IKEv2 tunnels fail to establish after upgrading to 7.17 (between 7.17<->7.17 and 7.17<->7.16.2). However, 7.17 does establish IKEv2 with Huawei AR (same settings).
Rolling back to 7.16.2 does fix the issue.
Auth method is PSK, 7.17 peer sends “Delete” right after successful IKE_AUTH. Tested on both live RBs and GNS3 lab.
On server-space it sounds quite logical, but here we have situation where some of same models succeed and some fail - while using same installation packages and sharing same architecture. It is hard to believe this has anything to do with userspace.
P. S. Even units with same hardware behave differently - hap ac2 with its’ 16 MB storage succeeds but RB450Gx4 with 512 MB storage fails while both have essentially same SoC
It seems, it reinitializes all the IGPs after 5sec:
2025-01-17 13:23:21 route,bgp,info JPoP_MTik1-IPv6-1 {l_addr: fc00::10:43:0:126, r_addr: fc00::10:7:255:255} Established
2025-01-17 13:23:26 route,rip,info instance { 0 IP } created
2025-01-17 13:23:26 route,rip,info instance { 0 IP6 } created
2025-01-17 13:23:27 route,rip,info instance { 0 IP } interface { L2TP1 } created
2025-01-17 13:23:27 route,rip,info instance { 0 IP6 } interface { L2TP1 } created
2025-01-17 13:23:29 route,rip,info instance { 0 IP6 } interface { L2TP1 } neighbor fe80::eb47:9598:f0:28%*8 created
2025-01-17 13:23:32 route,ospf,info instance { version: 3 router-id: 10.43.0.126 } created
2025-01-17 13:23:32 route,ospf,info OSPFv3 { version: 3 router-id: 10.43.0.126 } area { 0.0.0.0 } created
2025-01-17 13:23:32 route,ospf,info instance { version: 2 router-id: 10.43.0.126 } created
2025-01-17 13:23:32 route,ospf,info OSPFv2 { version: 2 router-id: 10.43.0.126 } area { 0.0.0.0 } created
This is totally platform independent, experiencing on CHR too. If I add a static default then where forwarding works, where it doesn’t:
$ ping 10.43.0.126
PING 10.43.0.126 (10.43.0.126) 56(84) bytes of data.
64 bytes from 10.43.0.126: icmp_seq=11 ttl=60 time=10.5 ms
64 bytes from 10.43.0.126: icmp_seq=12 ttl=60 time=12.1 ms
64 bytes from 10.43.0.126: icmp_seq=13 ttl=60 time=10.6 ms
64 bytes from 10.43.0.126: icmp_seq=14 ttl=60 time=12.0 ms
64 bytes from 10.43.0.126: icmp_seq=15 ttl=60 time=10.3 ms
64 bytes from 10.43.0.126: icmp_seq=16 ttl=60 time=10.3 ms
64 bytes from 10.43.0.126: icmp_seq=17 ttl=60 time=12.1 ms
64 bytes from 10.43.0.126: icmp_seq=18 ttl=60 time=10.1 ms
64 bytes from 10.43.0.126: icmp_seq=19 ttl=60 time=9.82 ms
64 bytes from 10.43.0.126: icmp_seq=20 ttl=60 time=12.5 ms
64 bytes from 10.43.0.126: icmp_seq=21 ttl=60 time=15.8 ms
64 bytes from 10.43.0.126: icmp_seq=22 ttl=60 time=10.4 ms
64 bytes from 10.43.0.126: icmp_seq=23 ttl=60 time=10.2 ms
64 bytes from 10.43.0.126: icmp_seq=24 ttl=60 time=10.2 ms
64 bytes from 10.43.0.126: icmp_seq=25 ttl=60 time=11.6 ms
64 bytes from 10.43.0.126: icmp_seq=26 ttl=60 time=10.2 ms
64 bytes from 10.43.0.126: icmp_seq=75 ttl=60 time=8.75 ms
64 bytes from 10.43.0.126: icmp_seq=76 ttl=60 time=11.5 ms
64 bytes from 10.43.0.126: icmp_seq=77 ttl=60 time=10.0 ms
64 bytes from 10.43.0.126: icmp_seq=78 ttl=60 time=11.7 ms
64 bytes from 10.43.0.126: icmp_seq=79 ttl=60 time=10.8 ms
64 bytes from 10.43.0.126: icmp_seq=80 ttl=60 time=10.6 ms
64 bytes from 10.43.0.126: icmp_seq=81 ttl=60 time=10.8 ms
64 bytes from 10.43.0.126: icmp_seq=82 ttl=60 time=11.8 ms
