RBSXTR&R11e-LTE6
unfortunately I’m having problems with a new RBSXTR&R11e-LTE6 (got it 7 days ago).
Suddenly I find myself without an internet connection, trying a ping 1.1.1.1 directly from SXT results in time out. The connection seems to be “freezed”.
To fix it, the command /interface lte at-chat lte1 input = “AT + reset” (or restarting the device).
Configuration? All default apart APN and frequency bands (3,20), doesn’t help select only LTE in network mode. Also tried with/without cell lock, no difference.
I had this problem with both previous (6.44 and V020) and current ROS/firmware versions.
Everything is up to date but the problem is still there.
Current versions:
ROS: v6.47 (stable)
RouterBOARD’s firmware: v6.47
Modem’s firmware: R11e-LTE6_V025
Simil behaviour here http://forum.mikrotik.com/t/wap-lte-connection-issues/114376/1
The (long) log (look at hr 08.39 and 18.28):
jun/03 14:22:25 system,info router rebooted
jun/03 14:22:34 bridge,info hardware offloading activated on bridge "bridge" ports: ether2,ether1
jun/03 14:22:37 interface,info ether1 link up (speed 100M, full duplex)
jun/03 14:23:13 system,info,account user admin logged in from 192.168.88.10 via web
jun/03 14:23:52 lte,info lte1: registered home
jun/03 14:24:00 interface,info lte1 link up
jun/03 15:05:13 lte,error lte1: reply timeout for: AT+COPS=?
jun/03 15:05:13 interface,info lte1 link down
jun/03 15:05:30 lte,info lte1: registered home
jun/03 15:05:37 interface,info lte1 link up
jun/03 15:13:34 system,info log rule added by admin
00:08:56 system,info,account user admin logged out from 192.168.88.10 via web
00:08:56 system,info,account user admin logged out via local
00:12:44 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
00:12:44 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
00:12:44 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
00:12:47 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
00:12:47 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
00:12:47 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
00:12:47 lte,async,raw lte1: sent AT+CFUN?
00:12:47 lte,async,raw lte1: rcvd +CFUN: 1
00:12:47 lte,async,raw lte1: sent AT+COPS?
00:12:47 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
********** INTERNET NOT WORKING **********
08:39:40 system,info,account user admin logged in from 192.168.88.10 via web
08:48:43 interface,info ether1 link down
08:48:48 interface,info ether1 link up (speed 100M, full duplex)
08:49:06 interface,info ether1 link down
08:49:08 interface,info ether1 link up (speed 100M, full duplex)
08:49:49 interface,info ether1 link down
08:49:51 interface,info ether1 link up (speed 100M, full duplex)
08:50:06 system,info,account user admin logged out from 192.168.88.10 via web
08:57:05 system,error,critical login failure for user admin from 192.168.88.10 via web
08:57:13 system,info,account user admin logged in from 192.168.88.10 via web
08:57:18 system,info,account user admin logged in via local
08:57:38 system,info,account user admin logged out via local
09:03:36 system,info,account user admin logged out from 192.168.88.10 via web
09:04:23 system,error,critical login failure for user admin from 192.168.88.10 via web
09:04:28 system,info,account user admin logged in from 192.168.88.10 via web
09:04:31 system,info,account user admin logged in via local
09:05:17 lte,async lte1: sent AT+reset
09:05:17 lte,async lte1: rcvd OK
09:05:21 lte,account lte1 session: 64784s 5835063787/250751681 bytes 4323631/2758236 packets
09:05:21 lte,async lte1: modem hung up
09:05:21 interface,info lte1 link down
09:05:33 system,info,account user admin logged out via local
09:05:34 system,error,critical login failure for user admin from 192.168.88.10 via web
09:05:45 system,error,critical login failure for user admin from 192.168.88.10 via web
09:05:49 system,info,account user admin logged in from 192.168.88.10 via web
09:05:49 system,info,account user admin logged in via local
09:05:52 system,info,account user admin logged out via local
09:06:00 lte,async lte1: sent ATE0
09:06:00 lte,async lte1: rcvd OK
09:06:00 lte,async lte1: sent AT+CGMI
09:06:00 lte,async lte1: rcvd +CGMI: "MikroTik"
09:06:00 lte,async lte1: sent AT+CGMM
09:06:00 lte,async lte1: rcvd +CGMM: "R11e-LTE6"
09:06:00 lte,async lte1: sent AT+CGMR
09:06:00 lte,async lte1: rcvd R11e-LTE6_V025
09:06:00 lte,async lte1: sent AT+CGSN
09:06:00 lte,async lte1: rcvd 356662100201489
09:06:00 lte,async lte1: sent AT+CFUN?
