V7.22 [stable] is released!
Before an upgrade:
  2. Make sure the device will not lose power during upgrade process;
  3. Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.22 (2026-Mar-09 10:38):
  • ! certificate - added support for multiple ACME certificates (services that use a previously generated certificate need to be reconfigured after the certificate expires);
  • ! device-mode - added option to configure device-mode via Netinstall or FlashFig using a “mode script”;
  • app - added configurable app-store URL for custom apps;
  • app - added health check for apps, which automatically rewrites the composed YAML;
  • app - added jupyter-notebook, livebook, myip, and rustfs apps;
  • app - added support for custom apps;
  • app - allow configuring bridge port pvid for app;
  • app - changed ui-url parameter for Smokeping and Nextcloud;
  • app - clean the backup directory after container repull;
  • app - do not show duplicate entries of required-mounts;
  • app - enable swap on all devices that use apps to help with performance;
  • app - fixed /app/export;
  • app - fixed apps constantly polling the cloud;
  • app - fixed elasticsearch, element, pmacct-netflow apps failing to start;
  • app - fixed issue with Cinny not being able to create a root-dir;
  • app - fixed missing reverse-proxy URL;
  • app - fixed potential port collisions between apps;
  • app - show app URL only when it is running;
  • app - show DNS URL for app only if it has a reverse-proxy;
  • bgp - added BGP unnumbered support;
  • bgp - changed multipath to number argument;
  • bgp - fixed BGP output sometimes not being cleaned after session restart;
  • bgp - fixed early-cut not working properly;
  • bgp - fixed ignore-as-path-len not being used;
  • bgp - fixed update messages not being sent on default-prepend value change;
  • bgp - implemented add-path;
  • bgp - implemented multipath (ability for BGP best path to select ECMP routes);
  • bgp - make remote.address parameter optional;
  • bgp-vpn - allow modifying scopes with routing filters;
  • bgp-vpn - use target scope for imported route;
  • bridge - added local and static MAC synchronization for MLAG;
  • bridge - added MLAG support per bridge interface (/interface/bridge/mlag menu is moved to /interface/bridge; configuration is automatically updated after upgrade; downgrading to an older version will result in MLAG configuration loss);
  • bridge - added MLAG-specific aged and aged-peer flags to host table;
  • bridge - added RA guard feature;
  • bridge - fixed MAC moving between regular ports and bonds for MLAG;
  • bridge - fixed MLAG state being permanently disabled when changing bridge interface settings;
  • bridge - fixed performance regression in complex setups with vlan-filtering (introduced in v7.20);
  • bridge - improved logic for interface remove;
  • bridge - improved MAC synchronization for MLAG;
  • bridge - improved VRRP MAC address handling;
  • bridge - removed vlan-filtering check when changing the MVRP setting (allows disabling MVRP through WinBox);
  • bth - use separate Let's Encrypt certificate for file-share;
  • certificate - improved certificate export process;
  • certificate - improved logging;
  • chr - improved fast-path stability when using vmxnet3 driver;
  • console - added :continue and :break commands for various loops;
  • console - added :exit command to terminate scripts;
  • console - added "comments" parameter to print command to control comment and error output;
  • console - added comparison operators for ID values;
  • console - added Ctrl+Left/Right word navigation;
  • console - added Ctrl+w word deletion;
  • console - added hint for dry-run import parameter;
  • console - added left shift (<<) and right shift (>>) support for IPv6 addresses;
  • console - added on-event script runner support to print follow/follow-only;
  • console - added timestamp support to print follow/follow-only;
  • console - allow undefined variables in dry-run import;
  • console - changed autocomplete expansion criteria;
  • console - disable follow command in /ip/firewall/connection menu;
  • console - fixed brief print for entries with multiple comments;
  • console - fixed setting of /interface/wireless/scan-list;
  • console - fixed time drift for interface last-link-down-time and last-link-up-time;
  • console - fixed value type names in comparison errors;
  • console - implemented string casting in :tobool command;
  • console - improved command decoding to drop extraneous commands (visible in history logging);
  • console - improved error tracing when using find command;
  • console - improved export command to avoid empty [find];
