V7.21 [stable] is released!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.21 (2026-Jan-12 14:56):
  • arm64 - allow enabling receive packet steering on /system/resource/irq/rps menu in order to overcome unbalanced CPU load;
  • bgp - allow duplicate router-ids for eBGP sessions (RFC 6286);
  • bgp - always advertise extended nexthop cap for all supported address families;
  • bgp - do not allow iBGP with non-equal ASNs;
  • bgp - fixed l2vpn-cisco decoding (introduced in v7.20);
  • bgp - fixed occasional corruption of MPLS labels in BGP VPN update messages;
  • bgp - fixed route refresh subcode 0 warning;
  • bgp - fixed selection of received BGP VPN routes;
  • bgp - implement RFC 9234 route leak prevention and detection using roles;
  • bonding - added lacp-system-id and lacp-system-priority settings;
  • bonding - fixed lacp-mode=passive;
  • bonding - improved stability for 802.3ad LACP;
  • bridge - expose more DHCP snooping warning logs;
  • bridge - fixed dynamic switch-cpu VLAN creation (introduced in v7.20);
  • bridge - fixed filter and NAT matching with "mac-protocol=length";
  • bridge - fixed missing local MAC after changing protocol-mode setting;
  • bridge - fixed multicast packet receiving on bridge as multicast-router when HW offloading is used;
  • bridge - fixed possible DHCP packet drop caused by the add-dhcp-option82;
  • bridge - fixed possible MVRP issues when STP topology changes;
  • bridge - fixed static host and MDB entry updates on VLAN add/remove;
  • bridge - improved DHCP Option 82 values (circuit-id:"interface-name:vid", remote-id:"bridge MAC address");
  • bridge - improved stability after failed protocol-mode=mstp change;
  • bridge - improved system stability when forwarding traffic with fast-path and bridged interface gets removed or disabled (introduced in v7.20);
  • bridge - properly apply bridge MVRP settings on the fly;
  • bth - added file-share link preview;
  • bth - fixed big file upload;
  • bth - fixed file-share expire after reboot;
  • bth - make user private-key sensitive;
  • certificate - added certificate "trust-store" parameter;
  • certificate - added option to configure built-in trust store (replaced "builtin-trust-anchors" parameter);
  • certificate - added SHA384, SHA512 support for SCEP;
  • certificate - allow ca-crl-host parameter for issued certificates;
  • certificate - fixed incorrect appearance of "invalid-before" and "invalid-after" dates;
  • certificate - improved logging;
  • certificate - on certificate import, added the "issued" flag if the certificate store contains the imported certificate's CA and its private key;
  • certificate - refactored Certificate internal processes;
  • chr - fixed guest OS type "Other Linux (64-bit)";
  • console - added "mvrp" to mac-protocol setting;
  • console - added delimiter parameter to :toarray command;
  • console - added fetch-changelog flag to check-for-updates command;
  • console - added reset command to settings directories;
  • console - added sensitive flag to QR code in WireGuard "show-client-config";
  • console - added show-sensitive option for print command, hide sensitive settings in print output by default;
  • console - changed file id format;
  • console - do not allow to set value as empty for arguments that require selection of a specific list entry;
  • console - do not set values when "setup" command is interrupted;
  • console - fixed :convert from=num on MIPSBE;
  • console - fixed "special-login" setting incorrect channel;
  • console - fixed autocomplete in fullscreen editor to append tabs, spaces, etc;
  • console - fixed empty output in route menus when using "print where gateway";
  • console - improved :toip command to get IPv4 address from IPv4 CIDR address;
  • console - improved :toip6 command to get IPv6 addresses from IPv6 prefixes;
  • console - improved hints for address arguments;
  • console - improved hints for DHCPv6;
  • console - improved printing visuals (column layout and paging);
  • console - improved stability;
  • console - remove unnecessary commands from /ip/hotspot/active menu;
  • console - removed /quickset menu;
  • console - return error values for certain commands if action failed (e.g. /system/routerboard/upgrade);
  • console - show fullscreen script editor completions above hintbar;
