Before an upgrade:
- Remember to make backup/export files before an upgrade and save them on another storage device;
- Make sure the device will not lose power during upgrade process;
- Device has enough free storage space for all RouterOS packages to be downloaded.
What's new in 7.24 (2026-Aug-14 11:33):
- adlist - improved service stability when adjusting adlist configuration;
- app - added "HF_TOKEN" env to openwebui;
- app - added "network-outgoing-access" parameter which does not allow app to make outgoing connections;
- app - added hermes-agent, inventree, opencloud, opencloud-extended apps;
- app - added PAPERLESS_SECRET_KEY env to paperless-nginx;
- app - allow "reset" even if disk not configured;
- app - allow HTTP for Gitea when "check-certificate=no";
- app - allow setting "working_dir" in app YAML;
- app - changed pmacct-netflow YAML;
- app - disable UI in Hermes, access through /container/shell;
- app - fixed apps not updating firewall redirects when changed in YAML;
- app - fixed apps sometimes getting stuck on "waiting for layer";
- app - make secrets sensitive to avoid polluting configuration export;
- app - removed healthcheck from opencloud-extended-collabora;
- app - reserve the app's VETH IP when stopped to eliminate IP address changes on every start/stop;
- app - show CHR's address instead of the container's;
- app - use randomly generated secrets in new apps;
- bgp - fixed EVPN label corruption and corrected EVPN type-5 output;
- bgp - improved stability when receiving malformed packets;
- bgp - removed "save-to" from "resend" command;
- bgp-vpn - fixed blackhole route export;
- bridge - added "querier-uses-bridge-address" setting to use bridge source IP address for IGMP querier;
- bridge - added DHCPv4 snooping IP binding table;
- bridge - added scheduling point during VLAN processing to prevent soft lockups when flushing FDB over large VLAN ranges;
- bridge - fixed forwarding through peer-port after disabling MLAG;
- bridge - fixed local static host entries;
- bridge - fixed MLAG MAC address handling issues related to aging, flushing and moving;
- bridge - fixed stability issue when using DHCPv4 snooping;
- bridge - fixed stuck MLAG session when using mismatched L2MTU (introduced in v7.23);
- bridge - improved bridge and port STP "priority" setting (warn when a non-compliant value is used and allow selecting a value from a list);
- bridge - improved STP, BPDU and topology change handling with MLAG, ensure dual-connected port STP state is in sync with MLAG peer;
- btest - added VRF support for bandwidth-test and speed-test;
- certificate - added "acme-renew" command;
- certificate - general improvements in certificate handling;
- certificate - use AES encryption when exporting certificates in PKCS#12 format;
- console - added "days" to scheduler;
- console - added "in" and "has" operators for array types;
- console - added "order-by" parameter to "print" command, allowing sorting by up to three arguments in ascending or descending order;
- console - added comparison operators for array type;
- console - added log tracing when scripts fail to start due to permissions;
- console - do not terminate self-removing scripts;
- console - fixed "print follow on-event" script runner command not showing all argument values in some cases;
- console - fixed argument mappings in "do" block for monitor commands;
- console - fixed proplist order in monitor commands;
- console - fixed script import/export with empty "policy" setting;
- console - fixed stability issue in full-screen editor;
- console - fixed UTF-8 comparisons on some architectures;
- console - improved "print detail" mode;
- console - improved script handling and error logging when running scripts from external sources (e.g. DHCP, SNMP, Netwatch, etc.);
- console - make "mac-auth-password" sensitive in "/ip/hotspot/profile";
- console - make "password" sensitive in "/system/package/local-update/mirror";
- console - produce runtime errors for bad command parameters;
- console - prompt about and offer to stop already existing serial terminal session when opening new one;
- console - renamed "address" to "available-from" in "/ip/service" (backwards compatible via deprecation);
- console - renamed "reauth-timeout" to "reauth-period" in "/interface/dot1x/server" (backwards compatible via deprecation);
- console - restrict editing comments in WiFi registration table;
- container - added "save" command to allow saving container images;
- container - added "swap-current" usage;
- container - added "swap-max" global and per-container limit;
- container - added ability to run containers in privileged mode;
- container - added initial support for RKE2;