  • console - improved history logging when performing object rename with set/reset;
  • console - improved set/remove command handling in /file menu;
  • console - look up variable in global scope if argument scope lookup failed;
  • console - parse width parameter for non-interactive SSH commands;
  • console - show smaller QR codes where possible;
  • console - use the same flag output format for both print brief and detail;
  • container - added support for zstd extraction;
  • container - automatically stop/repull/start the container on repull or remote-image change;
  • container - fixed issue where the container may not start after upgrading if root-dir was not set;
  • container - improved error message if container fails to start;
  • container - internal stability improvements;
  • container - use the user-defined envs and envlist for container shell command;
  • defconf - fixed L009 configuration (introduced in v7.21);
  • detnet - added request-interval setting;
  • detnet - changed default port from MNDP to a random unused UDP port;
  • dhcp-server - improved failure/error logging for both IPv4 and IPv6;
  • dhcpv4-client - fixed inability to reference disabled DHCP client by interface name;
  • dhcpv4-client - request DOMAINNAME (15) option from the server;
  • dhcpv4-server - improved DHCP option handling;
  • dhcpv4-server - improved logging;
  • dhcpv4-server - send all found lease options in reply to DHCPINFORM;
  • dhcpv6-client - allow unsetting "pool-prefix-length" parameter;
  • dhcpv6-client - improved log messages;
  • dhcpv6-relay - fixed link-layer address inconsistency with the original link-layer address in relay-forward packets;
  • dhcpv6-server - swap input and output RADIUS accounting statistics counters;
  • disk - added support for file-based swap space;
  • disk - added trim command which functions similarly to fstrim;
  • disk - fixed issue where iSCSI did not work with ESXi and XEN hypervisors;
  • disk - fixed issue with disks not mounting after swapping devices;
  • disk - fixed opening a drive in read-only mode if it became locked;
  • disk - improved BTRFS stability on TILE devices;
  • disk - renamed format file-system=trim and trim-secure to format file-system=discard and discard-secure;
  • disk - show if drive is encrypted and locked;
  • email - use default port if not specified;
  • ethernet - increased Rx buffer size for devices with Alpine CPUs (reduces packet rx-drop in certain cases);
  • fetch - added HTTP/2 support on ARM64 and x86/CHR devices;
  • fetch - fixed fetch treating relative paths from redirects as hostnames;
  • fetch - increased default maximum redirect count to 2;
  • fetch - return error code and HTTP headers to :onerror script;
  • fetch - treat HTTP 304 return code as success;
  • gps - fixed GPS port disappearance after reboot for EC25-EU&KNe;
  • health - added CPU temperature monitoring to L009 with ARM64;
  • hotspot - allow WireGuard interface type;
  • hotspot - check validity of base32 for otp-secret;
  • hotspot - do not invalidate static ARP entries;
  • hotspot - fixed www response after login by cookie;
  • hotspot - set sensitive flag on /ip/hotspot/user otp-secret;
  • ike1 - added ChaCha20-Poly1305 ESP encryption support;
  • ike1,ike2 - improved netlink update handling;
  • iot - added Bluetooth extended scanning and 1M/2M PHY support for the RB924i KNOT devices;
  • iot - added Bluetooth extended scanning, advertising, and 1M/2M/CODED PHY support for EC25 KNOT devices;
  • iot - added modbus delay using interframe-gap setting;
  • iot - improved LoRa FSK modulation downlinking;
  • ip - added error messages to reverse-proxy rules;
  • ip - added reverse-proxy;
  • ip-service - properly disable IP/Service on manual disable;
  • ippool6 - allow creating sub-pool by specifying "from-pool";
  • ipsec - added "none" option to IPsec key QKD certificate field;
  • ipsec - added IKEv2 DDoS cookie activation setting;
  • ipsec - added logging for IPsec policy template group;
  • ipsec - added logging of IKEv2 connection SPI and initiator address;
  • ipsec - adjusted minimum generated PSK key length;
  • ipsec - fixed IKEv2 child policy reqid lost on rekey;
  • ipsec - fixed IKEv2 child reqid handling on traffic selector update;
  • ipsec - improved aes256-ctr stability on L009;
  • ipsec - removed modp8192 proposal on MIPS architectures;
  • ipv6 - added dhcp6-pd-preferred to /ipv6/nd/prefix to control P flag in Prefix Info Option RFC 9762;
  • ipv6 - delete SLAAC default route if there are no active SLAAC prefixes present and no new RAs received;
  • ipv6 - do not generate duplicate dynamic link-local addresses on tunnel type interfaces;