  • console - updated "Change your password" to "Change your password (Ctrl-C to skip)";
  • console - updated copyright notice;
  • container - add initial Bluetooth device support;
  • container - added "/app" menu for simple containerized app installation (requires "container" package and enabled "container" device-mode);
  • container - added CPU usage;
  • container - added hosts setting;
  • container - added kill command to send signals (CLI only);
  • container - added option to limit CPUs used by containers;
  • container - added root dir size;
  • container - added run command to allow interactive mode (CLI only);
  • container - added stop-time setting;
  • container - added update command (CLI only);
  • container - allow /tmp tmpfs to be unlimited in size;
  • container - allow app network to be any bridge interface;
  • container - allow to configure extra ENV variables directly in container;
  • container - allow to disable/enable envs and mounts;
  • container - allow to specify mounts directly in container;
  • container - calculate volume sizes;
  • container - convert container mounts setting to mountlists, old mount name becomes list name, list name can map to multiple mounts;
  • container - do not allow layer-dir to be within some containers root-dir;
  • container - enable relevant kernel features to support more container apps;
  • container - fixed error for starting container which consists of large number of layers;
  • container - fixed extract issues;
  • container - fixed VETH when using long interface name;
  • container - general container service stability fixes and improvements;
  • container - have per container layer-dir setting to be able to have separate layer stores for different sets of containers;
  • container - made it possible to set timeout on /container/shell;
  • container - make sure a working directory is created if it does not exist;
  • container - show detailed import status, helps understand long imports;
  • container - show image-id field (CLI only);
  • container - shows app URL and "running" status only when port is open;
  • container - store image import data (allows keeping container after netinstall);
  • detnet - do not try detection on slave interfaces;
  • detnet - fixed unnecessary process starting even when feature is not enabled;
  • dhcpv4-client - don't stop client on unsuccessful client option value change;
  • dhcpv4-server - added "support-broadband-tr101" setting to pass additional Option 82 suboptions to RADIUS server;
  • dhcpv4-server - added setting allowing to select client-id, MAC address and opt82 parameters for dynamic lease addition;
  • dhcpv4-server - allow creating static DHCPv4 leases for VETH interfaces;
  • dhcpv4-server - allow to set other gateway types not just IP for dhcp lease "routes" parameter;
  • dhcpv4-server - improved logging;
  • dhcpv4-server - improved setup wizard prompts relating to DNS;
  • dhcpv4-server - respond with hlen 0 when htype is 8;
  • dhcpv4-server - send RADIUS Accounting Stop messages when interim-update is zero;
  • dhcpv6-client - do not show I flag for disabled client;
  • dhcpv6-client - fixed misleading "couldn't acquire address, continue with prefix only" error when prefix is not even requested;
  • dhcpv6-relay - added "about" error message option;
  • dhcpv6-relay - enable configuration of options that are added to relayed DHCPv6 requests;
  • dhcpv6-server - added accounting to use-radius setting, similar to DHCPv4 server;
  • dhcpv6-server - attempt to extract MAC from DUID for dual-stack purposes when client uses DUID-EN type of DUID;
  • dhcpv6-server - improved event logging messages;
  • dhcpv6-server - improved service stability when receiving DHCP requests for PPP service clients without included IA_PD;
  • dhcpv6-server - include traffic usage statistics when accounting is stopped due to binding expiry and removal;
  • discovery - correctly report PoE dual signature per-pair class;
  • discovery - fixed MNDP IPv6 status reporting;
  • discovery - send out neighbor discovery immediately on IPv4/IPv6 changes;
  • disk - added nvme-tcp-server-nqn setting to be able to explicitly configure NQN, will default to "nqn.2000-02.com.mikrotik:slot" for new configurations;
