Hi, I’m trying to set up the two trunk ports on a Mikrotik switch. The uplink trunk port has a native VLAN 555 which is just our native VLAN for links between switches. Our wireless access points don’t have a controller to connect too, so we use trunk ports to allow the networks for the SSIDs. We use VLAN 10 as the management network for the WAPs.
I guess in my case I’m trying to convert the sample configs listed below to a Mikrotik. I do use the WinBox GUI to configure the switch. CRS112-8P-4S v6.49.19
I will leave you to figure the most of it out from links given. But a significant difference is that under Cisco, you are configuring the vLANs into ports. On Mikrotik, you configure ports onto vLANs. So you end up with something like this:
