Here is my current config. As it is now, I’m only able to connect to the bridge itself. Can’t reach any of the VLANs, so I think that I messed up my filter rules.
# jan/02/1970 20:31:00 by RouterOS 7.8
# model = CRS317-1G-16S+
add admin-mac=48:A9:8A:98:DA:60 auto-mac=no comment=defconf name=vbridge0 \
vlan-filtering=yes
set [ find default-name=ether1 ] comment="Dedicated Admin/Management port"
set [ find default-name=sfp-sfpplus1 ] comment=\
"Used to bridge this switch with the CCR2004-1G-12S+2XS"
set [ find default-name=sfp-sfpplus2 ] comment=\
"Dedicated iLO port (VLAN ID 51)"
/interface vlan
add interface=vbridge0 name=IDM vlan-id=51
add interface=vbridge0 name=IVFT vlan-id=21
add interface=vbridge0 name=IVM vlan-id=2
add interface=vbridge0 name=IVP vlan-id=3
add interface=vbridge0 name=IVR vlan-id=4
add interface=vbridge0 name=IVS vlan-id=5
add interface=vbridge0 name=SPM vlan-id=6
add interface=vbridge0 name=SQN vlan-id=7
add interface=vbridge0 name=XAN vlan-id=8
add name=WAN
add name=LAN
add name=VLANs
/interface lte apn
add name=vBridge0pool ranges=12.0.0.20-12.0.0.254
add name=IDMpool ranges=10.0.0.5-10.0.0.127,10.0.0.129-10.0.0.254
add name=IVMpool ranges=10.0.1.2-10.0.1.254
add name=IVPpool ranges=10.0.2.2-10.0.2.254
add name=IVRpool ranges=10.0.3.2-10.0.3.254
add name=IVSpool ranges=10.0.4.2-10.0.4.254
add name=IVFTpool ranges=10.0.5.2-10.0.5.254
add name=SPMpool ranges=10.12.8.9-10.12.8.254
add name=SQNpool ranges=10.12.7.7-10.12.7.254
add name=XANpool ranges=10.12.6.17-10.12.6.254
add address-pool=IDMpool interface=IDM name=IDMdhcp
add address-pool=vBridge0pool interface=vbridge0 name=vBridge0dhcp
add address-pool=IVMpool interface=IVM name=IVMdhcp
add address-pool=IVPpool interface=IVP name=IVPdhcp
add address-pool=IVRpool interface=IVR name=IVRdhcp
add address-pool=IVSpool interface=IVS name=IVSdhcp
add address-pool=SPMpool interface=SPM name=SPMdhcp
add address-pool=SQNpool interface=SQN name=SQNdhcp
add address-pool=XANpool interface=XAN name=XANdhcp
add address-pool=IVFTpool interface=IVFT name=IVFTdhcp
/port
set 0 name=serial0
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=vbridge0 comment=defconf interface=ether1
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus1
add bridge=vbridge0 comment=defconf frame-types=admit-only-vlan-tagged \
interface=sfp-sfpplus2 pvid=51
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus3
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus4
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus5
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus6
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus7
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus8
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus9
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus10
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus11
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus12
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus13
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus14
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus15
add bridge=vbridge0 comment=defconf interface=sfp-sfpplus16
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface bridge vlan
add bridge=vbridge0 tagged=vbridge0,ether1
add bridge=vbridge0 tagged="sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfpplus\
4,sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus7,sfp-sfpplus8,sfp-sfpplus9,sfp-sfp\
plus10,sfp-sfpplus11,sfp-sfpplus12,sfp-sfpplus13,sfp-sfpplus14,sfp-sfpplus\
15,sfp-sfpplus16" vlan-ids=51
15,sfp-sfpplus16" vlan-ids=21
15,sfp-sfpplus16" vlan-ids=3
15,sfp-sfpplus16" vlan-ids=4
15,sfp-sfpplus16" vlan-ids=6
15,sfp-sfpplus16" vlan-ids=7
15,sfp-sfpplus16" vlan-ids=8
add bridge=vbridge0 untagged="sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp-sfppl\
us4,sfp-sfpplus5,sfp-sfpplus6,sfp-sfpplus7,sfp-sfpplus8,sfp-sfpplus9,sfp-s\
fpplus10,sfp-sfpplus11,sfp-sfpplus12,sfp-sfpplus13,sfp-sfpplus14,sfp-sfppl\
us15,sfp-sfpplus16,vbridge0,ether1" vlan-ids=1
add interface=ether1 list=WAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4 list=LAN
add interface=sfp-sfpplus5 list=LAN
add interface=sfp-sfpplus6 list=LAN
add interface=sfp-sfpplus7 list=LAN
add interface=sfp-sfpplus8 list=LAN
add interface=sfp-sfpplus9 list=LAN
add interface=sfp-sfpplus10 list=LAN
add interface=sfp-sfpplus11 list=LAN