  • disk - allow only lowercase chars in iscsi-server-iqn;
  • disk - allow to have type=file devices without rose-storage (needed for file based swap);
  • disk - allow to set smb-share only for type=smb;
  • disk - consolidate client states into single field, as each item can be only one type of "client";
  • disk - do not allow setting raid-master when have filesystem;
  • disk - do not allow starting Btrfs replace when replace is suspended;
  • disk - do not delete partition configs on device remove and eject (fixes lost config with unstable hardware);
  • disk - fixed iscsi client;
  • disk - fixed iscsi export disable;
  • disk - fixed issue with double "/" in SMB share path for some clients;
  • disk - fixed SATA eject/scan;
  • disk - fixed SMB mount to be writable by container;
  • disk - fixed write RAID superblock;
  • disk - improved cleanup order to avoid waiting for timeouts on shutdown;
  • disk - improved RDS2216 SATA controller;
  • disk - improved system stability;
  • disk - rename nvme-tcp client name to nqn everywhere symmetrically with server;
  • disk - show NVMe critical warnings;
  • disk - unshare iscsi and nfs client/server ids, add iscsi-server-iqn;
  • disk - update interface type/speed after scan;
  • disk - use default label when nothing specified when formatting from WinBox;
  • dns - added VRF support to ":resolve" command;
  • dns - added VRF support to DNS servers;
  • email - added "certificate-verification" parameter;
  • email - return all errors to console when executed from console;
  • eoipv6,gre6,ipip6 - added "dont-fragment" setting to control packet fragmentation for packet sizes exceeding underlay interface MTU;
  • ethernet - added "unsupported speed" warning for forced 1Gbps, 2.5Gbps, 5Gbps, 10Gbps baseT modes;
  • ethernet - change default L2MTU 1518 to 1596 for RB5009;
  • ethernet - fixed 2.5G-baseT link-partner-advertising on RB5009, hAP ax3, Chateau ax devices;
  • ethernet - improved Ethernet port mapping to ensure a consistent and reliable interface order for wAP ax;
  • ethernet - improved system stability for RB912, RB911 devices;
  • evpn - fixed Ethernet Segment (ES) routes;
  • fetch - added "http-percent-encoding" parameter;
  • fetch - fixed http headers appearance when received payload is empty;
  • fetch - send http-data for any http method;
  • file - distinguish empty mount points from disks;
  • file - improved error messages provided to GUI;
  • file - improved stability and interoperability with WinBox and console;
  • firewall - added "h" flag indicating that firewall service helper is applied for particular connection;
  • firewall - added support for TOS/mask matching for raw rules;
  • firewall - clear relevant masqueraded connection tracking entries on IP address change;
  • firewall - fixed "tls-host" not matching expected hosts;
  • firewall - fixed hotspot value loss on rule enable/disable;
  • firewall - fixed strip-ipv4-options always passthrough;
  • firewall - hide hw-offload setting from devices that do not support it;
  • firewall - improved system stability and memory allocation when using firewall services;
  • firewall - make hw-offload=yes default setting in /ip/firewall/filter menu;
  • firewall - use the highest TTL as timeout value for domain address list entries if multiple domain names resolve to same IP;
  • health - upgraded fan controller firmware to latest version;
  • hotspot - added TOTP support for local hotspot users;
  • hotspot - improved system stability;
  • hotspot - prevent service from starting unnecessarily in the background on export/print commands;
  • ike2 - adapt rekey procedure for compatibility with Libreswan;
  • iot - added LoRa Round Trip Time monitoring support;
  • iot - added Modbus rx-switch-offset parameter which helps offset Rx window;
  • iot - added mqtt disconnect/connect GUI options;
  • iot - added support for Modbus port baud-rates from 9600 to 115200;
  • iot - changed LoRa packet's timestamp format, which fixes duty cycle issues for some servers;
  • iot - improved Modbus multi-write registers handling;
  • ip-service - do not duplicate entries for containers running in same netns;
  • ip-settings - limit IPv4/IPv6 max-neighbor-entries maximum value;