09:06:00 lte,async lte1: rcvd +CFUN: 4
09:06:00 lte,async lte1: sent AT+CMEE=2
09:06:00 lte,async lte1: sent AT+CREG=2
09:06:00 lte,async lte1: sent AT+CGREG=2
09:06:00 lte,async lte1: sent AT+CEREG=2
09:06:00 lte,async lte1: sent AT+CGEREP=2,0
09:06:00 lte,async lte1: sent AT+CMGF=0
09:06:00 lte,async lte1: sent AT+CNMI=1,1,0,1,0
09:06:00 lte,async lte1: sent AT+EEMOPT=1
09:06:00 lte,async lte1: sent AT*MRD_SN?
09:06:00 lte,async lte1: rcvd *MRD_SN:AE39032CA122
09:06:00 lte,async lte1: sent AT+CPIN?
09:06:00 lte,async lte1: rcvd +CPIN: READY
09:06:04 lte,async lte1: sent AT+CPMS="SM","SM","SM"
09:06:04 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,30
09:06:04 lte,async lte1: sent AT+CFUN?
09:06:04 lte,async lte1: rcvd +CFUN: 4
09:06:04 lte,async lte1: sent AT*ICCID?
09:06:04 lte,async lte1: rcvd *ICCID: ***HIDDEN***
09:06:04 lte,async lte1: sent AT+CNUM
09:06:04 lte,async lte1: rcvd +CNUM: "","***HIDDEN***",129
09:06:04 lte,async lte1: sent AT+CIMI
09:06:04 lte,async lte1: rcvd ***HIDDEN***
09:06:04 lte,async lte1: sent AT+CPIN?
09:06:04 lte,async lte1: rcvd +CPIN: READY
09:06:04 lte,async lte1: sent AT*BAND?
09:06:04 lte,async lte1: rcvd *BAND: 15, 78, 147, 0, 524292, 0, 2, 2, 0
09:06:04 lte,async lte1: sent AT*BAND=15,78,147,0,524292,0,2,0
09:06:04 lte,async lte1: rcvd OK
09:06:04 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
09:06:04 lte,async lte1: sent AT+RESET
09:06:23 lte,async lte1: modem hung up
09:06:36 system,info,account user admin logged out from 192.168.88.10 via web
09:07:02 lte,async lte1: sent ATE0
09:07:02 lte,async lte1: rcvd OK
09:07:02 lte,async lte1: sent AT+CFUN?
09:07:02 lte,async lte1: rcvd +CFUN: 4
09:07:02 lte,async lte1: sent AT+CMEE=2
09:07:02 lte,async lte1: sent AT+CREG=2
09:07:02 lte,async lte1: sent AT+CGREG=2
09:07:02 lte,async lte1: sent AT+CEREG=2
09:07:02 lte,async lte1: sent AT+CGEREP=2,0
09:07:02 lte,async lte1: sent AT+CMGF=0
09:07:02 lte,async lte1: sent AT+CNMI=1,1,0,1,0
09:07:02 lte,async lte1: sent AT+EEMOPT=1
09:07:02 lte,async lte1: sent AT*MRD_SN?
09:07:02 lte,async lte1: rcvd *MRD_SN:AE39032CA122
09:07:02 lte,async lte1: sent AT+CPIN?
09:07:02 lte,async lte1: rcvd +CPIN: READY
09:07:06 lte,async lte1: sent AT+CPMS="SM","SM","SM"
09:07:06 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,30
09:07:06 lte,async lte1: sent AT+CFUN?
