Hex E50UG
Hmmm, so it seems the 7.20 update does not entirely solve the WAN on ether1 issue? Is 7.20rc1 different from 7.20Beta7, or do we think that whatever fix Mikrotik implemented doesn't entirely solve it?
I am pretty sure there are two (or more) things going wrong with the EN7562CT. One is a PPPoE issue reported in this thread, which maybe the 7.20 update corrects. Another one seems to some sort of general download throughput issue, which maybe 7.20 also improves. The other is the upload issue I (and others) are having when connecting to certain GPON provider equipment.
In the second case, the wan/ether1 port upload/tx speed tanks massively which is different from the complaints from people using PPPoE on the wan/ether1 port, and update 7.20 definitely does not fix that per my testing results.
In either case, the built-in PHY of the EN7562CT seems to either be total garbage or MikroTik's drivers/implementation of it are seriously broken.
Ah ok, thanks for the response. I guess my hope that 7.20 stable would solve everything may be a bit over-optimistic then. I'll continue to follow this issue. Quite an unfortunate situation, given what a good value this refresh would have been if it actually delivered as expected.
Sure thing. Despite my frustrations I truly hope MikroTik can fix whatever the problems are.
The OG hex was my gateway drug into RouterOS years ago, so much affordable power and capability. I was really looking forward to using these refresh models in a number of scenarios too :frowning:
When I try to create a macvlan with E50UG, adding just one macvlan causes my network speed to drop by 100~200 Mbps. This is very strange
I just saw that RouterOS 7.19.6 has been released!
*) ethernet - improved performance for hEX Refresh and hEX S (2025);
I'll update when I get home after work and report back my findings.
@eric0x7677 Any news?
I've got one here as well in a lab environment connected to 1G/1G fiber ISP device.
I'll try stuff if it helps anyone figure this out.
Edit: Rookie mistake. I'm getting full speeds on it.. bone stock default config 7.20rc3. ETH1 WAN, ETH2 LAN.
Still willing to help out.
This update didn't solve the problem, now using any port for PPPoE the limitation occurs. Only DHCP works normally.
I'm using DHCP... 250 max.. sometimes under 200.
Are you using IPv6 to do your tests? If yes, enable fasttrack on it once the default config hasn't.
DHCP on ether5 has maximum speed. I'll test ether1. I need PPPoE, which limits all ports.
Nope. v4 only on this ISP
I have an ISP fiber link of 700MiB/350MiB using PPPoE with a bridge modem and I can achieve the maximum of the link on IPv4 and IPv6 (MTU 1492) without problems. The CPU remains around 40% for IPv4 and 30% for IPv6 during the tests. Both IP protocols have a default firewall with Fasttrack enabled and some filters disabled.
It works with fasttrack, but I don't use fasttrack, so the problem persists.
Sigh. Rookie mistake on my part. Limitation was something dumb on my end, not the hEX Refresh.
Embarrassing.
Anyhow, full disclosure.. I'm getting full speeds on default config 7.20rc3 standard setup, ETH1 WAN, ETH2 LAN (PC), FastTrack enabled. 1G symmetric. DHCP connection to Fiber ISP's equipment, IPv4 only.
Still willing to help if I can with a working setup.
Fasttrack enabled or disabled?
Enabled. (default conf)
With Fasttrack, the old updates also work, but Fasttrack with Wireguard and Mangle doesn't work very well. So the problem still exists.
I upgraded to 7.20rc3 as well, and I'm still experiencing upload slowness on ETH1.
I should be getting 300/300. If I switch to ETH2 or use my Asus AP as a router, I can get 300/300.
I'm not sure what else to try, and I would appreciate any guidance you could offer.
Unfortunately we will have to wait for routeros to come with these fixes.
It looks like you're having the same results and behavior on ether1 as me.
These new hex refresh units disagree with something some carriers are doing, but only against ether1. The built-in switch chip (ether2 through ether5) seems to handle it fine. Just like you, none of my other routers (MikroTik, or otherwise) have this problem. Only the hex refresh.
If you can, please try sticking a dumb switch or other device between your hex ether1 and your verizon ONT connection, to see if the problem "magically" goes away.
The really fun thing is, we have no way to troubleshoot any further. With actual console access to ethtool and the kernel message buffer, maybe we could get somewhere. All I can do is guess. Is it EEE/802.3az? Is it flow control? Is it some bizarre driver problem? Is it something else? We have to wait for MikroTik, which obviously doesn't have access to our ISP uplink to troubleshoot against.
Would be nice to hear something, even if it's "here's your money back/a different router because this chip is broken".