  • ippool6 - added "Valid Lifetime" and "Preferred Lifetime" options and use them when constructing IPv6 address;
  • ippool6 - fixed minor memory leak;
  • ippool6 - log address removal;
  • ippool6 - take into account "subnet-id" when specified on address;
  • ipsec - fixed CHACHA20 typo in log messages;
  • ipsec - support Post-Quantum Pre-shared Key (PPK) with QKD integration (CLI only);
  • ipv6 - added "none" option for IPv6/ND/Prefix when advertising just options, not prefix;
  • ipv6 - added "self" option for IPv6/ND DNS advertise settings;
  • ipv6 - allow to specify on which interfaces to accept Router-Advertisements;
  • ipv6 - do not disable/enable Router-Advertisements functionality based on IPv6/ND configuration;
  • ipv6 - initialize RA receiving when enabled and without any other IPv6 configuration;
  • ipv6 - properly remove SLAAC installed route when prefixes expire;
  • ipv6 - remove SLAAC installed DNS server and route on expire;
  • isis - improved stability;
  • isis - improved system stability when changing passive flag;
  • isis - improved system stability when receiving a hello packet;
  • l3hw - added per-VLAN "l3-hw-offloading" setting and "H" flag for /interface/vlan menu;
  • l3hw - display warning when partial offloading is active (suggest users to use suppress-hw-offloading to control which routes get HW offloaded and which are CPU processed);
  • l3hw - fixed issue with IPv4 ARP and IPv6 neighbor resolve for CRS812;
  • l3hw - fixed partial offloading with /31 routes;
  • l3hw - fixed per-VLAN counters when packets are going through CPU;
  • l3hw - fixed VLAN and VXLAN counters for CRS520 device;
  • l3hw - improved stability and performance during L3HW enable with many routes;
  • l3hw - improvements and optimizations for IPv4 /32 and IPv6 /128 route offloading;
  • l3hw - prioritize local IP address over ARP/neighbor entry with same IP (fixes incorrect packet flow);
  • log - fixed ISO8601 time format;
  • log - fixed memory leak;
  • log - fixed remote logging on remote-protocol configuration change;
  • log - fixed unnecessary file creation when configuring a disabled log action with "target=disk";
  • log - hide irrelevant log action parameters;
  • log - limit firewall log prefix length;
  • log - limit log socket buffer memory size;
  • lte - added "force-delete" command to allow deletion of active eSIM profiles;
  • lte - added additional logging for error reported by modem during APN profile setup;
  • lte - added command to send out EUICC generated notifications manually;
  • lte - added confirmation prompt when deleting eSIM profile;
  • lte - added support for additional D-Link DWM-222 variation (vendor-id="0x2001" device-id="0x7e46");
  • lte - added support for additional Huawei E3372-325 variation (vendor-id="0x3566" device-id="0x2001");
  • lte - added support for R11e-LTE6 v039 firmware release and availability notification;
  • lte - ask for user confirmation before installing eSIM profile;
  • lte - clear SIM not present error when performing modem FW upgrade;
  • lte - discontinued support for RBSXTLTE3-7, further versions will use v7.20 LTE firmware package;
  • lte - do not retry activation for IPv4 and IPv6 APNs on QMI modems if only one address family is assigned;
  • lte - fixed cases where LTE monitor could show abnormalities;
  • lte - fixed LTE interface IPv6 address generation to use EUI-64 (introduced in v7.20);
  • lte - fixed MTU inheritance from master interface in multi-APN setups;
  • lte - fixed MTU setting for AT modems;
  • lte - fixed no re-connection after cellular network requested APN deactivation on Chateau 5G ax R17;
  • lte - force sms-protocol to AT for FG621-EA modem;
  • lte - improved AT modems at-chat control channel handling after modem has closed AT channel unexpectedly;
  • lte - improved modem recovery for Chateau 5G and Chateau 5G R16;
  • lte - improved stability for FG621-EA modem;
  • lte - improved system stability when receiving SMS messages;
  • lte - provide firmware download URL when no LTE package installed on "SXT LTE3-7";
  • lte - relay EUICC generated notifications after profile enable/disable/remove/provision;
  • lte - rework multiapn support for AT modems;
  • lte - unify "SIM not present" status for all modems;