09:07:06 lte,async lte1: rcvd +CFUN: 4
09:07:06 lte,async lte1: sent AT*ICCID?
09:07:06 lte,async lte1: rcvd *ICCID: ***HIDDEN***
09:07:06 lte,async lte1: sent AT+CNUM
09:07:06 lte,async lte1: rcvd +CNUM: "","***HIDDEN***",129
09:07:06 lte,async lte1: sent AT+CIMI
09:07:06 lte,async lte1: rcvd ***HIDDEN***
09:07:06 lte,async lte1: sent AT+CPIN?
09:07:06 lte,async lte1: rcvd +CPIN: READY
09:07:06 lte,async lte1: sent AT*BAND?
09:07:06 lte,async lte1: rcvd *BAND: 15, 78, 147, 0, 524292, 0, 2, 2, 0
09:07:06 lte,async lte1: sent AT*BAND=15,78,147,0,524292,0,2,0
09:07:06 lte,async lte1: rcvd OK
09:07:06 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
09:07:07 lte,async lte1: sent AT+ZGDCONT=5,"IP","wap.tim.it",0
09:07:07 lte,async lte1: rcvd OK
09:07:07 lte,async lte1: sent AT+ZGPCOAUTH=5,"","",0
09:07:07 lte,async lte1: sent AT+COPS=0
09:07:07 lte,async lte1: sent AT+COPS=3,0
09:07:07 lte,async lte1: sent AT+CFUN=1
09:07:07 lte,async,event lte1: +CPAS: 2
09:07:07 lte,debug lte1: config ok
09:07:07 lte,async,raw lte1: sent AT+CFUN?
09:07:07 lte,async,event lte1: *RADIOPOWER: 1
09:07:07 lte,async,raw lte1: rcvd +CFUN: 1
09:07:09 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
09:07:09 lte,debug lte1: network access technology: Evolved 3G (LTE)
09:07:09 lte,info lte1: registered home
09:07:09 lte,async,raw lte1: +CGREG: 0
09:07:09 lte,async,event lte1: +CIREPI: 1
09:07:09 lte,async,event lte1: +CPAS: 0
09:07:09 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
09:07:09 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
09:07:09 lte,async,event lte1: +CEN1: 1, 222, 01
09:07:09 lte,async,event lte1: +CGEV: EPS PDN ACT 5
09:07:09 lte,async,event lte1: +ZNITZ: 2020,06,04,09,07,09,32,0
09:07:09 lte,async,event lte1: +NITZ: 1,+8,20/06/04,07:07:09
09:07:10 lte,async,raw lte1: sent AT+CFUN?
09:07:10 lte,async,raw lte1: rcvd +CFUN: 1
09:07:10 lte,async,raw lte1: sent AT+COPS?
09:07:10 lte,async,raw lte1: rcvd +COPS: 0,0,"I TIM",7
09:07:14 lte,async lte1: sent AT+ZGACT=1,5
09:07:14 lte,async lte1: rcvd OK
09:07:16 lte,async,event lte1: +ZCONSTAT: 1,5
09:07:16 lte,async,event lte1: +ZGIPDNS: 5,"IP","10.7.164.168","10.7.164.168","217.200.201.65","217.200.201.64","","","",""
09:07:16 interface,info lte1 link up
09:07:17 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
09:07:17 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
09:07:17 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
09:07:19 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
09:07:19 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
09:07:19 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
09:07:19 lte,async,raw lte1: sent AT+CFUN?
09:07:19 lte,async,raw lte1: rcvd +CFUN: 1
09:07:19 lte,async,raw lte1: sent AT+COPS?
09:07:19 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
09:12:17 system,info,account user admin logged in from 192.168.88.10 via web
09:17:05 interface,info ether1 link down
09:17:09 interface,info ether1 link up (speed 100M, full duplex)
09:17:27 interface,info ether1 link down
09:17:29 interface,info ether1 link up (speed 100M, full duplex)
09:18:06 system,info,account user admin logged out from 192.168.88.10 via web
09:18:07 interface,info ether1 link down
09:18:09 interface,info ether1 link up (speed 100M, full duplex)
09:18:14 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
09:18:14 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
09:18:14 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
09:18:17 lte,async,raw lte1: sent AT+CFUN?