64 bytes from 10.43.0.126: icmp_seq=83 ttl=60 time=12.2 ms
64 bytes from 10.43.0.126: icmp_seq=84 ttl=60 time=10.1 ms
64 bytes from 10.43.0.126: icmp_seq=85 ttl=60 time=10.5 ms
64 bytes from 10.43.0.126: icmp_seq=86 ttl=60 time=10.2 ms
^C
--- 10.43.0.126 ping statistics ---
201 packets transmitted, 28 received, 86.0696% packet loss, time 202355ms
rtt min/avg/max/mdev = 8.746/10.988/15.813/1.273 ms
After updating from 7.16.2 to 7.17 yesterday the 5ghz wifi has stopped working.
I have a hAP ax^3 (C53UiG+5HPaxD2HPaxD). The wifi1 interface has all of the configurations that it previously had, but is offline.
Both wifi interfaces are members of Bridge1, Bridge ports show wifi2 (2ghz) is up and running and it transmitting its SSID, whereas wifi1 shows it is not up and is not broadcasting its SSID.
I’ve looked at the config pre-update and post-update and it has not changed.
I manually uploaded the wifi-qcom package hoping it was just corrupt, that didn’t help. I uninstalled the wifi-qcom package and then reinstalled it, no luck.
While usual stable release may sometimes be beta-level quality, this endless polishing of device-mode produced a release of alpha-level quality if not even worse…
It might be possible, it is related to some scenarios only. For example: majority of IPv6 traffic, heavy load, traffic handovers between 2,4 and 5 GHz bands, fast BSS transition according IEEE 802.11r etc. etc. If I would know, it would be excellent, but I don’t know root cause. Reality is that in my quite simple case and simple config always ending with not only Linux OOPS, but even kernel panic crash and restart with autosupout.rif generated.
All autosupout.rif had been provided to Mikrotik. And result was - nothing, it is fine, old HW, use “wireless.apk”. On the other hand “wirelles.apk” works fine. But in this case is big question, why Qualcomm native drivers on Qualcomm HW work so badly in specific cases? And it seems I am not alone. Majority of my connected devices are Apple products and there were more complains from other users about the usage, traffic fluctuation, sudden disconnections and reconnections etc.
Thank you Deniss for your effort. I wanted not to be rude, but closing the tickets with kernel crashes without any solution makes me little bit angry. And not only here, in my job (mobile telco industry) too. :-)) Resources are in my case fine, I have 256MB RAM, not only 128MB. I am willing to test it, if you want.
I upgraded to 7.17 on my hAP ax2 and realized that the bridge ports are not shown as “hardware offloaded” anymore. This was always the case on previous versions. Bug?
P.S: Setting “detect interface list” (Detect Internet) to “none” doesn’t fix the issue.
Yeah and some random guy here dreamed THIS will be a long-term, because it took so long… LOL
This is a typical MT point-zero release, 3 steps forward and 5 back… The long-term is as far away as with the v7.0 release.
This is because many people wait for the final release to pull the trigger: “omg!!! it broke my xyz”. instead of evaluating the testing releases ao Mikrotik can fix release specific issues before final version.
Superchannel is working great on my hAP ax3, no DFS and max TX power allowed by the hardware just had to limit the frequency to 5180-5805 and 2412-2462. Otherwise it may pick a channel out of the usable spectrum for most WiFi clients.
