SFP support RB5009UG+S+IN
Got me an RB5009UG+S+IN to replace my RB4011iGS+RM. Been using a generic fs.com sfp (SFP-GE-BX) for a couple of years and that has been running perfectly.
Copied the config and running smooth except...no RX on the sfp while there are packages flowing TX.
Mmm...something with the sfp? Optic cable defective?
Replaced it back with the RB4011, no problems at all.
Replaced it with the hEX S (I have some spare hardware) performing the same config as the RB5009...no problems at all.
Is the RB5009 (still) picky when it comes to sfp adapters? How can I find out which adapters are supported and working?
Running RouterOS version 7.20beta9 (firmware upgrade as well) on all devices.
Also created a support ticket.
There is a table here: MikroTik wired interface compatibility - RouterOS - MikroTik Documentation
From that, the RB5009 does not seem particularly picky...
The picky part was because of the topics I found on this forum about sfp and RB5009.
The TS has exactly the same problem (though he encountered it in 2022):
As a workaround I have my CRS112 handling the SFP and with VLAN filtering I'm able to do NAT on the RB5009. Still puzzled by why it is not working (though I found a topic on this forum describing the exact same problem).
Yes - In the end i had to move to a very specific sfp+ adapter (zaram) to get this to work. Seems the RB5009 is more picky than the HexS
Could you please share the type? I assume this is for AON and not for XGS-PON?
Not sure if this is for AON - you’ll need to ask one of the sellers (will provide email in a pm)
Type is Zaram ZXOS11NPI SFP+ it will work on both Delta as well as KPN with the latest firmware
Thanks, just checked...it is XGS-PON, while I still am on AON.