09:18:17 lte,async,raw lte1: rcvd +CFUN: 1
09:18:17 lte,async,raw lte1: sent AT+COPS?
09:18:17 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
09:18:17 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
09:18:17 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
09:18:17 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
09:18:20 lte,async,raw lte1: sent AT+CFUN?
09:18:20 lte,async,raw lte1: rcvd +CFUN: 1
09:18:20 lte,async,raw lte1: sent AT+COPS?
09:18:20 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
09:18:20 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
09:18:20 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
09:18:20 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
09:18:21 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
09:18:21 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
09:18:21 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
09:18:23 lte,async,raw lte1: sent AT+CFUN?
09:18:23 lte,async,raw lte1: rcvd +CFUN: 1
09:18:23 lte,async,raw lte1: sent AT+COPS?
09:18:23 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
13:18:38 lte,async,event lte1: +CGEV: NW PDN DEACT 5
13:18:38 lte,account lte1 session: 15082s 958393252/92408873 bytes 910523/517726 packets
13:18:38 interface,info lte1 link down
13:18:38 lte,async,event lte1: +ZCONSTAT: 0,5
13:18:39 lte,async,event lte1: +CGEV: EPS PDN ACT 5
13:18:39 lte,async,event lte1: +ZNITZ: 2020,06,04,13,18,39,32,0
13:18:39 lte,async,event lte1: +NITZ: 1,+8,20/06/04,11:18:39
13:18:43 lte,async lte1: sent AT+ZGACT=1,5
13:18:43 lte,async lte1: rcvd OK
13:18:46 lte,async,event lte1: +ZCONSTAT: 1,5
13:18:46 lte,async,event lte1: +ZGIPDNS: 5,"IP","10.36.90.243","10.36.90.243","217.200.201.65","217.200.201.64","","","",""
13:18:46 interface,info lte1 link up
13:18:47 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:18:47 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:18:47 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:18:47 lte,async,raw lte1: sent AT+CFUN?
13:18:47 lte,async,raw lte1: rcvd +CFUN: 1
13:18:47 lte,async,raw lte1: sent AT+COPS?
13:18:47 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:19:17 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:19:17 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:19:17 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:19:18 lte,async,raw lte1: sent AT+CFUN?
13:19:18 lte,async,raw lte1: rcvd +CFUN: 1
13:19:18 lte,async,raw lte1: sent AT+COPS?
13:19:18 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
13:19:34 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:19:34 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:19:34 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:19:36 lte,async,raw lte1: sent AT+CFUN?
13:19:36 lte,async,raw lte1: rcvd +CFUN: 1
13:19:36 lte,async,raw lte1: sent AT+COPS?
13:19:36 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:19:37 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:19:37 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:19:37 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:19:37 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:19:37 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:19:37 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:19:39 lte,async,raw lte1: sent AT+CFUN?
13:19:39 lte,async,raw lte1: rcvd +CFUN: 1
13:19:39 lte,async,raw lte1: sent AT+COPS?
13:19:39 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:19:43 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:19:43 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:19:43 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:19:45 lte,async,raw lte1: sent AT+CFUN?
13:19:45 lte,async,raw lte1: rcvd +CFUN: 1
13:19:45 lte,async,raw lte1: sent AT+COPS?
13:19:45 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
13:19:49 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:19:49 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:19:49 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:19:51 lte,async,raw lte1: sent AT+CFUN?
13:19:51 lte,async,raw lte1: rcvd +CFUN: 1
13:19:51 lte,async,raw lte1: sent AT+COPS?
13:19:51 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:19:52 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:19:52 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:19:52 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:19:54 lte,async,raw lte1: sent AT+CFUN?
13:19:54 lte,async,raw lte1: rcvd +CFUN: 1
13:19:54 lte,async,raw lte1: sent AT+COPS?
