RouterOS version 7.1rc5 has been released in public “development” channel!
What’s new in 7.1rc5 (2021-Oct-25 20:15):
!) container - package is getting updated and will be made available in future, if interested in container feature please use 7.1rc4;
*) arm64 - fixed “total-sector-writes” resetting on each startup;
*) bgp - fixed IBGP nexthop selection;
*) bgp - fixed binding to IPv6 “link-local” address;
*) bgp - fixed missing default “local-pref” on selection;
*) bgp - fixed stability when appending extended communities;
*) bgp - improved stability and other minor fixes;
*) bonding - added warning when using 802.3ad mode without MII link monitoring;
*) bridge - added HW offload support for vlan-filtering on MT7621 switch chip (hEX, hEX S, RBM33G, RBM11G, LtAP);
*) bridge - fixed incorrect “hw=no” setting after reboot in rare cases;
*) bridge - improved MLAG stability;
*) capsman - do not include “access-list” passphrases in the output of export command by default;
*) certificate - added ability to choose the digest algorithm when generating a certificate;
*) chr - fixed FastPath support for VMXNET3 drivers;
*) dhcpv4 - fixed backslash prefix for packet logging;
*) dhcpv6-client - show correct DUID in print;
*) dhcpv6-server - fixed “address-pool” default value;
*) dhcpv6-server - fixed DUID generation with timestamp;
*) dns - fixed memory leak caused by large DNS replies;
*) gps - fixed built-in GPS functionality for LtAP;
*) health - fixed health value reporting on RB5009;
*) ipsec - enabled hardware acceleration support for ARM and ARM64 devices;
*) ipsec - fixed hardware acceleration support for CHR;
*) l3hw - fixed MTU on receive;
*) l3hw - fixed source MAC address usage for routed packets;
*) leds - adjust “system-led” color based on cellular connection technology on Chateau devices;
*) leds - fixed LED configuration on RB4011;
*) ltap - improved PCIe card support;
*) lte - added “at-chat” support in MBIM mode for Simcom modems in USB composition mode 9003;
*) lte - improved APN re-connection on non LTE networks;
*) lte - improved modem signal monitoring on Chateau 5G;
*) lte - moved notifications about incorrect responses from modem to ‘lte’ topic;
*) lte - properly show antenna selection on Chateau devices;
*) lte - request modem to restart registration process if timeout detected;
*) ospf - accept LA prefixes from intra-area router’s LSA to the routing table;
*) mpls - added ICMP handler (send ICMP ttl exceed on MPLS ttl expiry);
*) ospf - allow to set IPv6 networks for “interface-template”;
*) ospf - disable areas with no interface configuration;
*) ospf - do not allow to set “ptp-unnumbered” on IPv6 interfaces;
*) ospf - do not set empty filter chains when upgrading from v6;
*) ospf - improved stability and other minor fixes;
*) ospf - show interface’s hello, re-transmit and dead intervals;
*) package - uninstall “container” package when downgrading to v6;
*) pppoe - fixed DHCPv6 PD;
*) quickset - added 5G signal quality information;
*) quickset - made “Password…” button work in Basic AP mode;
*) route - improved stability and other minor fixes;
*) route-filters - fixed “<=” and “>=”;
*) route-filters - fixed “ext-community” problems;
*) route-filters - fixed “num range” matchers;
*) route-filters - fixed “route origin” matcher;
*) route-filters - improved completion;
*) route-filters - improved stability and other minor fixes;
*) rpki - added “rpki-query” command;
*) rpki - other minor fixes;
*) snmp - fixed IPsec-SA stats counter reporting;
*) snmp - fixed bulk get/walk with large neighbor version strings;
*) ssl - added support for additional GCM_SHA384 ciphers;
*) ssl - fixed x509 chain validation;
*) switch - fixed bogus statistics after RTL8367 switch reset;
*) system - improved DHCP and HotSpot service stability when shutting down;
*) system - improved system stability when downgrading to v6 with external disks attached;
*) tr069-client - improved compatibility for 5G;
*) traffic-flow - added systematic count-based packet sampling support;
*) user-manager - fixed “rate-limit-priority” parameter;
*) user-manager - fixed PEAP server authentication for Windows clients;
*) vrf - allow to assign interfaces directly along with interface lists;
*) vxlan - added default L2MTU value for improved connectivity in bridged setups;
*) vxlan - improved speed on MIPSBE devices;
*) wifiwave2 - fixed configuration profile renaming;
*) wifiwave2 - moved RADIUS accounting parameters to a separate configuration profile;
*) winbox - added “netmap” action to IPv6 NAT rules;
*) winbox - added IPv6 support for “Network” parameter under “Routing/OSFP/Interface Templates” menu;
*) winbox - added missing IPv6 mangle actions - “mark-routing”, “sniff-tzsp”, “sniff-pc”, “snpt” and “dnpt”;
*) winbox - added option to upgrade LTE firmware;
*) winbox - changed extension channel symbol to lower case for WifiWave2;
*) winbox - do not allow to set “memory-lines” parameter out of bounds under “System/Logging/Action” menu;
*) winbox - fixed “routing-mark” and “routing-table” selection in IPv4 and IPv6 firewall and route rules;
*) winbox - fixed private SSH key import;
*) winbox - made “0” the default value for GPS “init-channel” parameter;
*) winbox - made SSID field collapsible for WifiWave2;
*) winbox - moved “RPKI” tab from “Routing/BGP” to “Routing/RPKI” menu;
*) winbox - moved “Tables” tab from “IP/Route” to “Routing” menu;
*) winbox - moved all interface stats columns to the right;
*) winbox - properly load all backups stored in Cloud;
*) winbox - properly show “value” parameter for FWD type entries;
*) winbox - renamed “Backlight” to “OK” under “LCD/Backlight” menu;
*) winbox - renamed “Dst. Address” to “Route Dst.” under “IP/Firewall/Mangle” menu;
*) winbox - replaced “routing-table” with VRF in traceroute;
*) winbox - show “External Antenna” parameter on all Chateau devices;
*) winbox - updated WifiWave2 interface fields and tabs;
*) wireguard - do not consider WireGuard interface as ethernet;
*) wireguard - improved system stability when sending WireGuard packets over EoIP;
*) wireless - adjusted antenna gain on Chateau devices;
*) wireless - improved system stability when changing L2MTU for wireless interfaces;
*) wireless - improved system stability when limiting link throughput via “ap-tx-limit” and “client-tx-limit” parameters;
*) wireless - improved system stability when using nv2 protocol on ipq4019 interfaces;
All released RouterOS v7 changelogs are available here:
https://mikrotik.com/download/changelogs/development-release-tree