  • ipv6 - enable IPv6 fast-path after removing firewall rules;
  • ipv6 - improved system stability when manipulating IPv6 configuration that was added while IPv6 was disabled;
  • isis - improved stability and fixed a small memory leak;
  • l2tp - improved system stability on TILE architecture;
  • l3hw - fixed missing VLAN counters on reboot (introduced in v7.21);
  • l3hw - improved system stability on device shutdown/reboot;
  • l3hw - improved system stability when enabling VLAN offloading under active traffic (introduced in v7.21);
  • log - added comment support to rule entries;
  • log - added option to clear echo logs;
  • log - added option to prepend topics to BSD syslog message;
  • log - added script target for log actions;
  • log - fixed incorrect log message shown after canceling supout.rif creation;
  • log - fixed minor spelling issues;
  • log - fixed missing ID in trace logs after removing logging rule;
  • log - log "Secret must be set to run scripts from SMS" error only if ":cmd" prefix is used in SMS message;
  • log - use uppercase MAC address in firewall logging;
  • lte - added "auto" MTU option for LTE interfaces to use network-advertised MTU on supported devices;
  • lte - added AT command timeout for EC25-EU&KNe;
  • lte - added multi-apn and framed routing support for EC200A-EU modem (requires latest FW version);
  • lte - added roaming barring field to LTE "show-capabilities" menu;
  • lte - added subscriber number to monitor command for MBIM modems;
  • lte - added USB tethering support using iOS devices;
  • lte - clear about field status on firmware upgrade;
  • lte - do not allow modem firmware-upgrade on "inactive" interface;
  • lte - do not allow setting unsupported roaming barring settings for R11e-4G;
  • lte - do not flap LTE passthrough assigned interface on modem link state change;
  • lte - do not reconfigure LTE interface on configuration change error;
  • lte - enable DHCP relay packet forwarding to the cellular network for EG120K-EA and RG650E-AU;
  • lte - fixed "allow-roaming" setting to return error for modems that do not support roaming barring;
  • lte - fixed cases where AT dialer could get stuck in "modem not ready" state;
  • lte - fixed cases where incorrect network modes and bands could be suggested for active interface;
  • lte - fixed chained firmware update for Chateau 5G;
  • lte - fixed changing eSIM profile nickname;
  • lte - fixed changing MAC address for EC200A-EU modem;
  • lte - fixed crash on LTE passthrough interface deactivation;
  • lte - fixed displaying operator name for Chateau ax R17;
  • lte - fixed eSIM errors appearing on devices without eSIM support;
  • lte - fixed firmware update and status refresh for R11eL-EC200A-EU modem;
  • lte - fixed LTE interface IPv6 address generation to use EUI-64 for EC25-EU&KNe;
  • lte - fixed missing notifications to eSIM provider when eSIM provisioning canceled;
  • lte - fixed tethering support for Google Pixel Pro 8;
  • lte - fixed wrong MTU reading/setting for config-less modems;
  • lte - hide external antenna selection menu for the Chateau AX R17;
  • lte - improved APN IP type handling by enabling only the IP protocols defined in the assigned APN profile for config-less modems;
  • lte - make inactive LTE interface settable, LTE interface settings can be set without waiting for modem initial initialization;
  • lte - removed delay before querying modem status for config-less modems with info channel;
  • lte - show ICCID and IMSI also when the interface is disabled;
  • lte - strip modem reported padding characters for SIM card (ICCID) on Chateau ax R17;
  • mac-telnet - added interface property;
  • macsec - fixed hardware offload on S53 and C53 devices;
  • mesh - fixed missing S flag on interfaces after mesh disable/enable;
  • ospf - fixed typos in log messages;
  • ping - added IPv6 support for flood-ping;
  • poe-out - added LLDP support for dual-signature PDs;
  • poe-out - firmware update for 802.3at capable boards (the update will cause a brief power interruption to poe-out interfaces);
  • poe-out - firmware update for 802.3bt capable boards (the update will cause a brief power interruption to poe-out interfaces);
  • poe-out - firmware update for CRS354-48P-4S+2Q+ (the update will cause a brief power interruption to poe-out interfaces);
  • poe-out - fixed controller-error for CRS354-48P-4S+2Q+;
  • port - fixed baud rate change for TILE architecture devices;
  • ppp - added initial support for BG770A-GL modem firmware update;
  • ppp - fixed Framed-Route attribute not being applied to correct VRF;
  • profiler - split "management" process into different smaller process groups;