13:19:54 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
13:19:59 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:19:59 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:19:59 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:20:00 lte,async,raw lte1: sent AT+CFUN?
13:20:00 lte,async,raw lte1: rcvd +CFUN: 1
13:20:00 lte,async,raw lte1: sent AT+COPS?
13:20:00 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:20:34 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:20:34 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:20:34 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:20:35 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:20:35 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:20:35 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:20:37 lte,async,raw lte1: sent AT+CFUN?
13:20:37 lte,async,raw lte1: rcvd +CFUN: 1
13:20:37 lte,async,raw lte1: sent AT+COPS?
13:20:37 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:21:02 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:21:02 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:21:02 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:21:04 lte,async,raw lte1: sent AT+CFUN?
13:21:04 lte,async,raw lte1: rcvd +CFUN: 1
13:21:04 lte,async,raw lte1: sent AT+COPS?
13:21:04 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
13:21:19 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:21:19 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:21:19 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:21:22 lte,async,raw lte1: sent AT+CFUN?
13:21:22 lte,async,raw lte1: rcvd +CFUN: 1
13:21:22 lte,async,raw lte1: sent AT+COPS?
13:21:22 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:21:26 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:21:26 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:21:26 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:21:28 lte,async,raw lte1: sent AT+CFUN?
13:21:28 lte,async,raw lte1: rcvd +CFUN: 1
13:21:28 lte,async,raw lte1: sent AT+COPS?
13:21:28 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
13:21:49 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:21:49 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:21:49 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:21:50 lte,async,raw lte1: sent AT+CFUN?
13:21:50 lte,async,raw lte1: rcvd +CFUN: 1
13:21:50 lte,async,raw lte1: sent AT+COPS?
13:21:50 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:21:52 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:21:52 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:21:52 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:21:53 lte,async,raw lte1: sent AT+CFUN?
13:21:53 lte,async,raw lte1: rcvd +CFUN: 1
13:21:53 lte,async,raw lte1: sent AT+COPS?
13:21:53 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
13:22:00 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:22:00 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:22:00 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:22:02 lte,async,raw lte1: sent AT+CFUN?
13:22:02 lte,async,raw lte1: rcvd +CFUN: 1
13:22:02 lte,async,raw lte1: sent AT+COPS?
13:22:02 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:22:04 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:22:04 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:22:04 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:22:05 lte,async,raw lte1: sent AT+CFUN?
13:22:05 lte,async,raw lte1: rcvd +CFUN: 1
13:22:05 lte,async,raw lte1: sent AT+COPS?
13:22:05 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
13:22:46 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
13:22:46 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
13:22:46 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
13:22:47 lte,async,raw lte1: sent AT+CFUN?
13:22:47 lte,async,raw lte1: rcvd +CFUN: 1
13:22:47 lte,async,raw lte1: sent AT+COPS?
13:22:47 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
13:25:47 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
13:25:47 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
13:25:47 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
13:25:50 lte,async,raw lte1: sent AT+CFUN?
13:25:50 lte,async,raw lte1: rcvd +CFUN: 1
13:25:50 lte,async,raw lte1: sent AT+COPS?
13:25:50 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
18:28:23 system,info,account user admin logged in via local
18:28:30 lte,async lte1: sent AT+reset
18:28:30 lte,async lte1: rcvd OK
18:28:34 system,info,account user admin logged out via local
18:28:34 lte,account lte1 session: 18589s 819364124/91232609 bytes 859036/637189 packets
18:28:34 lte,async lte1: modem hung up
18:28:34 interface,info lte1 link down
18:29:12 lte,async lte1: sent ATE0
18:29:12 lte,async lte1: rcvd OK
18:29:12 lte,async lte1: sent AT+CGMI
18:29:12 lte,async lte1: rcvd +CGMI: "MikroTik"
18:29:12 lte,async lte1: sent AT+CGMM
18:29:12 lte,async lte1: rcvd +CGMM: "R11e-LTE6"
18:29:12 lte,async lte1: sent AT+CGMR
18:29:12 lte,async lte1: rcvd R11e-LTE6_V025
18:29:12 lte,async lte1: sent AT+CGSN
18:29:12 lte,async lte1: rcvd 356662100201489
18:29:12 lte,async lte1: sent AT+CFUN?
