FastPath is a PMD hook into a userspace forwarding plane.
OpenVPN and ZeroTier are already userspace based, WireGuard is using the kernel module I believe.
Mikrotik could technically add FastPath support to any of these as long as they use the Userspace version rather than the Kernel module.
Will they? I have no idea… The developer time would be better spent on an IPv6 FastPath module, FastPath FIFO shaper and improving performance of the existing FastPath modules.
On hAP ac^2 if I set “strong-crypto=yes” in IP/SSH/ and try to export config of entire device, it takes a very long time and finally in file is error about SSH and this section is not exported:
set api disabled=yes
set winbox port=8291
set api-ssl disabled=yes
#error exporting /ip/ssh
/system clock
set time-zone-name=Europe/Warsaw
/system identity
Config view from console :
[admin@Testv7] /ip/ssh> pr
forwarding-enabled: no
always-allow-password-login: no
strong-crypto: yes
allow-none-crypto: no
host-key-size: 4096
i’m also on hapac2, i can export config just fine with enabling strong-crypto, the only caveats is I should backup the config without password otherwise the backup file won’t be restored successfully, already filed a ticket on this weird bug
Interesting, I also have discovered how to reproduce. It happens if you set key size to 4096 and try to export config. In my case it caused to take ~2mins and 40% CPU load(and error line in exported file).
Setting key size to 2048 and export work fast and fine, then if you set again 4096 after that it also works.
I just upgraded Winbox to 3.29 and ROS to v7.1rc2 (tile). Winbox no longer has capsman in its highest level categories, but I still had a capsman window open from before the upgrades.
Additional info: I restored winbox 3.28 from a backup but it will not run with v7.1. I downgraded back to 6.49b54 and winbox 3.29 has capsman so the problem is 7.1rc2. I also did not see dude in 7.1rc2 but do not know if it is supposed to be there. I will wait for v71rc3 and try again.
Please add an option to /import, or make it the default behavior, to print the imported line when an error occurs (in addition to the error message), and to continue the import.
As it is now, it is very difficult to import rsc files as even with the slightest difference in features the import stops and prints only the error message (like “item already exists”) without context.
The “verbose” option can be used, but it prints everything and it still does not continue after the error so repeated attempts with from-line option are required