  • macsec - added initial support for hardware-offloaded support (available only on QCA8081 PHY: RB5009, hAP ax3, Chateau ax ether1 port);
  • media - fixed console autocomplete for path parameter;
  • mpls - fixed LDP filter upgrade from v6 where neighbor parameter is not specified;
  • mpls - fixed update of LDP Address message when local addresses change;
  • mpls - properly renew services when LDP transport address changes its state;
  • netinstall - fixed install with old RouterBOOT;
  • ospf - changed nssa-translator default value from no to candidate;
  • ospf - fixed OSPF interface "Standby" state detection;
  • ospf - improved stability;
  • ospf - show interface as separate prop for interface and neighbor;
  • ovpn - fixed OVPN server handling on reboot (introduced in v7.20);
  • ovpn - improved system stability when using cipher=blowfish128;
  • ovpn-server - added support for pushing IPv6 routes;
  • poe-out - added input name hint to poe max-power settings;
  • poe-out - added LED blink on error for RB5009;
  • poe-out - firmware update for 802.3at capable boards (the update will cause brief power interruption to poe-out interfaces);
  • poe-out - fixed CRS354 misreporting approved LLDP power;
  • poe-out - improved firmware update stability;
  • poe-out - improved power-on mechanism for 802.3at capable boards;
  • port - added comment for /port/remote-access (CLI only);
  • port - added support for additional baudrates for USB to serial adapters;
  • port - do not show serial port for ATL 5G R16;
  • port - fixed displaying "baud-rate=auto" on x86;
  • port - fixed export for default serial port name;
  • port - give "gps" prefix for R11e-LR8G and R11e-LR9G GPS ports;
  • ppp - added multi-APN support to ppp-client dialer;
  • ppp - added setting to set BG77 modem cellular connection mode (auto; lte-m; nb-iot) (CLI only);
  • ppp - improved service stability when using IPv6 with DHCP and RADIUS accounting;
  • qos-hw - added "default" flags to default entries;
  • qos-hw - added "mirror-profile" which allows to select profile (traffic-class) for mirrored traffic;
  • qos-hw - always show usage and PFC counters, even when they are zero;
  • qos-hw - fixed counters for ports that are configured with "offline" tx-manager;
  • qos-hw - fixed profile add/remove for CRS812;
  • qos-hw - fixed shared-pools for CRS812;
  • qos-hw - remove unnecessary "offline" tx-manager for CRS812 (not supported by hardware);
  • queue - improved system stability when using SFQ kind of queues;
  • route - added options in /routing/settings to adjust check-gateway=ping timers;
  • route - fixed SNMP output for ECMP routes having interface gateways;
  • route - hide suppress-hw-offload setting from devices that do not support it;
  • route - improved stability;
  • route - improved system stability with multicast routing;
  • route - make check-gateway=ping work on p2p interface gateways;
  • route - removed /routing stats mem-blocks;
  • routerboot - fixed boot MAC for CRS305-1G-4S+ and CRS328-4C-20S-4S+ switches ("/system routerboard upgrade" required);
  • sfp - expose sfp-cmis-module-state to monitor;
  • sfp - filter out non-breakout modes for breakout modules;
  • sfp - fixed "sfp-tx-fault" state indication for CRS520-4XS-16XQ;
  • sfp - fixed combo-mode change for CRS326-4C+20G+2Q+;
  • sfp - fixed missing link up/down notifies;
  • sfp - improved initialization and linking for 25G DAC on CRS812;
  • sfp - improved system stability with some GPON modules for CRS418, CCR2004 and CCR2116 devices;
  • sfp - recognize 40G Active Cable (XLPPI);
  • sfp - remove 40G-baseCR4, 40G-baseSR4-LR4 from sfp-supported list for qsfp28-x-3 interfaces;
  • snmp - added lldpLocChassisId OID;
  • snmp - count only "bound" leases for mtxrDHCPLeaseCount OID;
  • snmp - make lldpLocPortId and lldpLocPortDesc OIDs information consistent with LLDP TLVs;
  • socksify - improved system stability when using Socksify service;
  • ssh - added support for ED25519-SK keys;
  • ssh - improved logging of failed login attempts;
  • ssh - refactored SSH service internal processes;
  • ssh - renamed User SSH keys "key-owner" field to "info";
  • ssh - replaced "always-allow-password-login" with "password-authentication" in SSH settings;
  • supout - added info log entry when autosupout.rif is generated;