18:29:12 lte,async lte1: rcvd +CFUN: 4
18:29:12 lte,async lte1: sent AT+CMEE=2
18:29:12 lte,async lte1: sent AT+CREG=2
18:29:12 lte,async lte1: sent AT+CGREG=2
18:29:12 lte,async lte1: sent AT+CEREG=2
18:29:12 lte,async lte1: sent AT+CGEREP=2,0
18:29:12 lte,async lte1: sent AT+CMGF=0
18:29:12 lte,async lte1: sent AT+CNMI=1,1,0,1,0
18:29:12 lte,async lte1: sent AT+EEMOPT=1
18:29:12 lte,async lte1: sent AT*MRD_SN?
18:29:12 lte,async lte1: rcvd *MRD_SN:AE39032CA122
18:29:12 lte,async lte1: sent AT+CPIN?
18:29:12 lte,async lte1: rcvd +CPIN: READY
18:29:16 lte,async lte1: sent AT+CPMS="SM","SM","SM"
18:29:16 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,30
18:29:16 lte,async lte1: sent AT+CFUN?
18:29:16 lte,async lte1: rcvd +CFUN: 4
18:29:16 lte,async lte1: sent AT*ICCID?
18:29:16 lte,async lte1: rcvd *ICCID: ***HIDDEN***
18:29:16 lte,async lte1: sent AT+CNUM
18:29:16 lte,async lte1: rcvd +CNUM: "","***HIDDEN***",129
18:29:16 lte,async lte1: sent AT+CIMI
18:29:16 lte,async lte1: rcvd ***HIDDEN***
18:29:16 lte,async lte1: sent AT+CPIN?
18:29:16 lte,async lte1: rcvd +CPIN: READY
18:29:16 lte,async lte1: sent AT*BAND?
18:29:16 lte,async lte1: rcvd *BAND: 15, 78, 147, 0, 524292, 0, 2, 2, 0
18:29:16 lte,async lte1: sent AT*BAND=15,78,147,0,524292,0,2,0
18:29:16 lte,async lte1: rcvd OK
18:29:16 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
18:29:16 lte,async lte1: sent AT+RESET
18:29:37 lte,async lte1: modem hung up
18:30:15 lte,async lte1: sent ATE0
18:30:15 lte,async lte1: rcvd OK
18:30:15 lte,async lte1: sent AT+CFUN?
18:30:15 lte,async lte1: rcvd +CFUN: 4
18:30:15 lte,async lte1: sent AT+CMEE=2
18:30:15 lte,async lte1: sent AT+CREG=2
18:30:15 lte,async lte1: sent AT+CGREG=2
18:30:15 lte,async lte1: sent AT+CEREG=2
18:30:15 lte,async lte1: sent AT+CGEREP=2,0
18:30:15 lte,async lte1: sent AT+CMGF=0
18:30:15 lte,async lte1: sent AT+CNMI=1,1,0,1,0
18:30:15 lte,async lte1: sent AT+EEMOPT=1
18:30:15 lte,async lte1: sent AT*MRD_SN?
18:30:15 lte,async lte1: rcvd *MRD_SN:AE39032CA122
18:30:15 lte,async lte1: sent AT+CPIN?
18:30:15 lte,async lte1: rcvd +CPIN: READY
18:30:19 lte,async lte1: sent AT+CPMS="SM","SM","SM"
18:30:19 lte,async lte1: rcvd +CPMS: 0,30,0,30,0,30
18:30:19 lte,async lte1: sent AT+CFUN?
18:30:19 lte,async lte1: rcvd +CFUN: 4
18:30:19 lte,async lte1: sent AT*ICCID?
18:30:19 lte,async lte1: rcvd *ICCID: ***HIDDEN***
18:30:19 lte,async lte1: sent AT+CNUM
18:30:19 lte,async lte1: rcvd +CNUM: "","***HIDDEN***",129
18:30:19 lte,async lte1: sent AT+CIMI
18:30:19 lte,async lte1: rcvd ***HIDDEN***
18:30:19 lte,async lte1: sent AT+CPIN?
