tx rx fp rx dropped pppoe account
Hello All. I’m running into an issue which is the tx rx fp rx dropped to 0. The solution to fix that is by press disable and enable the pppoe account. Is there any work around script to automatically disable pppoe account and enable it again once dropped?
Few solutions but always Build In are the best.
/tool traffic-monitor add name=CheckPPPoE interface=pppoe-out1 traffic=received trigger=always threshold=0 on-event=SystemScriptNameToRun comment="ThanxToSiB" disabled=no
and in System Scripts this name=SystemScriptNameToRun:
/interface pppoe-client enable pppoe-out1;
This is ReEnable means create new connection.
All this can be more complicated but I hope this method will be good.
Thank you I will test it and report
Tested. When the threshold 0, the trigger hit run time 298 times, until I disable the script, re-enable manually and the pppoe connected and back to normal. Any advice please?
Again happened this morning
Single/One pppoe with ISP in standard situation newer reach 0 and the traffic monitor is good idea to check if problem exist.
You situation I think is other. When you not have a “big transfer” as normal traffic then you should change a checking way. Before, I answer you a generic information to generic question.
This mean the 0 at Rx is your normal behavior and you not gave many traffic/customers behind your device and then TrafficMonitor generate 298 fail-possitive check’s I assume.
Re-enable TrafficMonitor script or ppppoe interface?
I think the pppoe interface - this means the TrafficMonitor generate failse possitive re-enable and ROS cannot do connection?
Maybe the proper way to re-enabled in ROS is disable and separate enable the pppoe interface to do re-connection.
Maybe you should change your request.
This Rx=0 show at pppoe even when he works well and you have “not use of internet” - this give you info that way of checking interface are bad and you need other way.
Please write more about you situation.
Maybe you should have something like
  • Netwatch who will be checking accessibility to remote host?
  • Recursive Routing who will be checking this pppoe as accessibility to remote host?
  • Own script who will be checking traffic via this pppoe and do action if no-internet will be detected by this intereface.
Many ways but you must write more about your situation.
My situation the PPPoE Status (Connected) and FP Rx 0 OR Rx 0, when i served internet there is no internet until I Disable and Re-enable PPPoE account, What I’m looking for If I got the FP Rx 0 or Rx 0 Then the Script or built-in configuration disconnect the PPPoE account and enable. Appreciate your support in advance my friend.
Yes I think of that, Rx 0, I try to navigate to youtube or any website to have transfer and see if it changed from 0, All my tries failed. The only way disable the PPPoE account and enable it again to have the internet back
I don’t know why the TrafficMonitor generate that big failed check, I just Disable the TM to avoid disconnect-Connect fail request and as usual disable the account and enable it manually.
Used script below but not working when I lost the internet written by rextended http://forum.mikrotik.com/t/check-locked-pppoe-pptp-l2tp-sstp-ovpn-ppp-connections/75396/1
/system scheduler
add disabled=no interval=20m name=check-ppp-client on-event=":log info message=\"*** start check any ppp client connection ***\";\r\
    \n:local pppTest value=[/ppp active find];\r\
    \n:local pingNumber value=2;\r\
    \n:local pingMin value=1;\r\
    \n:foreach userTest in=\$pppTest do={\r\
    \n :local pingOk value=[:ping [/ppp active get \$userTest value-name=address] count=\$pingNumber]\r\
    \n :if ( \$pingOk < \$pingMin) do={\r\
    \n  :log warning message=([/ppp active get \$userTest value-name=service] . \" auto disconnected: \". \$pingOk . \" ping ok over \" . \$pingNumber . \" \" . [/ppp active get \$userTest value-name=name] . \" \" . [/ppp active get \$userTest value-\
    name=address])\r\
    \n  /ppp active remove \$userTest\r\
    \n }\r\
    \n};\r\
    \n:log info message=\"*** end check any ppp client connection ***\";\r\
    \n" policy=ftp,read,write,test start-date=jan/01/2002 start-time=00:20:00
Re-enable manually the PPPoE, because the TM generate big false re enable.
I have explained my situation, please your kind support
Hello again,
Give me materials to work, means.
*) What do a proper re-connection?
# or
/interface pppoe-client disable pppoe-out1; /interface pppoe-client enable pppoe-out1;
*) Internet Detection.
You have internet only from pppoe-out1 and when it’s have Rx=0 and Tx=0 then what is a status of this connection?
Provide me a cli print without login/pass:
interface pppoe-client print detail
put [interface pppoe-client monitor pppoe-out1 once as-value ]
and/or screenshot from Status tab.
We can connect TrafficMonitor with one of those status infrormation to do proper checking and restarting pppoe.