  • radius - fixed initialization of incoming UDP socket in some situations;
  • radius - fixed RadSec SSL CPU usage increase on closed connections;
  • radius - improved incoming RadSec packet processing on busy service;
  • radius - improved logging;
  • rip,pimsm - separate the interface property from the address in /routing/rip/interface and /routing/pimsm/interface menus;
  • rose-storage - added XFS support;
  • route - added logs for check-gateway state changes;
  • route - added routing/settings policy-rules;
  • route - added SLAAC route redistribution for IPv6 capable routing protocols;
  • route - do not set blackhole flag for synthetic routes;
  • route - fixed route removal after unexpected safe mode termination;
  • route - fixed routes when scope was less than 10;
  • routerboard - allow changing /system/routerboard/settings via Netinstall or FlashFig using a "mode script";
  • routerboot - allow installing ARM64 on L009 device ("/system routerboard upgrade" required; configure "/system/routerboard/settings set preferred-architecture=arm64 boot-device=try-ethernet-once-then-nand"; start Netinstall with ARM64 image and reboot the device (DO NOT load the backup routerboot with reset button); downgrading to older versions must be avoided);
  • routerboot - fixed linking to 1000M-half for KNOT Embedded LTE4 ("/system routerboard upgrade" required);
  • routerboot - fixed possible Netinstall failure for KNOT Embedded LTE4 ("/system routerboard upgrade" required);
  • routing-filter - added possibility to match SLAAC and bgp-mpls-vpn route types;
  • sfp - improved initialization and linking for some QSFP modules;
  • smips - reduced package size and removed ip-scan, mac-scan, ping-speed, flood-ping features;
  • snmp - added 5G NSA connection signal indications: nr-rsrp, nr-rsrq, nr-sinr;
  • snmp - fixed CA band indication;
  • snmp - fixed issue where bulk walk might skip the first OID;
  • snmp - fixed minor memory leak when changing SNMP authentication/encryption passwords;
  • snmp - fixed reply for empty snmpbulkwalk requests;
  • snmp - report maximum "ifSpeed" value if out of bounds;
  • snmp - report RouterOS version in SNMPv2-MIB::sysDescr;
  • ssh - improved logging;
  • supout - wait up to 5 minutes for export to complete and show incomplete output in case of timeout;
  • switch - fixed missing switch-cpu port counters;
  • switch - improved system stability when changing bridge multicast-router property on CRS1xx/2xx (introduced in v7.19);
  • switch - updated switch-marvell.npk driver;
  • system - added reset-configuration keep-apps=yes;
  • system - display serial ports in the /system/resource/hardware menu;
  • system - improved upgrade service stability when the server is unreachable;
  • undo - show user when configuring DHCP server or hotspot with setup command;
  • upgrade - added "password" parameter to "local-upgrade" feature when configuring through CLI;
  • upgrade - added IPv6 support for local package source and mirror;
  • upgrade - fixed local package mirror check interval;
  • upgrade - removed redundant commands from local package menu;
  • usb - updated device ids for ax88179_178a driver;
  • user - properly apply login delay (introduced in v7.20);
  • user-manager - added support for NAS-Identifier attribute;
  • user-manager - always respond to accounting requests;
  • user-manager - do not send Disconnect-Message for unknown usernames for Accounting-Request;
  • user-manager - do not send invalid NAS-Port-Type on CoA/PoD messages;
  • user-manager - fixed unauthenticated access to /PRIVATE/ userman web files;
  • user-manager - show empty value for session NAS-IP-Address if empty;
  • webfig - added missing icons for Firewall table;
  • webfig - added new section "Common names" in skin designer;
  • webfig - added support for collapsible tree view for menus like Interfaces, Files, Queues;
  • webfig - added support for URL fields;
  • webfig - fixed ability to set interworking.realms-raw WiFi interface attribute;
  • webfig - fixed skin designer mobile view for QuickSet and Terminal;
  • webfig - fixed Torch Filters default values;
  • webfig - improved address type field input value validation;
  • wifi - added keepalive message in CAPsMAN data channel;
  • wifi - added optional show-frame=radiotap parameter value to make sniffer display the radiotap header of captured frames;
  • wifi - allow specifying hostname to caps-man-addresses;
  • wifi - fixed channel switching for MediaTek access points;
  • wifi - fixed FT support with wpa2-psk-sha2;
  • wifi - fixed functionality of the wireless-signal-strength LED trigger;
