rv5900 igmp-proxy
Hi
I just bought my rb5900 a couple of days a go for my isp in the Netherlands. My isp providers tv and internet over 2 vlan’s where the tv signals are send over multicast.
I configured my rb5900 with igmp-snooping and igmp-proxy but what ever i try the rb5009 drops the multicasts.
With the same config applied on the rb750 no issues
add arp=proxy-arp igmp-snooping=yes name=bridge-local protocol-mode=none
set [ find default-name=ether1 ] arp=proxy-arp l2mtu=1598 loop-protect=off
set [ find default-name=ether2 ] l2mtu=1598
/interface vlan
add interface=ether1 name=vlan1.4 vlan-id=4
add interface=ether1 loop-protect=off name=vlan1.6 vlan-id=6
/ip dhcp-client option
add code=60 name=option60-vendorclass value="'IPTV_RG'"
/ip dhcp-server option
/ip dhcp-server option sets
add name=IPTV options=option60-vendorclass
add name=dhcp_pool0 ranges=192.168.1.2-192.168.1.254
add address-pool=dhcp_pool0 interface=bridge-local lease-time=1h30m name=\
    dhcp1
/ppp profile
set *0 only-one=yes use-compression=yes use-ipv6=no use-upnp=no
add name=default-ipv6 only-one=yes use-compression=yes use-upnp=no
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface=vlan1.6 \
    keepalive-timeout=20 max-mru=1500 max-mtu=1500 name=pppoe-client profile=\
    default-ipv6 user=1234@provider
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
    disabled=yes disabled=yes name=zt1 port=9993
add bridge=bridge-local interface=ether2
add bridge=bridge-local interface=ether3
add bridge=bridge-local interface=ether4
add bridge=bridge-local interface=ether5
add bridge=bridge-local interface=ether6
add bridge=bridge-local interface=ether7
add bridge=bridge-local interface=ether8
add address=192.168.1.1/24 interface=bridge-local network=192.168.1.0
/ip dhcp-client
add default-route-distance=210 dhcp-options=option60-vendorclass interface=\
    vlan1.4 use-peer-dns=no use-peer-ntp=no
add address=192.168.1.0/24 gateway=192.168.1.1
set allow-remote-requests=yes cache-max-ttl=1d servers=8.8.8.8,8.8.4.4
add action=accept chain=input in-interface=pppoe-client protocol=icmp
add action=accept chain=input connection-state=related
add action=accept chain=input connection-state=established
add action=reject chain=input in-interface=pppoe-client protocol=tcp \
    reject-with=icmp-port-unreachable
add action=reject chain=input in-interface=pppoe-client protocol=udp \
add action=masquerade chain=srcnat comment="Needed for IPTV" dst-address=\
    213.75.112.0/21 out-interface=vlan1.4
    217.166.0.0/16 out-interface=vlan1.4
add action=masquerade chain=srcnat comment="Needed for internet" \
    out-interface=pppoe-client src-address=192.168.1.0/24
/ip upnp
set show-dummy-rule=no
/ip upnp interfaces
add interface=bridge-local type=internal
add interface=pppoe-client type=external
/routing igmp-proxy interface
add alternative-subnets=0.0.0.0/0 interface=vlan1.4 upstream=yes
/system clock
set time-zone-name=Europe/Amsterdam
/system routerboard settings
set cpu-frequency=auto
compared with the rb750
/interface vlan
    keepalive-timeout=20 max-mru=1500 max-mtu=1500 name=pppoe-client \
    password=1234 user=1234@provider
add address-pool=dhcp_pool0 disabled=no interface=bridge-local lease-time=\
    1h30m name=dhcp1
/ppp profile
set *0 only-one=yes use-compression=yes use-upnp=no
/routing bgp instance
set default disabled=yes
/tool user-manager customer
set admin access=\
    own-routers,own-users,own-profiles,own-limits,config-payment-gw
/ip dhcp-client
add default-route-distance=210 dhcp-options=option60-vendorclass disabled=no \
    interface=vlan1.4 use-peer-dns=no use-peer-ntp=no
/ip upnp
/ip upnp interfaces
/system clock
/system logging
add topics=igmp-proxy
/tool user-manager database
set db-path=flash/user-manager
I am completely lost… any advise on what to try next?
See here, it looks like the same thing maybe?
http://forum.mikrotik.com/t/rb5009-ros-7-1-1-igmp-snooping-issue-with-l2-hw-offload/155045/2
Your config looks right.
The RB5009 on ROS 7.1.1 and 7.2rc1 has issues with DSCP and VLAN IDs and priorities.
The initial report was about troubles with outgoing PPPoE and VLANs. Other users have reported the same also for VLAN ifaces directly attached to physical etherX interfaces, breaking SIP over VLAN.
It seams the RB5009 messes up with VLAN and VLAN priorities on WAN interfaces.