Alternative will be scheduler and netwatch since.
status connection
And main question. In Status Tab is a different value when internet is online?
I know Rx=0 but I search some additional who is other in offline and online mode.
Alaqmar12121
But you not share both screenshot to compare.
In this scenario, with all screenshot you provide I think that the best ways will be for you use from Netwatch+Scheduler to monitor internet and do reconnection when off-line will be x minutes.
I Describe this way with one ISP in this post: http://forum.mikrotik.com/t/script-to-test-wan-and-reset-usb-power-on-down/106067/5
Your version are like this:
1. Create NetWatch → only it will do ping testing of target host and run up/down-script.
/tool netwatch add host=1.1.1.1 interval=10s timeout=500ms disabled=no comment=InternetWatchDog
*) 2. Add UP-script → Remove future fix action because ISP is up.
Do Nothing more.
/system scheduler remove [find where name~"SiBexInternetWatchDog_"];
/log warning "RESET Netwatch scheduled DOWN-script... ISP WORKS";
*) 3a. Add DOWN-script → ReCreate future jobs before DeadLine came true in 1m and last hope do reboot in 2m.
log error "start Netwatch DOWN-script...";
# ################ MAIN PROGRAM BELOW, NOT HERE ##############
# ################ DEFINE FUNCTION SOLVING Crossing Midnight ###########################
# Fix Crossing 24:00:00=00:00:00
/local SiBFixDateTime do={
/local SiBTimeToChange "23:45:00";
/local SiBTimeToChange $2;
/local SiBTimeDiffToAdd "60m2s"; # diff time < 24h
/local SiBTimeDiffToAdd $3; # diff time < 24h
#/local SiBDate "dec/31/2020"
/local SiBDate $1
/local SiBDateCorrected;
#log warning ("Source: ".$SiBDate." ".$SiBTimeToChange." + ".$SiBTimeDiffToAdd);
#put ("Source: ".$SiBDate." ".$SiBTimeToChange." + ".$SiBTimeDiffToAdd);
# Add diff time <=24h
/local SiBTimeAndDiffTime ($SiBTimeToChange + $SiBTimeDiffToAdd );
/if ([/len $SiBTimeAndDiffTime]=8) do={/set $SiBDateCorrected ($SiBDate." ".$SiBTimeAndDiffTime); };
/if ([/len $SiBTimeAndDiffTime]>8) do={
  /set $SiBTimeAndDiffTime ($SiBTimeAndDiffTime-1d);
  ## Add 24h to date, copy time if exist.
  # Days: 01-27
  local SiBDayToChange [/pick $SiBDateCorrected 4 6;];
  if ($SiBDayToChange<=27) do={
      set $SiBDayToChange ($SiBDayToChange+1);
      if ([/len $SiBDayToChange]=1) do={set $SiBDayToChange ("0".$SiBDayToChange)}
      set $SiBDateCorrected ( [/pick $SiBDateCorrected 0 4].$SiBDayToChange.[/pick $SiBDateCorrected 6 20] );
    } else={
      if ($SiBDayToChange!=31) do={
          # Days: 28..30; Main magic do internal scheduler.
          /system scheduler remove [find name=SiBTempScheduler2qw34er5v78bn90m];
          /system scheduler add name=SiBTempScheduler2qw34er5v78bn90m on-event={nothing } start-time=00:00:01 start-date=( [/pick $SiBDateCorrected 0 4].($SiBDayToChange+1).[/pick $SiBDateCorrected 6 11 ] );
          set $SiBDateCorrected ([system scheduler get [find name=SiBTempScheduler2qw34er5v78bn90m] start-date].[/pick $SiBDateCorrected 11 20 ]);
        } else={
          # Day 31 for Jan..Nov
          /local SiBMonths ("jan","feb","mar","apr","may","jun","jul","aug","sep","oct","nov","dec");
          /local SiBMounthToChange [/pick $SiBDateCorrected 0 3];
          for x from=0 to=10 do={if ([/pick $SiBMonths $x]=$SiBMounthToChange) do={ set $SiBDateCorrected ([pick $SiBMonths ($x+1)]."/01".[/pick $SiBDateCorrected 6 20 ]) }}
          # Day 31 for Dec
          if ($SiBMounthToChange="dec") do={ set $SiBDateCorrected ("jan/01/".([/pick $SiBDateCorrected 7 11]+1).[/pick $SiBDateCorrected 11 20] )}
#log warning ("New date time: ".$SiBDateCorrected);
#put ("New date time: ".$SiBDateCorrected);
:return $SiBDateCorrected
# ################ MAIN PROGRAM ###########################
# Select a proper Netwatch
local LocNetWatchHost 1.1.1.1;
local LocNetWatchHostComment "InternetWatchDog";