  • switch - added dynamic "copy-to-cpu" ACL rule for loop-protect;
  • switch - automatically add local bridge MAC to switch FDB;
  • switch - fixed non-IP multicast packet receive on 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98CX8410 switches;
  • switch - improved HW bond load balancing by adding MPLS labels to transmit hash for 98DXxxxx, 98CXxxxx switches;
  • switch - improved stability on MediaTek switch chips;
  • swos - fixed "allow-from" setting for MIPSBE devices;
  • system - added disks to /system/resource/hardware list;
  • system - detect policy mismatch sooner if script is executed internally by some other service;
  • system - fixed local update package filename generation;
  • system - fixed network header offset for interfaces with MAC (fixes VRRP Tx on IGMP snooping bridge);
  • system - fixed potential configuration loss when available disk space was insufficient;
  • system - fixed saving panic logs to autosupout.rif for ARM CRS3xx devices;
  • system - improved stability when terminating HTTP protocol connection;
  • system - improved system stability when processing different kinds of lists;
  • system - improved system stability when processing GRE packets on TILE devices;
  • system - improved system stability;
  • system - limit number of interface-lists to 244;
  • tr069-client - added LTE link recovery timer setting;
  • tr069-client - allow disabling Device.WiFi.AccessPoint;
  • tr069-client - expose 5G NR signal metrics for the Chateau R17 ax;
  • traffic-generator - added support for injecting pcapng files;
  • undo - do not show internally issued commands in /system/history;
  • undo - show console commands in WinBox/WebFig for /system/history entries;
  • ups - fixed board hibernation shutdown;
  • usb - fixed cases where USB bus order could change on D53 devices;
  • usb - LTE modem and USB-Serial Controller enumeration fix;
  • usb - support video capture devices for arm64 and x86, for passthrough to containers;
  • user-manager - added RadSec support;
  • veth - add container-mac-address setting;
  • veth - added default print brief table mode;
  • veth - added dhcp setting that allows to auto-configure IPv4 address, works when VETH is bridged with other interfaces and there is a DHCP server running somewhere on that network;
  • veth - complain immediately when VETH gateway not reachable, more detailed error message when network setup fails;
  • veth - fixed IP address not appearing in the app menu when VETH uses DHCP;
  • veth - fixed VETH interface not getting an IP address in a vlan-aware bridge containing multiple DHCP servers;
  • veth - show only when container package installed;
  • vrf - added read-only property to IPv4/IPv6 addresses, ARP and IPv6 neighbor;
  • vrf - allow setting comment on default "lo" interface;
  • vrrp - do not show "ttl not 255" warning when received VRRP VRID does not match with configured VRID;
  • vrrp - fixed gratuitous ARP being sent after VRRP is disabled (fixes packet forwarding on HW offloaded bridge after VRRP is disabled);
  • w60g - fixed possible memory leak when an interface is disabled;
  • webfig - added a hint for Undo/Redo buttons;
  • webfig - added Apps menu to login;
  • webfig - added capability to check/uncheck entry tree in skin designer;
  • webfig - added Copy capability;
  • webfig - added missing PPP types to Skin Designer;
  • webfig - added TCP State column for connection tracking table;
  • webfig - check if device is still reachable before disconnect on error;
  • webfig - fixed container config memory high input;
  • webfig - fixed issue where routes and PIM table did not load;
  • webfig - fixed issue where Torch stops running;
  • webfig - fixed name and title store in skins;
  • webfig - fixed new item window name when using skins;
  • webfig - improved mikrotik_logo.svg;
  • webfig - improved service stability after deleting a skin;
  • webfig - increase graph width for better scaling;
  • webfig - increase maximum number size in forms;
  • webfig - make close button as a button instead of link;
  • webfig - make combobox accessible to screen readers;
  • webfig - remember last user in login page;
  • webfig - turn off auto-capitalize and auto-correct for on-screen keyboards;
  • wifi - added "CAP" information field on interfaces view;