18:30:19 lte,async lte1: rcvd +CPIN: READY
18:30:19 lte,async lte1: sent AT*BAND?
18:30:19 lte,async lte1: rcvd *BAND: 15, 78, 147, 0, 524292, 0, 2, 2, 0
18:30:19 lte,async lte1: sent AT*BAND=15,78,147,0,524292,0,2,0
18:30:19 lte,async lte1: rcvd OK
18:30:19 lte,async lte1: sent AT*lteband=3,7,1,20,12,17,2,25,26,5,8,38,41,40,39
18:30:20 lte,async lte1: sent AT+ZGDCONT=5,"IP","wap.tim.it",0
18:30:20 lte,async lte1: rcvd OK
18:30:20 lte,async lte1: sent AT+ZGPCOAUTH=5,"","",0
18:30:21 lte,async lte1: rcvd OK
18:30:21 lte,async lte1: sent AT+COPS=0
18:30:21 lte,async lte1: sent AT+COPS=3,0
18:30:21 lte,async lte1: sent AT+CFUN=1
18:30:21 lte,async,event lte1: +CPAS: 2
18:30:21 lte,debug lte1: config ok
18:30:21 lte,async,raw lte1: sent AT+CFUN?
18:30:21 lte,async,event lte1: *RADIOPOWER: 1
18:30:21 lte,async,raw lte1: rcvd +CFUN: 1
18:30:22 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
18:30:22 lte,debug lte1: network access technology: Evolved 3G (LTE)
18:30:22 lte,info lte1: registered home
18:30:22 lte,async,raw lte1: +CGREG: 0
18:30:22 lte,async,event lte1: +CIREPI: 1
18:30:22 lte,async,event lte1: +CPAS: 0
18:30:22 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
18:30:22 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
18:30:22 lte,async,event lte1: +CEN1: 1, 222, 01
18:30:22 lte,async,event lte1: +CGEV: EPS PDN ACT 5
18:30:22 lte,async,event lte1: +ZNITZ: 2020,06,04,18,30,23,32,0
18:30:22 lte,async,event lte1: +NITZ: 1,+8,20/06/04,16:30:23
18:30:24 lte,async,raw lte1: sent AT+CFUN?
18:30:24 lte,async,raw lte1: rcvd +CFUN: 1
18:30:24 lte,async,raw lte1: sent AT+COPS?
18:30:24 lte,async,raw lte1: rcvd +COPS: 0,0,"I TIM",7
18:30:27 lte,async lte1: sent AT+ZGACT=1,5
18:30:27 lte,async lte1: rcvd OK
18:30:29 lte,async,event lte1: +ZCONSTAT: 1,5
18:30:29 lte,async,event lte1: +ZGIPDNS: 5,"IP","10.37.73.224","10.37.73.224","217.200.201.65","217.200.201.64","","","",""
18:30:29 interface,info lte1 link up
18:30:34 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
18:30:34 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
18:30:34 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
18:30:36 lte,async,raw lte1: sent AT+CFUN?
18:30:36 lte,async,raw lte1: rcvd +CFUN: 1
18:30:36 lte,async,raw lte1: sent AT+COPS?
18:30:36 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",9
18:30:36 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
18:30:36 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
18:30:36 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
18:30:36 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",9
18:30:36 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",9,"09a"
18:30:36 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",9
18:30:38 lte,async,raw lte1: +CREG: 1,"3e29","0ab54b29",7
18:30:38 lte,async,raw lte1: $CREG: 1,"3e29","0ab54b29",7,"09a"
18:30:38 lte,async,raw lte1: +CEREG: 1,"3e29","0ab54b29",7
18:30:39 lte,async,raw lte1: sent AT+CFUN?
18:30:39 lte,async,raw lte1: rcvd +CFUN: 1
18:30:39 lte,async,raw lte1: sent AT+COPS?