add interface=sfp-sfpplus12 list=LAN
add interface=sfp-sfpplus13 list=LAN
add interface=sfp-sfpplus14 list=LAN
add interface=sfp-sfpplus15 list=LAN
add interface=sfp-sfpplus16 list=LAN
add interface=IDM list=VLANs
add interface=IVFT list=VLANs
add interface=IVM list=VLANs
add interface=IVP list=VLANs
add interface=IVR list=VLANs
add interface=IVS list=VLANs
add interface=SPM list=VLANs
add interface=SQN list=VLANs
add interface=XAN list=VLANs
/interface ovpn-server server
set auth=sha1,md5
add address=12.0.0.4/8 comment=defconf interface=sfp-sfpplus1 network=\
12.0.0.0
add address=10.0.0.128/24 interface=IDM network=10.0.0.0
add address=10.0.1.1/24 interface=IVM network=10.0.1.0
add address=10.0.2.1/24 interface=IVP network=10.0.2.0
add address=10.0.3.1/24 interface=IVR network=10.0.3.0
add address=10.0.4.1/24 interface=IVS network=10.0.4.0
add address=10.0.5.1/24 interface=IVFT network=10.0.5.0
add address=10.12.8.1/24 interface=SPM network=10.12.8.0
add address=10.12.7.1/24 interface=SQN network=10.12.7.0
add address=10.12.6.1/24 interface=XAN network=10.12.6.0
add address=10.0.0.0/24 dns-server=10.0.0.4 domain=<REDACTED> gateway=\
10.0.0.128 ntp-server=10.0.0.4
add address=10.0.1.0/24 dns-server=10.12.8.2 domain=<REDACTED> gateway=\
10.0.1.1 ntp-server=10.12.8.2
add address=10.0.2.0/24 dns-server=10.12.8.2 domain=<REDACTED> gateway=\
10.0.2.1 ntp-server=10.12.8.2
add address=10.0.3.0/24 dns-server=10.12.8.2 domain=<REDACTED> gateway=\
10.0.3.1 ntp-server=10.12.8.2
add address=10.0.4.0/24 dns-server=10.12.8.2 domain=<REDACTED> gateway=\
10.0.4.1 ntp-server=10.12.8.2
add address=10.0.5.0/24 dns-server=10.12.8.2 domain=<REDACTED> gateway=\
10.0.5.1 ntp-server=10.12.8.2
add address=10.12.6.0/24 dns-server=1.1.1.1 domain=<REDACTED> gateway=\
10.12.6.1
add address=10.12.7.0/24 dns-server=10.12.8.2 domain=<REDACTED> gateway=\
10.12.7.1 ntp-server=10.12.8.2
add address=10.12.8.0/24 dns-server=10.12.8.2 domain=<REDACTED> gateway=\
10.12.8.1 ntp-server=10.12.8.2
add address=12.0.0.0/8 dns-server=12.0.0.13 domain=<REDACTED> gateway=\
12.0.0.1 ntp-server=12.0.0.13
set allow-remote-requests=yes servers=1.1.1.1
add action=dst-nat chain=dstnat comment=SoftEtherVPN0 dst-port=443 \
in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=443
add action=dst-nat chain=dstnat comment=SoftEtherVPN1 dst-port=992 \
in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=992
add action=dst-nat chain=dstnat comment=SoftEtherVPN2 dst-port=26422 \
in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=26422
add action=dst-nat chain=dstnat comment=SoftEtherVPN30 disabled=yes dst-port=\
1194 in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=\
1194
add action=dst-nat chain=dstnat comment=SoftEtherVPN31 dst-port=1194 \
in-interface=vbridge0 protocol=udp to-addresses=10.12.8.2 to-ports=1194
add action=dst-nat chain=dstnat comment=SoftEtherVPN40 dst-port=500 \
in-interface=vbridge0 protocol=udp to-addresses=10.12.8.2 to-ports=500
add action=dst-nat chain=dstnat comment=SoftEtherVPN41 dst-port=4500 \
in-interface=vbridge0 protocol=udp to-addresses=10.12.8.2 to-ports=4500
add action=dst-nat chain=dstnat comment=SoftEtherMangt dst-port=5555 \
in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=5555
add action=dst-nat chain=dstnat comment=hMailServSMTP dst-port=25 \
in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=25
add action=dst-nat chain=dstnat comment=hMailServPOP3 dst-port=110 \
in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=110
add action=dst-nat chain=dstnat comment=hMailServIMAP dst-port=143 \
in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=143
add action=dst-nat chain=dstnat comment=hMailServSMTPS disabled=yes dst-port=\
465 in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=\
465
add action=dst-nat chain=dstnat comment=hMailServPOP3s disabled=yes dst-port=\
110 in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=\
110
add action=dst-nat chain=dstnat comment=hMailServIMAPS disabled=yes dst-port=\
995 in-interface=vbridge0 protocol=tcp to-addresses=10.12.8.2 to-ports=\
995
add disabled=no dst-address=0.0.0.0/0 gateway=12.0.0.1
/system clock
set time-zone-name=America/New_York
/system identity
set name=DC-10GbE-BridgeSwitch
/system ntp client
set enabled=yes
/system ntp client servers
add address=10.12.8.2
/system package update
set channel=long-term
/system routerboard settings
set boot-os=router-os
