I wanted to use the Netmetal 5 device as an AP outside of my house.
do I need to purfchase antennas?
will thge device work without antennas? if bnot can you please suggest what I shhould get?
ciao,
Antonio
ciao,
Antonio
Yes, you NEED antennas, powering the device without antennas connected might result in damage to the device, the transmitter needs a given minimum impedance on the connector, if you want to fiddle with the device without antennas, you need to use either common wi-fi antennas or terminators on the antenna connectors.
The matter is dicussed (among many other places) here:
http://forum.mikrotik.com/t/antenna-for-the-netmetal-ax/183391/1
http://forum.mikrotik.com/t/wap-coverage-picture-included/179859/1
http://forum.mikrotik.com/t/netmetal-ax-antenna/182772/1
http://forum.mikrotik.com/t/netmetal-ax-antennas/182113/1
ok well noted and understand clearly!!! I will purchase these :
https://mikrotik.com/product/hgo_antenna_out
thanks!
I am sure noted, I doubt the understood.
You chose … poorly
, those are like the worst possible antennas to mount (if the device is to be put outdoors, but a Netmetal indoors makes little sense), try reading again the given links.
ok now it’s clear… before it was in effect a little muddy, ![]()
ok so its better to connect the wires and cover them as suggested to let the witres go down the back and connect to the antenna device..
something like this :
https://it.bestchoice.com/price-comparison/product-E6gVaV813l
anyhow something similar that is good for external environment.
Yep, but you managed to choose like the second worst antenna in the world
(seriously, that one is for interior use only).
If the netmetal goes outdoors (as it should), you want outdoor antenna(s).
Devices that go outside must be weather/waterproof as much as possible.
In a perfect world anything that goes outside should be IP66, IP67 or IP68, IP55 is usually good enough, but however for not certified devices or when the actual weather/waterproofing depends also on the specific way they are cabled special attention needs to be paid on the insulation/waterproofing.
But do you need an omnidirectional coverage or a sector one?