  • wifi - fixed possible certificate failure after CAPsMAN disable/enable;
  • wifi - improved spectral-history width for console;
  • wifi - improved stability and fixed multiple issues;
  • wifi - improved stability of interfaces in station mode during roaming;
  • wifi - improved support for 802.11be access points;
  • wifi - improved system stability when using spectral-scan;
  • wifi - introduced /interface/wifi/network menu for higher level network configuration (CLI only);
  • wifi - quicker re-connections to APs for interfaces in station mode;
  • wifi - updated regulatory information for Malaysia;
  • wifi-mediatek - fixed rx chains functionality;
  • wifi-mediatek - updated driver and firmware;
  • winbox - added "Force Check" for local upgrade;
  • winbox - added comment in "System/Ports/Remote Access" menu;
  • winbox - added confirmation message to Format Drive;
  • winbox - added Container Repull command;
  • winbox - added error reporting to CAPsMAN Manager menu;
  • winbox - added GUI support for IPsec QDK;
  • winbox - added missing LoRa channel fields;
  • winbox - added missing route flags;
  • winbox - added route ISIS tab;
  • winbox - added socsify icon for firewall NAT rules;
  • winbox - added SwOS Allow From field;
  • winbox - added warning when changing global script variables;
  • winbox - allow using specified skin without the sensitive policy;
  • winbox - fixed applying a skin to a user authenticated with RADIUS;
  • winbox - fixed applying a skin to WinBox if it was uploaded via the branding package;
  • winbox - fixed default flag in certain menus;
  • winbox - fixed empty "Realm Raw" value processing and value inheritance from configuration template (requires WinBox 4);
  • winbox - fixed L3HW default value for VLAN interface (introduced in v7.21);
  • winbox - fixed modem firmware-upgrade for the RG650E-EU modem;
  • winbox - fixed the "New QoS Profile" field for switch rules;
  • winbox - make File Share URL field clickable;
  • winbox - move "Default" panel from "IPv6/ND/Proxy" to "IPv6/ND/Prefixes";
  • winbox - rearrange filter wizard parameters in tabs;
  • winbox - recognize imported certificate key size;
  • winbox - rename "Change Now" to "Change" button in "System/Password" menu;
  • winbox - replace "DHCP" with "DHCPv6" in IPv6 menus;
  • winbox - set "Mount Filesystem" by default under "System/Disk" menu;
  • winbox - show MPLS tab only to relevant routes;
  • winbox - show separator after "Protocol" field for IPv6 Firewall rules;
  • winbox - show warnings in "MPLS/Traffic Eng/Tunnel" menu;
  • winbox - updated some setting and title names;
  • winbox - updated various WiFi properties;
  • wireguard - fixed private key generation when creating a WireGuard interface;
  • wireguard - improved stability;
  • wireguard - merged upstream fixes and improvements;
  • wireless - avoid joining BSS that previously failed until all other options tried;
  • wireless - improved system stability when changing nstreme mode;
  • wireless - improved system stability when eap-method=passthrough configured for station;
  • x86 - added JME network driver;
  • x86 - fixed interface hang on RTL8125 when processing IP-fragmented UDP traffic;
  • x86 - improved link establishing on Intel X710 series NIC;
To upgrade, click Check For Updates under System/Packages menu and select the stable Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
  • Everything went smoothly
  • I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
  • I encountered an issue, but solved it (please post the solution)
0 voters
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
wifi-qcom-ac - split into two packages, to help devices with only 16MB storage (manually remove the old driver, then install appropriate new)
Noo, who needs this anyway :frowning:
Hello everybody,
I 've performed an upgrade from V7.21.3 to V7.22 on my RB5009 and CRS310 (both running RouterOS v7.21.3). After the upgrade, the CRS310 lost its ability to reach the internet (e.g., ping 1.1.1.1 failed with "no route to host"), even though it had local connectivity to the RB5009.
Setup:
  • Core: RB5009 (IP: 192.168.10.1)
  • Switch: CRS310-1G-8S+in (IP: 192.168.10.2)
  • Interconnect: 2-port Bonding (LACP) named RB5009-to-CRS310.
  • VLANs: Management IP sits on vlan1-base.
The Issue: Before the upgrade, the switch had internet access without an explicit static route. After the upgrade to the latest v7, the routing table only showed connected routes: DAcH 192.168.10.0/25 vlan1-base 0
I had to manually add the following to restore connectivity: /ip route add dst-address=0.0.0.0/0 gateway=192.168.10.1
Is this the expected behavior?
