the same.
The fact that none of my other MikroTik routers (hap ax3, l009, rb5009 - all of them work fine on the same connection) have this problem is plain proof that something is clearly not right in the EN7562CT.
Edit: I do think that I am interpreting that“Tx/Drop” reading in the 7.20rc1 release wrong, it’s probably not indicating drops and is just named or displayed weirdly in the RC GUI
So I wonder if the people for which the fix is working are not connecting to an incompatible device that uses EEE/802.3az
I am wondering if the tests @holvoetn did were with the ether1 port connected to a switch?
I have an RB760iGs but no EN7562CT based routers, so I can't test.
I did my tests with Hex Refresh connected to L009.
So not really a switch but similar behavior.
Can't redo those tests since the device has been deployed. But I do have Hex S 2025 at home now ?
Hmmm, so it seems the 7.20 update does not entirely solve the WAN on ether1 issue? Is 7.20rc1 different from 7.20Beta7, or do we think that whatever fix Mikrotik implemented doesn't entirely solve it? I'm still on the fence whether to buy a couple of these refreshes as spares of my non-refresh HEX, but it sure would be nice to have them be drop-in replacements, rather than configure them for different ports.
Thanks!
