A month on and off trying to figure out VLANs and nothing. I can’t find anything anywhere that tells how this is supposed to work. Is there somewhere or someone that can just show me the most basic, most primitive example of a working VLAN configuration, using bridge vlan filtering?
Scenario: One router (say hEX S) and One AP (Say wAP AC). Everything is up and working: PC connected to eth2 on router, AP connected from eth2 to eth5 on router, PC has access, Wifi is up and running. Without all the added security, without special management VLAN and firewalls, etc. What is the most basic way to construct a Guest VLAN on the AP, that puts it on a separate network from the default network and gives access to the internet? Is this scenario impossible? If so what is the simplest case scenario and a complete example that actually works? I want to learn this but I need something that works to build off of because there is nothing else available to learn from that adequately explains it. I’ve poured through the docs, all the referenced threads. I’ve been locked out of my router more times that I care to admit. I just need a basic working example to build off of. Then I can learn how to do it right, with full security. Please.