Thanks!
@Edpa, is the excessive sector writing to disk, addressed in this release, didnt see it?
Assuming the CRS310 gets its IP config from the RB5009 using DHCP (otherwise it hardly would ever have worked without adding a default rout), I suggest to check the add-default-route parameter of the DHCP client.
If set to yes (default), the DHCP client will add the default route received as system wide default route, marked with [D] for dynamic.
Thanks for the suggestion. However, the CRS310 (and a daisy-chained CRS304) were both using static IP configurations, not DHCP.
Adding the static default route /ip route add dst-address=0.0.0.0/0 gateway=192.168.10.1 resolved the issue instantly on both switches.
Thanks!
What’s up with the Wireless icon? Why the white background?
whatsupwiththis
Please, Mikrotik. Look at this
For manual IP configuration, having to set a default route to reach "the internet" is obviously to be expected.
The question remains how it worked without before.
I am sorry to report, but the handling of the ACME certificates in this release version is still very far from okay.
I've reported about my issues where the router tries after each reboot to create a new ACME certificate and to contact Let's Encrypt and fails because incoming connection to port 80 is not allowed.
I was told that this is the attempts that the router makes to automatically migrate old certs issued with /certificate/enable-ssl-certificate to the new /certificate/add-acme facility.
So with the release of 7.22rc4, I did this on my routers:
  • Enable www and open the firewall and use /certificate/add-acme to properly get an certificate issued. This certificate has the K and a flag, with the correct domain.
  • That certificate was then assigned to www-ssl.
  • The previous old certificate (the one made with /certificate/enable-ssl-certificate) is removed. There are no other ACME certificate in the certificate list, except for the one newly issued with /certificate/add-acme.
But now, today, after the upgrade from 7.22rc4 to 7.22 stable, and the reboot, once again I see this appearing in the certificate list!
And the corresponding log entry in the log.
WHY???? The current certificate associated with www-ssl is still there and active, is only 3-days old, it has the new a flag, as well as acme-status="acme cert updated successfully". Why did RouterOS want to request a new certificate again right after the upgrade to 7.22 stable? The certificate issued under 7.22rc4 still has 86 days validity left.
Winbox 4.0.1 on Linux with ROS 7.20.8 fast login on CHR.
ROS 7.22 gives “reading the index file” for 5 seconds and then continues to login.
Turning back solves the slower login.
@sinisa Where did you see this
I don’t see it in the changelog (unfortunately!)
I think that was sarcasm :wink:.
I am seeing the same behaviour on my devices (rb5009, crs326 etc.). It is especially apparent when accessing remote devices over a wireguard tunnel.
It appears winbox is spending a little longer on “reading index file” before logging in. Not the end of the world for me but an interesting change.
Bridge vlan-filtering performance regression fix (from v7.20) — Real-world impact?
The changelog mentions:
For those running multi-VLAN setups (e.g., ISP triple-play with Internet/IPTV/VoIP VLANs on SFP stick + bridge), this is significant.
Questions for the community:
  1. Has anyone benchmarked the throughput improvement after upgrading from 7.20/7.21 to 7.22 on vlan-filtering bridges?
  2. Were there any noticeable latency issues with IPTV multicast on 7.20/7.21 that are now resolved?
  3. For RB5009 users with multiple VLANs on SFP — any measurable difference?
I've been running 7.21.3 on RB5009UG+S+ with 4 bridged VLANs (Internet, IPTV, VoIP, Management) over XPON SFP stick. Curious if anyone noticed degraded performance since 7.20 and whether 7.22 actually fixes it.
I had been having similar problems in different circumstances. I would suggest to start diagnosing these delays by doing packet capture on tunnel interface. I suspected something related to MTU, but it was not - I was having ECE and CWR flags ans subsequent retransmissions a lot. As that is not related to 7.22 I would not discuss it further around here - it is just a suggestion how to approach the problem.
See this answer:
How did you come to this conclusion?
Hello @qatar2022
I am currently running an RB5009 as my main router, linked to a CRS310 (via LACP Bonding) which is connected to a NAS (via SFP+) and also to several CRS304 switches. All of them are running v7.22 with a multi-VLAN configuration.
I haven't observed any throughput degradation or latency spikes that were noticeable enough to trigger a manual benchmark during the recent upgrade cycles (7.20 through 7.22). In my setup, inter-VLAN traffic and high-bandwidth NAS transfers have remained stable and consistent.