- container - do not allow starting with empty default DNS list and no DNS override;
- container - do not print environment variables in log on container startup;
- container - fixed "start-on-boot" not retrying on certain startup errors;
- container - fixed container "devices" override to appear under "/dev";
- container - improved layer size calculation to avoid potential loops;
- container - improved support for containers;
- container - reduced writes to flash when running health check;
- container - use env "TERM=xterm" if no TERM variable provided when running shell;
- crypto - fixed hardware accelerator for GCM cipher in TLS connection on Alpine CPUs;
- defconf - set "configuration.dtim-period=3" for WiFi;
- defconf - use "add-dns-entries=yes" on devices with DHCP server;
- dhcp - fixed processing of DHCP options that are longer than 255 bytes;
- dhcpv4-relay - fixed stability issue when creating duplicate relays;
- dhcpv4-server - do not reset "class-id" parameter when lease loses "bound" status;
- dhcpv4-server - set "ciaddr" in forcerenew messages so a relay, if used, can unicast such messages;
- dhcpv6-relay - fixed non-working relay when adding from WinBox;
- dhcpv6-server - fixed invalid flag;
- discovery - added "address6" column to default "/ip/neighbor" print view;
- discovery - added "discovery" logging topic;
- discovery - added "dying-gasp" feature for LLDP, MNDP, CDP that sends packet with "TTL=0" before graceful reboot/shutdown/upgrade;
- discovery - clear neighbor entry when receiving "dying-gasp" packet;
- discovery - improved service stability when sending discovery packets on interfaces that have hundreds of IP addresses;
- disk - added "last-seen" property that displays disk model and serial when removed;
- disk - added "raid-scrub-cancel" command;
- disk - added error message when disk state transitions from good to bad;
- disk - do not consider USB drives as self-encryption capable;
- disk - fixed "smart-info" not showing information on certain storage devices;
- disk - limited maximum swap size to be no more than 10x of device RAM;
- disk - resolved issue where storage device might change information upon reboot;
- ethernet - disable EEE on hAP be3 Media;
- ethernet - fixed stability issue for Chateau PRO ax devices;
- ethernet - fixed stability issue for devices with Alpine CPU;
- ethernet - removed "1G-baseT-half" link mode on RTL8367 switch;
- fetch - added "ip-type" parameter;
- fetch - added option to force HTTP/2 only (only for ARM64 and x86/CHR devices);
- fetch - fixed false "bad request" response when trying to fetch URL with IPv6 address in it;
- fetch - hint file list for "src-path" and "dst-path" parameters;
- hardware - renamed "max-power" to "manufacturer-reported-max-power";
- iot - added LoRa keep alive logic for UDP protocol;
- iot - added missing LoRa US radio plans;
- iot - added Wiliot USB dongle support;
- iot - allow maximum Modbus "timeout" property to be 10 seconds;
- iot - monitor LoRa worker state (watchdog);
- iot - pass Wiliot certification;
- ip-service - remove reverse-proxy for SMIPS;
- ip-service - show service name for "l2tp";
- ipsec - fixed expired SA handling to prevent “no such item” errors during listing;
- ipsec,ike1 - dropped base mode exchange;
- ipsec,ike1 - fixed negotiated PFS validation;
- ipsec,ike1 - improved SA, transform, fragment parsing and malformed packet validation;
- ipsec,ike2 - fixed ppk child key generation during rekey;
- ipsec,ike2 - improved KE generation validation during initial setup and child SA creation;
- ipsec,ike2 - improved PPK handling by always using it when authorized, including additional Child SAs, and moved PPK processing to the Child SA task;
- ipsec,ike2 - use first child KE selection only during IKE_AUTH exchange;
- ipsec,qkd - moved QKD to "/system/keymat-provider" menu and made it a generic key material provider;
- ipv6 - added "status" column to default "/ipv6/neighbor" print view;
- ipv6,ra - changed default "router-advertisement-route-distance" to 1;
- ipv6,ra - correctly process RAs advertising previously expired prefix;
- ipv6,ra - fixed prefix invalidation;
- ipv6,ra - use lowest value between IPv6/Pool and IPv6/ND/Prefix/Default as dynamic prefix lifetime;
- isis - fixed ECMP route removal;
- l2tp - allow fragmentation of large IPv6 packets;
- l3hw - added HW offloaded support for VLAN interfaces created directly on Ethernet for CRS8xx series switches;
- l3hw - added HW offloaded VRF support on 98DX8208, 98DX8216, 98DX8212, 98DX8332, 98DX3257, 98DX4310, 98DX8525, 98DX3255, 98CX8410 switches;
- l3hw - added VRF assignment via switch ACL rules for devices with Marvell Prestera switch chip;
- l3hw - allow VLAN tagged traffic inside VXLAN tunnel;