18:30:39 lte,async,raw lte1: rcvd +COPS: 0,2,"22201",7
LTE interface:
pin-status: ok
registration-status: registered
functionality: full
manufacturer: "MikroTik"
model: "R11e-LTE6"
revision: R11e-LTE6_V025
primary-band: B3@20Mhz
rsrp: -84dBm
rsrq: -12dB
sinr: 1dB
cqi: 7
ri: 2
Any script for mitigation of this behaviour like restart if ping fails are not a solution for me, I think it must work correctly.
I know that the signal is bad, but rebooting did solve the problem (for a few hours), and with other LTE devices I don’t have any problem.
Sorry for my bad english :slight_smile:
Thanks to everyone who will help me!
I have that problems with firmware 020, 022 as normal.
024 was the best but this is a beta firmware.
025 currently have got similar behavior and you are confirm that.
My way to just push that problem is put sxtr at floor or inside metal trash (empty :slight_smile: ) to do worse signal and when he generate 2 timeout then he stuck in offline - this is still at 025 but only when you use CellLock feature.
Additional many person report me that they have a breakes 2-6s because that 025 very like change and search better band/ca to stay connected and produce short breakes. Mostly you see that at Zoom session :).
Additional ppl say that 025 have problems with CA, they must resign from CellLock and only at*cell=0 do short breake and ca cameback (with speed).
At Chateau is the same but then a scan via 5s fix that, maybe lte modules have the same OS/RTOS perhapse but still this is like common problem in MikroTik as Vendor.
I see that you have good parameters at B3 and please read this: http://forum.mikrotik.com/t/v6-46-1-stable-is-released/135478/1
Please add a watchdog (LteLogger2) script to monitor changes at status of LTE: http://forum.mikrotik.com/t/sxt-lte-4g-cat6/134468/1
About detect the problem and triger some fix action you can discover two ways:
Simple watchdog: http://forum.mikrotik.com/t/sxt-lte-4g-cat6/134468/1
Advance watchdog: http://forum.mikrotik.com/t/tx-rx-fp-rx-dropped-pppoe-account/132656/1
Hi SiB, thanks for reply!
I can confirm that.
I had already visited almost all of your suggested posts :slight_smile:
Although, in my opinion RBSXTR must work out of the box with correct configuration, but in this forum I read that there have been problems for months.
Last friday I opened a ticket with support, but no reply until now. How many days they take approximately to respond?
Why MikroTik does not fix this problem if it occurs in so many cases?
and
and
and finaly
Is about the same.
Because writing here, at forum is not a proper way and this is not count at all as recorded problems. Ppl not give here his supout.rif here, and good, and this is just to share configs and do help in that field.
To fix that sutuation we can group, and report that problems together.
In example, I help many ppl and they create tickets to support by https://help.mikrotik.com/servicedesk and share they case with me as info@sibex.it and then I see that post’s, and I help them do testing, all staff like share they RB via PublicIP for support bcs they not have public ip etc… all that staff. They write me at my telegram and we try do many commands to found any workaround to help MTK to easy replicate a problem.
MikroTik if not reach cesses at that support portal or old way support@mikrotik.com then it’s not count as big problems at massive scale. We must report.
In normal situation who is replicable and documented by user and prepare to test & found solution then MikroTik answer at 0-3days, For me it’s great.
This is my point of view at this forum and how support see at forum. Some post’s are answered here by support itself but this is not a support channel !.
I think this works, the problems can be with lte modules and they firmware and way how they work.
Totally agree with you.
MikroTik if not reach cesses at that support portal or old way > support@mikrotik.com > then it’s not count as big problems at massive scale. We must report.
That’s why I opened a ticket attaching supout.rif.
Just because I read that had already been made reports about long ago, I’m wondering why the problem is stil here today.
I have read that they reply in about 3 days (and you confirmed that), but I wrote about a week ago and today still have no answers from support.
do a trick, create a new supout.rif, write how to replicate the problem and you wait for they any answer.
My cases always have got a workaround, list what I try do and what is differ or not, possibility way to replicate, and new supout.rif. Then they know the problems is not a trivial and it’s not a end-user problem who check all user stuff to fix that.
