MAIN AP config:
# 2026-07-14 13:31:02 by RouterOS 7.23.2
# software id = xxxxxxxxx
# model = E62iUGS-2axD5axT
# serial number = xxxxxxxxxxx
add name=bridge1 vlan-filtering=yes
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/interface vlan
add comment=WIFI-EXTvlan interface=bridge1 name=vlan1 use-service-tag=yes \
vlan-id=120
add comment=WIFI-HOvlan interface=bridge1 name=vlan2 use-service-tag=yes \
vlan-id=130
/interface wifi channel
add band=2ghz-ax disabled=no frequency=2462 name=channelcfg width=20/40mhz
add band=5ghz-ax disabled=no frequency=5240 name=channel5ghz width=\
20/40/80mhz
/interface wifi configuration
add antenna-gain=0 country=Germany disabled=no installation=indoor name=\
WIFIINTcfg ssid=WIFI-INT_optout_nomap
WIFIEXTcfg ssid=WIFI-EXT_optout_nomap
WIFIHOcfg ssid=WIFI-HO_optout_nomap
add antenna-gain=0 country=Germany disabled=no hide-ssid=yes installation=\
indoor name=WIFIINT1cfg ssid=WIFI-INT1_optout_nomap
/interface wifi security
add authentication-types=wpa2-psk disabled=no encryption=ccmp name=WIFI-INTsec
add authentication-types=wpa2-psk disabled=no encryption=ccmp name=WIFI-EXTsec
add authentication-types=wpa2-psk disabled=no encryption=ccmp name=WIFI-HOsec
/interface wifi
set [ find default-name=wifi1 ] channel=channelcfg comment=WIFI-INT \
configuration=WIFIINTcfg configuration.mode=ap disabled=no security=\
WIFI-INTsec security.ft=yes .ft-over-ds=yes .wps=disable
set [ find default-name=wifi2 ] channel=channel5ghz configuration=WIFIINT1cfg \
configuration.mode=ap disabled=no security=WIFI-INTsec security.wps=\
push-button
add comment=WIFI-EXT configuration=WIFIEXTcfg configuration.mode=ap \
datapath.bridge=bridge1 .vlan-id=120 disabled=no mac-address=\
XX:XX:XX:XX:D9:58 master-interface=wifi1 name=wifi3 security=WIFI-EXTsec \
add comment=WIFI-HO configuration=WIFIHOcfg configuration.mode=ap \
datapath.bridge=bridge1 .client-isolation=yes .vlan-id=130 disabled=no \
mac-address=XX:XX:XX:XX:D9:59 master-interface=wifi1 name=wifi4 security=\
WIFI-HOsec security.ft=yes .ft-over-ds=yes .wps=disable
/system script
add dont-require-permissions=no name=DisableWifi owner=user1 policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source=\
"/interface/disable wifi1;"
add dont-require-permissions=no name=EnableWifi owner=user1 policy=\
"/interface/enable wifi1;"
add dont-require-permissions=no name=DisableWifi2 owner=user1 policy=\
"/interface/disable wifi2;"
add dont-require-permissions=no name=EnableWifi2 owner=user1 policy=\
"/interface/enable wifi2;"
add bridge=bridge1 interface=wifi1
add bridge=bridge1 interface=wifi2
/ipv6 settings
set disable-ipv6=yes
/interface bridge vlan
add bridge=bridge1 tagged=ether1 vlan-ids=120
add bridge=bridge1 tagged=ether1 vlan-ids=130
/ip dhcp-client
add comment="Server Uplink DHCP" interface=bridge1 name=client1
/system clock
/system leds
set 0 interface=wifi1 leds=wifi1-led type=wireless-status
set 1 interface=wifi2 leds=wifi2-led type=wireless-status
/system ntp client
set enabled=yes
/system ntp client servers
add address=XXX.XXX.XX.X
/system scheduler
add interval=1d name=DisableWifiScheduler on-event=DisableWifi policy=\
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon \
start-date=2026-07-02 start-time=23:59:00
add interval=1d name=EnableWifiScheduler on-event=EnableWifi policy=\
start-date=2026-07-03 start-time=05:30:00
add interval=1d name=EnableWifiScheduler2 on-event=EnableWifi2 policy=\
add interval=1d name=DisableWifiScheduler2 on-event=DisableWifi2 policy=\
/tool graphing
set store-every=hour
/tool graphing interface
add allow-address=XXX.XXX.XX.XX/32 store-on-disk=no
Repeater/Extender config:
# 2026-07-02 10:35:23 by RouterOS 7.21.5
# software id = XXXXXXXXXXXXXX
# serial number = XXXXXXXXXXXXX
add name=bridge1
/interface wifi
set [ find default-name=wifi2 ] configuration.country=Germany .mode=\
station-bridge .ssid=XXXXXXXXXXXXXXXXX disabled=no \
security.authentication-types=wpa2-psk .encryption=ccmp
/ip dhcp-client
add interface=bridge1