- l3hw - fixed VRF-related issues for CRS8xx series switches;
- l3hw - fixed VTEP offload on IPv4 /32 route changes;
- leds - added dark mode support for L009, hAP ax2, hAP ax3, hEX refresh, hEX S (2025), hAP ax S and Chateau ax devices;
- leds - fixed Ethernet activity LED for Chateau LTE18 ax (introduced in v7.23);
- leds - improved interface stats activity for devices with Marvell Prestera switch chip;
- lte - added force-confirmation parameter for eSIM provision command;
- lte - cap IPv6 prefix lifetime for ipv6-interface;
- lte - do not add extra /128 IPv6 address for ipv6-interface;
- lte - do not query 5G neighbor cell info until RG650E-EU FW fixed;
- lte - enabled AT registration unsolicited event reporting for EG25-G and EC25-EU boards;
- lte - fixed cases where R11l-LTE7 modem would not display correct cell info after handover;
- lte - fixed EC/IO scale in CLI and GUI;
- lte - fixed EC25-EU, EG25-G traffic to 67 UDP;
- lte - fixed IPv6 RA handling for multiapn non-primary interface;
- lte - fixed third-party modems ICCID decoding for eSIM;
- lte - improved Cinterion PLS8-E roaming;
- lte - improved deregistration handling for AT modems;
- lte - improved system stability when no APN specified;
- lte - improved USB mode handling for BG770A-GL;
- lte - limit IPv6 prefix lifetime only when lifetime is advertised as infinity;
- lte - make modem MAC persistent for R11e-LTE6 and R11l-LTE7 modems;
- lte - remove site local DNS for ipv6-interface;
- lte - removed extra restart after firmware upgrade for EC200A-EU modem;
- lte - report short cell ID in 3G network mode also for AT modems;
- lte - restrict incoming calls for FG621-EU;
- lte - show "+CME ERROR: 10" as "SIM not present";
- lte - show "data-class" in LTE monitor instead of "access-technology" also for 5G AT modems;
- lte - show "primary-band" instead of "earfcn" in LTE monitor also for modems without CA support;
- lte - show RSCP and EC/IO parameter in 3G network mode for R11e-LTE6, R11l-LTE7 and FG621-EA modems;
- mesh - fixed missing FDB entries from wireless ports;
- mpls - added ICMP time exceeded handler for IPv6;
- mpls - make FastPath work with expl-null;
- netinstall - added Netinstall package;
- netinstall - improved architecture detection;
- netinstall-cli - added "help" parameter;
- netinstall-cli - added "reboot" and "shutdown" flags to control reboot after installation;
- netwatch - fixed an issue with DNS probe "timeout" parameter;
- netwatch - fixed HTTP GET probe over IPv6;
- netwatch - fixed inaccurate "rtt-stdev" value;
- netwatch - fixed issue where ICMP probes did not accept TTL exceeded packets when "accept-icmp-time-exceeded" was enabled;
- netwatch - increased maximum packet size to 65535;
- ospf - fixed stability issue during interface flaps;
- ospf - force passive for VRF interface;
- pimsm - make "hash-mask-length" parameter naming consistent and fixed typos;
- poe-in - added PoE-in monitoring and LLDP-based PoE negotiation support for newer devices (e.g. CRS504, CRS510, hEX S 2025, hAP be3 Media);
- poe-out - firmware update for 802.3at capable boards (the update will cause a brief power interruption to poe-out interfaces);
- poe-out - firmware update for 802.3bt capable boards (the update will cause a brief power interruption to poe-out interfaces);
- ppp - added "MT-Address-List" to IPv6 address list when received from RADIUS and using DHCP for IPv6 configuration;
- ppp - added iccid field to ppp info command for BG77 and BG770 modems;
- ppp - always show current FW version when running firmware-upgrade;
- ppp - disable/enable modem radio state depending on ppp interface state;
- ppp - fixed cases where BG77 or BG770 firmware upgrade was not available;
- ppp - fixed ppp-out stability issue;
- ppp - get IPv6 configuration via RA for modems using PPP emulation mode;
- ppp - improved "info" command for BG77 and BG770 modems;
- ppp - improved OVPN underlying SSL connection management;
- ppp - only show pin in export with "show-sensitive" flag;
- ppp - report actual network data usage statistics instead of "0" for all IPv6 RADIUS accounting parameters on accounting "Stop" packet;
- ppp - toggle radio state on interface disable/enable;
- queue - fixed "undo" command for simple queues;
- reverse-proxy - improved stability;
- rip - do not export authentication keys by default;
- route - allow to add route with link-local destination address;
- route - fixed memory leak when flapping addresses or interfaces with routing protocols running;
- route - fixed potential race condition;
- route - respect the "interface" property when pinging IPv6 addresses over ECMP;
- sfp - fixed linking for hAP ax S and hEX S (2025) with "1G-baseX" link-mode;