# Still is status down?
local LocStatus [/tool netwatch get [find host=$LocNetWatchHost comment=$LocNetWatchHostComment ] status];
if ($LocStatus != "down") do={/quit;}
# Convert the Netwatch SINCE to separate date and time of current down-time.
local LocSince  [/tool netwatch get [find host=$LocNetWatchHost comment=$LocNetWatchHostComment status=down ] since];
local LocSinceDate ([/pick $LocSince 0 11]);
local LocSinceTime ([/pick $LocSince 12 20]);
# Add action to future via scheduler
/system scheduler remove [find where name~"SiBexInternetWatchDog_v"];
# Try MAIN ACTION 1 - PPPoE ReEnable after 1m
local SiBCrossMid [$SiBFixDateTime $LocSinceDate $LocSinceTime 1m ];
local SiBStartDate [pick $SiBCrossMid 0 11];
local SiBStartTime [pick $SiBCrossMid 12 20];
/system scheduler add name=SiBexInternetWatchDog_v1 on-event={/interface pppoe-client disable pppoe-out1; /interface pppoe-client enable pppoe-out1;} start-date=$SiBStartDate start-time=$SiBStartTime;
# Try MAIN ACTION 2 - Reboot after 2m
local SiBCrossMid [$SiBFixDateTime $LocSinceDate $LocSinceTime 2m ];
/system scheduler add name=SiBexInternetWatchDog_2 on-event={/system reboot;} start-date=$SiBStartDate start-time=$SiBStartTime;
log error "stop Netwatch DOWN-script, Future action are scheduled";
Sorry for not attached the screenshot. Please check attached.
The script provided should I run it using system ---> scripts?
3a. Add DOWN-script -> ReCreate future jobs before DeadLine came true in 1m and last hope do reboot in 2m.
Code: Select all
Can we just ignore the rebooting please? Just want to Disable the pppoe and enable it after 25 second
WinBox > Tools > NetWatch - here a place with 3 tabs, up and down tab are two script who are running when access to remote host change to up (work) or down (failure).
Host 1.1.1.1 and Comment are important because they are use to check a result of proper netwatch.
Please setup Netwatch to 00:00:05 (check 1.1.1.1 every 5s).
In Down-script, the action “after 20 second do reconnection” without reboot, this will be done in 20-25s from internet failure.
Final script:
/tool netwatch add host=1.1.1.1 interval=5s timeout=500ms disabled=no comment=InternetWatchDog
*) 2. Add UP-script → Remove future fix action because ISP is up. Do Nothing more.
*) 3a. Add DOWN-script → ReCreate future jobs before DeadLine came true in 20s.
/local SiBDate $1
  # Days: 01-27
    } else={
        } else={
          # Day 31 for Dec
# Select a proper Netwatch who is ENABLE and have:
local LocStatus [/tool netwatch get [find host=$LocNetWatchHost comment=$LocNetWatchHostComment disabled=no] status];
local LocSince  [/tool netwatch get [find host=$LocNetWatchHost comment=$LocNetWatchHostComment status=down disabled=no] since];
# Try MAIN ACTION 1 - PPPoE ReEnable after 20s
local SiBCrossMid [$SiBFixDateTime $LocSinceDate $LocSinceTime 20s ];
Tried to understand something out of this “issues” but I just don’t get it.
What is the initial issue?
The FP Tx = 0 ?
That’s normal.
While connected to a router which is mostly idle, from outside.:
/interface monitor-traffic ppp-wan once
rx-packets-per-second: 8
rx-bits-per-second: 5.2kbps
fp-rx-packets-per-second: 8
fp-rx-bits-per-second: 5.2kbps
rx-drops-per-second: 0
rx-errors-per-second: 0
tx-packets-per-second: 11
tx-bits-per-second: 101.3kbps
fp-tx-packets-per-second: 0
fp-tx-bits-per-second: 0bps
tx-drops-per-second: 0
tx-queue-drops-per-second: 0
tx-errors-per-second: 0
And after beeing connected also to a device behind it so the firewall has to forward a few packets:
rx-packets-per-second: 15
rx-bits-per-second: 9.8kbps
fp-rx-packets-per-second: 15
fp-rx-bits-per-second: 9.8kbps
tx-packets-per-second: 18
tx-bits-per-second: 166.4kbps
fp-tx-packets-per-second: 5
fp-tx-bits-per-second: 54.2kbps
No issue.
ppp-wan wasn’t reconnected since boot. (link downs = 0).
