Any news on PPPoE limitation?
If having issues be sure to send a supout to Mikrotik, the more reports they get, the better.
OR
Change your ISP, they clearly are the problem ![]()
It's already been sent to Mikrotik, they know. And if you read this entire thread you'll know that the problem is with Mikrotik and not the provider, so don't speak without knowing.
I don't think the root cause is the ISP but his configuration.
He uses Mangle filters and Wireguard, and says that he can't enable fasttrack.
Did you read this thread, do you know why it was opened?
I'm quite convinced that the actual issue with the ether1 mac is fixed. At this point (especially if connecting to xPON networks) the issue is probably interface queue depth.
You can get tx drop statistics and you can try using a larger (at least 10x compared to default) queue there.
The probable reason for this not showing up on the switched ports is that for them the switch's built-in buffers (around 1-3Mb) provide enough queueing.
I tested it with the RB750GR3, with the same settings, and the problem doesn't occur. After the 7.19 update, even using ether5, the limitation occurs, previously it was only on ether1.
Hmmm. That's strange. I have no idea then. Trying the increased queue or reinstalling the router (if it's not too much trouble) couldn't hurt.
I recently enabled FastTrack, but the speed is still limited. Using a DHCP client instead of PPPoE, it works fine. Is there a specific configuration I can test? Thanks in advance.
Not sure. Maybe there is indeed something messed up around pppoe.
What I can tell you for sure is that without fasttrack anything beyond 500Mbps is basically not possible (on the Refresh series.)
It certainly wouldn't hurt to look at whether any tx drops are indicated. You can see this in the ethernet statistics.
I'll check, I forgot to mention that I only use Wireguard for pi-hole DNS on a VPS, so Wireguard is not the culprit. In DHCP I get 600mb.
I downgraded to 7.15.3 as suggested in other forum threads, reset, and ran my backup script. The PPPoE speed on ether5 works correctly, but on ether1 it stays at 75% of the maximum Link speed. I updated to 7.20 and on ether1 it goes back to 50% of the Link, and on ether5 it stays at 75% of the Link, always with the same configuration. So it's really a lack of tuning on Mikrotik, I believe.
If the cpu is not maxed out (check the per-core usage, because with pppoe it's almost always a single core that chokes) try looking for tx drops and try adding an interface queue.
I'm not trying to be difficult, but could you write down what your measurements show? I'm confused by the part about what you say regarding the speed on ether5: you first write that on the older version ether5 is good but then write that upon upgrade its speed "stays at" 75%. So did it decrease or not?
Sorry for any inconvenience. With the downgrade, I get 600mb of my link on ether5 and 450mb on ether1. After updating to 7.20, on ether1 I get 350mb and on ether5 450mb, CPU 0: 94%, CPU 1: 51% na ether1. In ether5 it is 50% for both.
Unfortunately, the best advice I can give you is to sell your hex refresh and buy something else. Faulty Ethernet ports aren't worth wasting his time, much less trying to prove anything to customer support.
Then it seems that the efficiency of the PPPoE client has somehow decreased. ![]()
Yes. In version 7.15.3, performance is better on ether5. I'll be using ether5 with version 7.20 and waiting for a definitive solution to use ether1 and achieve 100% speed. I read in another thread that this was reported to MK support, and support responded that they are aware of the issue and will fix it in future updates, but there is no timeline for this to happen.
They usually don’t commit to timelines. (Which from a certain perspective makes sense.)
We'll just have to wait. Anyway, thanks for your help.
To Mikrotik experts, is the AI correct?
The ether1 issue on the E50UG (hEX Refresh) is not physical, nor is it a hardware design flaw.
It's a software limitation (driver/datapath in RouterOS) that affects how ether1 traffic passes through the CPU.
Explaining it technically (but clearly):
The E50UG uses the EN7562CT chip from MediaTek/Engenius, which has:
an internal switch controlling the ether2–ether5 ports,
and a separate interface (called GMAC0) connected directly to the CPU—this is ether1.
This is identical to the design of the older RB750Gr3 (MT7621), but with an updated ARM processor.
Currently, in RouterOS 7.20, the driver managing this chip still doesn't offload traffic between ether1 and the internal switch. Therefore:
Any packet entering via ether1 (WAN) passes through the ARM processor to reach the bridge (LAN).
Meanwhile, LAN-to-LAN packets remain within the hardware switch (full fastpath, 900+ Mbps).
Therefore:
WAN-to-LAN performance = limited by CPU (software).
LAN-to-LAN performance = maximum (hardware offload active).
Why this is software-solvable?
Mikrotik has already done this before in other models:
In the RB760iGS (hEX S), ether1 offload was added in later versions of RouterOS.
The same can (and should) happen with the E50UG, if Mikrotik simply releases support for offload between GMAC0 (ether1) and the EN7562 switch.
This doesn't require replacing physical components—just tweaks to the kernel and the switch/bridge driver.
Straightforward Summary
Question Answer
Is ether1 physically defective? No
Is it a permanent limitation? No
Does it require a software update? Yes
Can it be fixed via firmware/RouterOS update? Absolutely
In the meantime, can it be mitigated with FastTrack and optimization? Yes, it reduces CPU load by 50–70%.
Mikrotik should fix this in future versions (7.21/7.22). Likely, as it did with other ARM/MIPS models.
Conclusion:
The E50UG's ether1 isn't a hardware issue.
It just doesn't have active offload in the driver yet—something Mikrotik typically fixes with updates to the datapath engine. In other words: your router is 100% healthy, and the limitation is software, solvable with a RouterOS or firmware update in the near future.