- sfp - removed unsupported "2.5G-baseX" speed on CRS312-4C+8XG and CRS326-4C+20G+2Q+;
- sftp - fixed branding package upload;
- sms - added some GSM7 symbols to SMS tool;
- snmp - added hotspot active-user-count and host-count OIDs to MIKROTIK-MIB;
- snmp - added missing SFP OIDs to MIKROTIK-MIB;
- snmp - added WiFi current channel "mtxrWifiInterfacesCurrentChannel" OID to MIKROTIK-MIB;
- ssh - added mlkem768x25519-sha256 key exchange support;
- ssh - do not attempt automatic empty password login when RADIUS is used;
- ssh - fixed SSH tunnel with IPv6 link-local address on non-ethernet interfaces;
- ssh - make SSH packet validation more strict;
- supout - added interface monitor-traffic;
- supout - added LTE eSIM section;
- switch - fixed IEEE reserved MAC handling for CRS1xx, CRS2xx switches;
- system - improved stability;
- system - renamed "factory-software" to "minimum-version" and "factory-firmware" to "minimum-firmware";
- system - restrict RouterOS processes using swap;
- system - show who is using "/system serial-terminal";
- traffic-generator - fixed injecting pcap/pcapng files on MIPSBE architecture;
- tunnel - fixed stability issue caused by a misconfigured routing loop under bridge (introduced in v7.22);
- upgrade - removed sensitive policy for "apply-changes" command;
- usb - allow overriding the power-reset duration;
- usb - fixed USB Ethernet interface default-name;
- vpls - added transmit loop detection;
- vrrp - added "v3-checksum-as-v2" setting;
- vrrp - fixed stability issue when "sync-connection-tracking" is enabled;
- vxlan - fixed missing L2MTU property when VRF is specified;
- vxlan - ignore disabled interfaces when checking for configuration conflicts;
- webfig - fixed issue with increasing keep-alive traffic;
- webfig - improved underlying encryption and stability processing;
- webfig - improvements to graphs;
- wifi - added "Preamble Puncturing" under "WiFi/Channel" menu;
- wifi - added dash when CAPsMAN generates interface name and prefix ends with digit;
- wifi - improved roaming/steering behavior for WiFi 7 MLO;
- wifi - improved stability;
- wifi - improved station-bridge mode;
- wifi - updated radio regulatory information;
- wifi - upgraded wifi-qcom driver;
- wifi-mediatek - fixed broken interfaces on startup;
- wifi-mediatek - fixed some channel definitions for certain countries;
- wifi-mediatek - improved channel switching;
- wifi-mediatek - improved stability during MLO channel switching;
- winbox - added "Network" configuration menu for WiFi;
- winbox - added "Preferred Architecture" setting for L009;
- winbox - added "SIM PIN" under "Tools/SMS";
- winbox - fixed "Connection Bytes" field under "IP/Firewall" menu;
- winbox - fixed "EC/IO" scaling for LTE interface;
- winbox - fixed "Use Ipsec" and "Ipsec Secret" under "Interfaces/L2TP Ether" menu;
- winbox - fixed empty value in "Immediate Gateway" under "IP/Routes" menu;
- winbox - fixed sort for "Address List" under "IPv6/Firewall" menu;
- winbox - make LoRa "Auth key" and MQTT "Password" sensitive;
- winbox - move "EAP" under "Security" tab for WiFi;
- winbox - show "Any. Port" column by default under "IP/Firewall" menu;
- winbox - show preferred and valid lifetime of IPv6 address also on static IPs;
- winbox - show priority bits in "VLAN ID" field under "Tools/Packet Sniffer" menu;
- wireguard - added support for domain names in client-dns;
- wireguard - added warning when allowed-address overlaps with another peer on the same interface;
- wireguard - fixed peer recreation on interface change;
- wireguard - fixed peer Tx/Rx counters;
- wireguard - fixed wg-export comments output and case when endpoint is not set;
- wireguard - fixed whitespace handling in AllowedIPs during wg-import;
- wireguard - generate port number when specified as zero;
- wireguard - improved wg-export to print endpoint domain name;
- wireguard - improved wg-import to quietly ignore wg-quick specific keys;
- wireguard - reconfigure peer only when meaningful changes are detected;
- wireguard - reinitialize socket on VRF change;
- x86 - fixed IRQ displaying per CPU on Intel 700 series NIC;
To upgrade, click Check For Updates under System/Packages menu and select the stable Channel in RouterOS configuration interface, or head to our download page: http://www.mikrotik.com/download
- Everything went smoothly
- I encountered an issue after the update (please post about the device, configuration, and unexpected symptoms)
- I encountered an issue, but solved it (please post the solution)
If you experience version related issues, then please send supout file from your router to support@mikrotik.com. The file must be generated while a router is not working as suspected or after some problem has appeared on the device