  • wifi - added CAPsMAN forwarding support (datapath.traffic-processing=on-capsman);
  • wifi - added configuration parameters relevant to the upcoming WiFi 7 products;
  • wifi - enable configuration of "3gpp-info-raw" and "realms-raw" interworking parameters;
  • wifi - fixed issue when trying to use interface as bonding slave;
  • wifi - fixed multi-passphrase usage in combination with access-list;
  • wifi - fixed possible duplicate values for WPA3 authentication types in scan results;
  • wifi - fixed possible memory leak when failing to start AP on chosen channel;
  • wifi - fixed some CAPsMAN settings to be optional;
  • wifi - improved formatting of FT request action frames;
  • wifi - improved interface stability when encountering authentication failures;
  • wifi - improved stability when capturing data at high rates with wifi sniffer;
  • wifi - increased accounting interval, maximum client entry count for 2.4GHz probe response delay feature;
  • wifi - rename ft-wpa2-eap authentication type to "ft-eap";
  • wifi - split access-list time property in days and time;
  • wifi-mediatek - added Superchannel regulatory profile;
  • wifi-qcom - added Unsolicited BSS Transition Management Request support;
  • wifi-qcom - improved default RTS/CTS policy for CPE station radios;
  • wifi-qcom - multicast-enhance will no longer apply for station mode configured devices;
  • wifi,wireless - include "Event-Timestamp" in RADIUS accounting messages;
  • winbox - added "Last Status" and "Last Address" fields in "Tools/Email" menu;
  • winbox - added file selector for BTH files;
  • winbox - added Forwarding Table in "MPLS" menu;
  • winbox - added missing "SM-DP+ Oid" LTE eSIM provisioning field;
  • winbox - added Sessions tab in "Routing/RPKI" menu;
  • winbox - added support for new settings and fixed several existing ones;
  • winbox - Bandwidth test, Speed test, Ping, Traceroute tools use RouterOS DNS service to resolve domain names;
  • winbox - fixed "Too many entries" not showing in WinBox v4;
  • winbox - fixed Disk iscsi/smb configuration;
  • winbox - fixed Disk NVMe-TCP configuration;
  • winbox - fixed Dude/Tools appearance after Apply action;
  • winbox - fixed graphs in some forms with big numbers;
  • winbox - fixed Keepalive Time format in "Routing/BGP" menus;
  • winbox - fixed Preshared Key "auto" and "none" options for WireGuard Peer;
  • winbox - fixed switch QoS monitor for mirror properties;
  • winbox - hide certificate "Issuer" field for certificate template;
  • winbox - hide IPv6 addresses for IP neighbors that no longer have them;
  • winbox - make multiple address fields required;
  • winbox - make separate inputs for WiFi Interworking "Authentication Types" and "Connection Capabilities" fields;
  • winbox - make VETH gateway fields not required;
  • winbox - move VRF from Ethernet to generic Interface table;
  • winbox - removed "Add" for dynamic DNS servers;
  • winbox - reorder BGP and OSPF tabs in logical order;
  • winbox - restore route max object 10000 limit;
  • winbox - show "Trusted" field for certificate template;
  • winbox - show warnings in "Routing/BGP" menus;
  • winbox - show warnings in Disk menu;
  • winbox - updated and shortened window titles (e.g. Address List -> Addresses);
  • wireguard - added VRF option (CLI only);
  • wireguard - allow to add AllowedIPs configuration for client configuration template;
  • wireless - added last-ip parameter for the CAPSMAN registration-table tab;
  • wireless - improved system stability when stopping scan process;
  • www - added option to disable individual web services in /ip/service/webserver and IP>Services>Web Server;
  • www - handle escaped characters in resource IDs and names for REST API requests;
  • www - process REST API requests only after user authentication is completed;
  • www - removed ability to publish directories via "/files" www service;
To upgrade, click Check For Updates under System/Packages menu and select the stable Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
  • Everything went smoothly
  • I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
  • I encountered an issue, but solved it (please post the solution)
0 voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
Stable? You're sure?