If possible, try to sniff for in/out IGMP on WAN connection and RTP streams if it gets so far to establish them.
If you encounter wrong VLAN IDs and or priorities, it can be worked around by adding a Raw post-routing FW rule on thw WAN facing iface to adjust wrong values befor they travel towards WAN.
For know, I gave up with MDNS Proxy on RB5009 and temorarly solved the problem by adding a VLAN passing the WAN to an untagged access port for the TV box. This way the TV IGMP/RTP traffic flows around the NAT on L2. This works well with the l2hw offload for VLAN bridging in RB5009.
This might not work dpending on your ISP IPTV and the CPE in place. But if it does, it works very reliable.
I’m also experiencing SIP issues (in my case provisionning) with PPPoE on a VLAN interface on both RB5009UG+S+IN & RB4011iGS+RM… Let’s hope Mikrotik is able to fix those VLAN bugs…
I have it configured like this, PPPoE+multicast on VLAN:
add igmp-snooping=yes mtu=1588 multicast-querier=yes name=bridge1 \
    protocol-mode=none
set [ find default-name=ether1 ] l2mtu=1596
set [ find default-name=ether2 ] l2mtu=1596
set [ find default-name=ether3 ] l2mtu=1596
set [ find default-name=ether4 ] l2mtu=1596
set [ find default-name=ether5 ] l2mtu=1596
set [ find default-name=ether6 ] l2mtu=1596
set [ find default-name=ether7 ] l2mtu=1596
set [ find default-name=ether8 ] l2mtu=1596
set [ find default-name=sfp-sfpplus1 ] l2mtu=1596 rx-flow-control=auto \
    tx-flow-control=auto
add add-default-route=yes disabled=no interface=ether8 name=pppoe-out1 \
    service-name=ccr user=username
/interface vlan
add interface=ether8 name=vlan602 vlan-id=602
add interface=ether8 name=vlan606 vlan-id=606
add name=dhcp_pool0 ranges=192.168.1.50-192.168.1.200
add address-pool=dhcp_pool0 interface=bridge1 lease-time=1h name=dhcp1
/interface bridge filter
add action=set-priority chain=forward disabled=yes in-interface=vlan606 \
    new-priority=7 out-interface=ether5 packet-type=multicast passthrough=no
add action=drop chain=forward out-interface=vlan606 packet-type=!multicast
add action=drop chain=output out-interface=vlan606 packet-type=!multicast
add bridge=bridge1 ingress-filtering=no interface=ether1
add bridge=bridge1 ingress-filtering=no interface=ether2
add bridge=bridge1 ingress-filtering=no interface=ether3
add bridge=bridge1 ingress-filtering=no interface=ether4
add bridge=bridge1 ingress-filtering=no interface=ether5
add bridge=bridge1 ingress-filtering=no interface=ether6
add bridge=bridge1 ingress-filtering=no interface=ether7
add bridge=bridge1 ingress-filtering=no interface=vlan606
add bridge=bridge1 interface=sfp-sfpplus1
/interface bridge settings
set use-ip-firewall=yes use-ip-firewall-for-vlan=yes
/ipv6 settings
/interface detect-internet
set detect-interface-list=all
add address=192.168.1.1/24 interface=bridge1 network=192.168.1.0
/ip dhcp-client
add add-default-route=no interface=vlan602 use-peer-dns=no use-peer-ntp=no
add address=192.168.1.0/24 dns-server=192.168.1.1,8.8.8.8 gateway=192.168.1.1
set servers=8.8.8.8,8.8.4.4
add action=drop chain=input icmp-options=8:0 in-interface=pppoe-out1 \
    protocol=icmp
add action=drop chain=input icmp-options=8:0 in-interface=vlan602 protocol=\
    icmp
add action=drop chain=input disabled=yes icmp-options=8:0 in-interface=\
    bridge1 protocol=icmp
add action=masquerade chain=srcnat out-interface=pppoe-out1
add disabled=no dst-address=192.168.200.0/29 gateway=192.168.250.1
/routing igmp-proxy
set quick-leave=yes
add interface=vlan606 upstream=yes
add interface=bridge1
it works for me, but I’m waiting for them to fix the filters
KPN?
But: enable “multicast_querier” on your bridge and you should be good. Took me forever to figure that out, appears this was enabled by default / differently in rOS 6.4x - hence why migrating (or netwerkje.com) settings isn’t working from the box.
edit: Which is what Ady262 linked to before, kudos.
edit2: Oh, and if it is KPN (or any of the sub brands): IPv6 won’t work yet. Issue described above.
I’m also using kpn, no “multicast_querier” on bridge needed here as there is an IGMP Proxy interface with “Querier” ( the bridge-local interface ) on the device.
add alternative-subnets=10.237.224.0/19,213.75.167.0/24,213.75.112.0/21,217.166.224.0/22 interface=vlan4 upstream=yes
