Anything that requires fetch now requires FTP permission. Netwatch doesn’t have that, I think.
So you need to use special tricks and they are barely documented. Probably someone here knows what to do.
Anyone else having issues with 10GBaseT SFP+ on CRS317? Mine stops working after update to 7.14. Like, link is up, but cannot reach other side. (SUP-144396)
Solution:
Had the affected bridge port set to edge=no. Setting it to edge=auto makes it work again. Mikrotik support was quick to help
The defaults only change things on new routers, or if you do a factory reset. Also, like the changelog says, the specific change is for LTE devices, which does not include RB4011
What’s new in 7.14rc2 (2024-Feb-20 12:35):
!) rose-storage - moved SMB service to the RouterOS bundle;
!) smb - removed legacy SMB service (replaced with newer and faster ROSE SMB service, compatible with SMB 2.1, SMB 3.0 and SMB 3.1.1);
*) bridge - fixed MLAG connection after peer-link flap (introduced in v7.13);
*) bridge - fixed MLAG connection issues due to STP (introduced in v7.14beta3);
*) bridge - fixed packet forwarding after changing HW offloaded bridge interface settings in certain cases (introduced in v7.13);
*) bridge - fixed port mst-override status (introduced in v7.14beta3);
*) defconf - improved wifi interface detection after upgrade;
*) lte - added redial timer when the MBIM modem fails to register or does not receive APN activation notification;
*) ovpn - improved “push-routes” option handling when large amount of routes is specified;
*) sms - increased SMS read timeout;
I’m also having problems with USB stick disappearing on RB5009.
I use the USB stick as storage for my containers, and after 3~4 days of uptime the usb1-part1 disk disappears from /file and garbage is shown in /disk.
The weird part is that all containers continue to work, but after a while this seems to corrupt data in the USB stick.
I thought this problem was related to my USB stick, so I didn’t report the problem before. I will wait until it happens again and then open a ticket with support.
Same for me with hap ax3, USB drive will cause a kernel panic and reboot after a few minutes in RC1. Will test on RC2.
EDIT: still kernel panic and reboot on RC2. Also formating seems broken, and when it actually works my PC sees the partition as ext3 and not as ext4 (this happened even before 7.14).
I keep having the MTU reseting from 1700 to 1500 on a VLAN interface. 7.14 RC1. RB5009.
The VLAN interface is on a VLAN aware Bridge (L2MTU = 1704 on the bridge interface). MTU = 1700 is accepted, then strangely revert to 1500 without any reported error.
It’s very annoying. I loose connectivity because this larger 1700 MTU is needed for an IPIPv6 tunnel.
In the meantime i would need a script to regularly check this value and reset it to 1700 if it did change.
I would be grateful if someone has such a similar script that i could use as a template.
7.14 RC2 does not seem to solve the problem. After upgrading from 7.14RC1 to 7.14RC2, the MTU was again at 1500.
Is there another interface on the bridge that has a lower MTU? I feel like I ran into this kind of thing using bridged tunnels at some point in the past and I think it was an interface that I missed updating the MTU on somewhere.
Unfortunately no, we have found a regression in the 05 FW that would lead to the lte interface to not show up in some cases, for now the version is removed from the upgrade server and a downgrade to 04 is recommended.
Hi, what is the bridge interface’s MTU (not L2MTU)? And what MTU values have bridge members? If any VLAN member (e.g., a bridge port with the respective pvid value) has a lower MTU (like 1500), the entire bridge resets MTU to the lowest value.
Bridges operate on Layer 2, where packet fragmentation is not possible. In other words, a bridge cannot forward a 1700-byte packet to an MTU=1500 port. Hence, the bridge selects the lowest MTU of the bridged interfaces (ports).
Please share your “/interface print” and “/interface export” output for further analysis.
I think you are confused with stuff from another manufacturer here. It has never been a problem to downgrade on MikroTik,
only you cannot downgrade below the version that was installed at the factory. When you have upgraded it yourself, you can
always downgrade to the previous version.