I am not sure yet. But feels like release have a problems with leaked VRF routes .
Update: Not, it is not have issues with it
Why RPS is disabled by default? Is there any risk by enabling it for all interfaces?
7.21 broke my ipv6 connectivity and had to downgrade to 7.20 to resolve this.
It's yet to be seen on which devices RPS actually makes notable change ... might be it only makes change on ARM CHRs with many CPU cores ... in this case it would make sense to have it disabled by default not to cause potential problems on the rest of ARM64 devices where it wouldn't make any notable difference otherwise.
ipv6, yes
wg too
and somes srcnat
80 pre-packaged apps already available, so users will start asking for more memory.
Please publish changelog between rc6 and final.
It's called Hap BE3
There are no changes between rc6 and final.
Please create new topic for comments such as this, it does not help us or the community to identify the issues with this release. If you do find an actual problem, please post about it, include your configuration export and device model.
So i can't use my nfs then for APP's ?
Saw this typo after upgrading/ rebooting:
Other than that everything seems to work :wink:
About apps, we made a video (fingers crossed for an Oscar):
https://www.youtube.com/watch?v=0ChcSIShJk0
It may be that your IPv6 addresses have changed, due to a change in how IPv6 assignment “from pool” is working. I made a ticket (actually for 7.22beta1 which has the same issue) but no reply yet.
The problem is that in the past, subnet could not be specified and subnets were assigned from 0. So when you had 4 interfaces with a “from pool” address, they were assigned subnets 0, 1, 2 and 3.
Now, the 1, 2 and 3 are pinned to those subnets, but subnet 0 will not be pinned and that interface will now get subnet 4. That may cause issues with e.g. firewall config. It may also cause connected devices to lose their address.
Upgrading from 7.20.6 to 7.21 on my 750gr3, I noticed these configuration changes that seem significant.
Dropped the "hw-offload=yes"
7.20.6
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
7.21
Dropped the "advertise-dns=no"
7.20.6
/ipv6 nd
set [ find default=yes ] advertise-dns=no ra-lifetime=2h30m
7.21
/ipv6 nd
set [ find default=yes ] ra-lifetime=2h30m
I also notice these notes:
So does that mean that the 750gr3 didn’t support hw-offloading afterall?
The “advertise-dns=no” also disappeared. Not sure why.
No, it never did and (quite certainly) never won't.
List of L3HW-capable devices is published in L3HW offloading guide.
Mind that in context of firewall, being L3 entity, talking about hardware-offload, of course means L3HW offload. L2 (bridging) offload is a pretty different thing ... and RB750Gr3 does support it.
This release makes the router unavailable via IP address. Can't connect via WinBox using IP address, only MAC connection works. Also, if the router is used as a gateway to reach other addresses, these addresses are also unavailable through it. No problems with 7.22beta1 though. Tried to switch between 7.21 and 7.22beta1 multiple times - always same result - 7.22 works, 7.21 doesn't. mipsbe device.
Definitely, not stable release at all.
It is a configuration issue that is present in your router but not a generic property of 7.21
